Re: Help with ANT [ Tutorial-Video ] [message #635859 is a reply to message #635792] |
Thu, 28 October 2010 07:49   |
Hi Toni,
I am talking about the library.xml file. This file can be found in: {eclipse-home}/plugins/org.eclipse.swtbot.eclipse.junit4.hea dless_version_number/library.xml
The entire file is:
<?xml version="1.0"?>
this has been copied from o.e.test plugin with some targets for SWTBot
<project name="Library" default="usage" basedir="C:">
<target name="usage">
<echo message="Please refer to the testframework.html in org.eclipse.test for instructions on usage." />
</target>
<target name="init">
Parameters:
(Mandatory)
data-dir - the directory for Eclipse to write its data
plugin-name - the name of the plugin to test
classname - the name of the test class
(Optional - overrides defaults set in script)
testProduct - a string containing the product id to test.
testApplication - a string containing the application id to test.
vmargs - a string containing arguments to pass to the VM.
extraVMargs - allows separate setting of VM args from separate caller.
timeout - overrides default test timeout value (in milliseconds).
test-output - overrides default output file produced from test run.
plugin-path - path to root of plug-in
useEclipseExe - property setting forces test to launch via eclipse executable.
junit-report-output - output directory for junit reports produced for specified classname.
<tstamp>
<format property="TIMENOW" pattern="HHmmssSSSS" />
</tstamp>
<!--property setting useEclipseExe launches tests using the eclipse executable-->
<condition property="launchTarget" value="eclipse-test">
<isset property="useEclipseExe" />
</condition>
<!--default launch target for launching tests-->
<property name="launchTarget" value="java-test" />
<!-- default product/application to launch -->
<condition property="testproduct.if.available" value="-product ${testProduct}">
<isset property="testProduct" />
</condition>
<property name="testproduct.if.available" value="" />
<condition property="testapplication.if.available" value="-testApplication ${testApplication}">
<isset property="testApplication" />
</condition>
<property name="testapplication.if.available" value="" />
<!--default heap sizes when running performance tests-->
<condition property="vmargs" value=" -Xms256M -Xmx256M">
<equals arg1="${test.target}" arg2="performance" />
</condition>
<property name="extraVMargs" value="" />
<property name="plugin-path" value="" />
<property name="timeout" value="7200000" />
<property name="test-output" value="${eclipse-home}/${classname}.xml" />
<property name="junit-report-output" value="C:\results" />
<mkdir dir="${junit-report-output}" />
</target>
<target name="swtbot-test" description="Eclipse application used to launch UI plugin tests." depends="init">
<antcall target="${launchTarget}">
<!--param name="application" value="org.eclipse.test.uitestapplication"/-->
<param name="application" value="org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplication" />
</antcall>
</target>
<target name="java-test">
<!--default vm args-->
<property name="vmargs" value="-Xms256m -Xmx512m" />
<!-- this argument is needed for macosx -->
<condition property="jvmOption" value="-XstartOnFirstThread -Dorg.eclipse.swt.internal.carbon.smallFonts">
<os family="mac" />
</condition>
<property name="jvmOption" value="" />
<!--set default jvm to use for testing-->
<property name="jvm" value="${java.home}/bin/java" />
<property name="launcher-arg-line" value="
-application ${application}
${testproduct.if.available}
${testapplication.if.available}
-data ${data-dir}
formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJUnitResultFormatter,${test-output} formatter=org.apache.tools.ant.taskdefs.optional.junit.PlainJUnitResultFormatter
-testPluginName ${plugin-name}
-className ${classname}
-os ${os}
-ws ${ws}
-arch ${arch}
-consoleLog
-debug" />
<property name="jvm-arg-line" value="${vmargs} ${extraVMargs} ${jvmOption}" />
<echo>======================================</echo>
<echo>Running swtbot junit tests in ${classname}</echo>
<echo>Command line args are ${launcher-arg-line}</echo>
<echo>JVM args are ${jvm-arg-line}</echo>
<echo>JUnit Result File: ${junit-report-output}/${classname}.xml.</echo>
<echo>Console output File: ${junit-report-output}/${classname}.txt.</echo>
<fail unless="application" message="variable 'application' not defined." />
<fail unless="data-dir" message="variable 'data-dir' not defined." />
<fail unless="test-output" message="variable 'test-output' not defined" />
<fail unless="plugin-name" message="variable 'plugin-name' not defined" />
<fail unless="classname" message="variable 'classname' not defined" />
<fail unless="os" message="variable 'os' not defined. os can be one of win32, linux, macosx" />
<fail unless="ws" message="variable 'ws' not defined. ws can be one of win32, wpf, gtk, carbon, cocoa" />
<fail unless="arch" message="variable 'arch' not defined. arch can be one of x86, x86_64, ppc" />
<pathconvert property="foundJunit3" setonempty="false" pathsep=" ">
<path>
<fileset dir="${eclipse-home}/plugins" includes="org.eclipse.swtbot.eclipse.junit3.headless*/META-INF/MANIFEST.MF" />
<fileset dir="${eclipse-home}/plugins" includes="org.eclipse.swtbot.ant.optional.junit3*" />
</path>
</pathconvert>
<fail if="foundJunit3">
Found org.eclipse.swtbot.eclipse.junit3.headless or org.eclipse.swtbot.ant.optional.junit3 in the plugins directory.
JUnit 3.x and 4.x don't play well together.
Please remove org.eclipse.swtbot.eclipse.junit3.headless and org.eclipse.swtbot.ant.optional.junit3 from the plugins dir.
</fail>
<java fork="true" dir="." timeout="${timeout}" jvm="${jvm}" logError="true" classname="org.eclipse.core.launcher.Main" output="${junit-report-output}/${classname}.txt">
<classpath>
<fileset dir="${eclipse-home}/plugins">
<include name="org.eclipse.equinox.launcher_*.jar" />
</fileset>
</classpath>
<arg line="${launcher-arg-line}" />
<arg line="-application org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplication"/>
<arg line="-testApplication ${test-classname}"/>
<arg line="-testPluginName ${plugin-name}"/>
<arg line="-os win32"/>
<arg line="-ws win32"/>
<arg line="-arch x86"/>
<arg line="-data C:\work_test"/>
<jvmarg line="${jvm-arg-line}" />
<sysproperty key="PLUGIN_PATH" value="${plugin-path}" />
</java>
<echo>If you see errors above please see the file ${junit-report-output}/${classname}.txt for more information.</echo>
<echo>Errors are generally caused by missing or incorrect dependencies.</echo>
<antcall target="collect-results" />
</target>
<target name="collect-results">
<dirname property="output-dir" file="${test-output}" />
<basename property="output-file-name" file="${test-output}" />
<junitreport todir="${junit-report-output}" tofile="${classname}.result.xml">
<fileset dir="${output-dir}">
<include name="${output-file-name}" />
</fileset>
</junitreport>
<style style="${eclipse-home}/plugins/org.eclipse.swtbot.eclipse.junit4.headless_2.0.0.595-dev-e36/JUNIT.XSL" basedir="${junit-report-output}" includes="${classname}.result.xml" destdir="${junit-report-output}" />
<!--save .log content and *.log content from configuration directory-->
<concat destfile="${junit-report-output}/${classname}.log">
<fileset dir="${eclipse-home}" includes="${data-dir}/.metadata/*.log" />
<fileset dir="${eclipse-home}" includes="configuration/*.log" />
</concat>
</target>
<target name="collect">
This target can be used to aggragate test runs from multiple test suites into a single report.
Parameters to this target:
includes - the names of the files to include
output-file - the name of the output file to produce
<junitreport todir="." tofile="${output-file}">
<fileset dir=".">
<include name="${includes}" />
</fileset>
</junitreport>
</target>
</project>
I hope it helps you.
Victor.
FUDForum. Page generated in 0.05578 seconds
