Home » Eclipse Projects » SWTBot » Troubles with "java.lang.NoClassDefFoundError: junit/framework/TestListener" in headless m
Troubles with "java.lang.NoClassDefFoundError: junit/framework/TestListener" in headless m [message #34738] Thu, 07 May 2009 09:15 Go to next message
Originally posted by: samuel.judith.anyware-tech.com
Hi everybody,
I try to get my product working with swtbot headless.
My generated product contains org.junit3.8 and unhappily I has
systematically the following message:
Exception in thread "WorkbenchTestable" java.lang.NoClassDefFoundError:
[java] at java.lang.ClassLoader.defineClass1(Native Method)
[java] at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
[java] at
[java] at
org.eclipse.swtbot.eclipse.junit3.headless.EclipseTestRunner .createFormatter(Unknown
Source)
[java] at
org.eclipse.swtbot.eclipse.junit3.headless.EclipseTestRunner .createAndStoreFormatter(Unknown
Source)
[java] at
org.eclipse.swtbot.eclipse.junit3.headless.EclipseTestRunner .run(Unknown
Source)
[java] at
org.eclipse.swtbot.eclipse.junit3.headless.UITestApplication .runTests(Unknown
Source)
[java] at
org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.java:68)
[java] at java.lang.Thread.run(Thread.java:619)
Does someone has an idea to give me please ?
Thanks much,
Samuel
Re: Troubles with "java.lang.NoClassDefFoundError: junit/framework/TestListener" [message #35030 is a reply to message #34738] Fri, 08 May 2009 01:00 Go to previous messageGo to next message
What version of eclipse/swtbot are you using ? Did you delete the junit4
headless feature from the target eclipse ? You should only have the junit3
plugins from swtbot. http://wiki.eclipse.org/SWTBot/Ant talks about
headless builds, read the setup section carefully, also turning on
-consoleLog and -debug as part of the command line argument may provide
more information.
If all else fails, as a workaround: You can make your test plugins depend
on junit 4.x and use the junit4 headless runner while keeping your tests
the same. JUnit 3 headless framework has not changed at all since the last
time I used it so this will need some investigation.
-- Ketan
Samuel JUDITH wrote:
> Hi everybody,
> [java] at
> [java] at
> Source)
> [java] at
> Source)
> [java] at
> Source)
> [java] at
> Source)
> [java] at
> Thanks much,
> Samuel
Re: Troubles with "java.lang.NoClassDefFoundError: junit/framework/TestListener" [message #35064 is a reply to message #35030] Fri, 08 May 2009 05:20 Go to previous messageGo to next message
Hi Ketan,
I use eclipse 3.4.2 and the following swtbot features are installed:
- org.eclipse.swtbot_2.0.0.204-dev
- org.eclipse.swtbot.eclipse_2.0.0.204-dev
- org.eclipse.swtbot.eclipse.test_2.0.0.204-dev
I have well deleted the junit4 headless plugins from the plugins directory.
I will test with junit4 and I will inform you.
Thanks a lot,
Samuel
> junit3 plugins from swtbot. http://wiki.eclipse.org/SWTBot/Ant talks
> about headless builds, read the setup section carefully, also turning on
> more information.
> depend on junit 4.x and use the junit4 headless runner while keeping
> your tests the same. JUnit 3 headless framework has not changed at all
> since the last time I used it so this will need some investigation.
> -- Ketan
>> Hi everybody,
>> [java] at
>> [java] at
>> [java] at
>> Source)
>> [java] at
>> Source)
>> [java] at
>> Source)
>> [java] at
>> Source)
>> [java] at
>> Thanks much,
>> Samuel
Re: Troubles with "java.lang.NoClassDefFoundError: junit/framework/TestListener" in headle [message #551744 is a reply to message #34738] Mon, 09 August 2010 08:39 Go to previous messageGo to next message
I am facing the same exception: java.lang.NoClassDefFoundError: junit/framework/TestListener. I am using Eclipse 3.5.
Please help me resolve this issue, as I am stuck badly.
My test plugin depends on:
org.eclipse.ui,
org.eclipse.core.runtime,
org.junit4;bundle-version="4.5.0",
org.eclipse.ui,
org.eclipse.swtbot.eclipse.core,
org.eclipse.swtbot.junit4_x,
org.hamcrest,
org.apache.log4j,
org.eclipse.swtbot.swt.finder,
org.eclipse.swtbot.eclipse.finder,
org.eclipse.core.resources,
org.eclipse.ant.core,
org.eclipse.core.runtime.compatibility,
org.eclipse.swtbot.eclipse.junit4.headless;bundle-version="2.0.0 "
Complete stack trace is :
[java] Exception in thread "WorkbenchTestable" java.lang.NoClassDefFoundError: junit/framework/TestListener
[java] at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:183)
[java] at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:576)
[java] at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:546)
[java] at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:477)
[java] at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader(ClasspathManager.java:465)
[java] at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:445)
[java] at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
[java] at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:376)
[java] at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:452)
[java] at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:405)
[java] at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:393)
[java] at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
[java] at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
[java] at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
[java] at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadCla ss(SingleSourcePackage.java:33)
[java] at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:440)
[java] at org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner .createFormatter(EclipseTestRunner.java:455)
[java] at org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner .createAndStoreFormatter(EclipseTestRunner.java:437)
[java] at org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner .run(EclipseTestRunner.java:179)
[java] at org.eclipse.swtbot.eclipse.junit4.headless.UITestApplication .runTests(UITestApplication.java:115)
[java] at org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.java:71)
[java] at java.lang.Thread.run(Thread.java:595)
Re: Troubles with "java.lang.NoClassDefFoundError: junit/framework/TestListener" in headle [message #551788 is a reply to message #551744] Mon, 09 August 2010 10:23 Go to previous messageGo to next message
Since this pops up very frequently, I've documented this here:
http://goo.gl/e4Br
Please go through the instructions and let us know about your progress.
Ketan
http://ketan.padegaonkar.name | http://eclipse.org/swtbot
> org.eclipse.ui,
> org.eclipse.ui,
> org.hamcrest,
> org.apache.log4j,
> Complete stack trace is : [java] Exception in thread "WorkbenchTestable"
> leLoader.java:405)
> leLoader.java:393)
> leLoader.java:405)
> leLoader.java:393)
Re: Troubles with "java.lang.NoClassDefFoundError: junit/framework/TestListener" in headle [message #551924 is a reply to message #551744] Tue, 10 August 2010 04:10 Go to previous messageGo to next message
Hi Ketan,
Thanks for the quick reply! I checked all the steps given in the wiki.
Everything was as per the trouble shooting tips mentioned there, except : I have both org.eclipse.jdt.junit4.runtime_1.1.0.v20090513-2000.jar and org.junit4_4.5.0.v20090423 in my eclipse plugins directory. Removing the jdt junit runtime plugin also doesn't help.
I face the above exception only when I include the formatter:
formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJU nitResultFormatter,${eclipse-home}/${classname}.xml
formatter=org.apache.tools.ant.taskdefs.optional.junit.Plain JUnitResultFormatter.
I am able to launch workbench and see my tests running if I dont have this formatter inside the library xml. It is just that it generates an empty report.
Why doesn't the formatter gets loaded when the org.eclipse.equinox.launcher is loaded?
Below is my ant script in library.xml to launch the workbench:
<java fork="true" dir="." timeout="${timeout}" jvm="${jvm}" logError="true" classname="org.eclipse.core.launcher.Main" output="${junit-report-output}/${classname}.txt">
<classpath>
<fileset dir="${eclipse-home}/plugins">
<include name="org.eclipse.equinox.launcher_*.jar" />
<!-- <include name="junit.jar" />
<include name="org.hamcrest.core_*.jar"/> -->
</fileset>
</classpath>
<arg line="${launcher-arg-line}" />
<jvmarg line="${jvm-arg-line}" />
<sysproperty key="PLUGIN_PATH" value="${plugin-path}" />
</java>
I tried passing the junit.jar to the classpath as well, but in vain.
Please let me know how to avoid the exception and generate report successfully.
Thanks in anticipation,
Tilak
Re: Troubles with "java.lang.NoClassDefFoundError: junit/framework/TestListener" in headle [message #552053 is a reply to message #551924] Tue, 10 August 2010 11:52 Go to previous messageGo to next message
Unfortunately you're in a grey area where it's hard for anyone to
diagnose any issue for you over email.
I just put another wiki page together for you to diagnose what could be
wrong http://wiki.eclipse.org/SWTBot/OSGi_Console
Let us know how it goes.
Ketan
On 8/10/10 1:10 AM, Tilak wrote:
> Hi Ketan,
> empty report.
> <classpath>
> </fileset>
> </classpath>
> </java>
> successfully.
> Tilak
Re: Troubles with "java.lang.NoClassDefFoundError: junit/framework/TestListener" in headle [message #552227 is a reply to message #552053] Wed, 11 August 2010 07:17 Go to previous message
Hi Ketan,
After eclipse is launched through ant, in the osgi prompt I gave the following commands:
osgi> ss org.eclipse.swtbot
Framework is launched.
id State Bundle
412 RESOLVED org.eclipse.swtbot.ant.optional.junit4_2.0.0.595-dev-e35
Master=114
413 RESOLVED org.eclipse.swtbot.eclipse.core_2.0.0.595-dev-e35
414 RESOLVED org.eclipse.swtbot.eclipse.finder_2.0.0.595-dev-e35
415 RESOLVED org.eclipse.swtbot.eclipse.gef.finder_2.0.0.595-dev-e35
416 RESOLVED org.eclipse.swtbot.eclipse.junit4.headless_2.0.0.595-dev-e35
417 RESOLVED org.eclipse.swtbot.eclipse.spy_2.0.0.595-dev-e35
418 RESOLVED org.eclipse.swtbot.eclipse.ui_2.0.0.595-dev-e35
419 RESOLVED org.eclipse.swtbot.go_2.0.0.595-dev-e35
420 RESOLVED org.eclipse.swtbot.junit4_x_2.0.0.595-dev-e35
421 RESOLVED org.eclipse.swtbot.swt.finder_2.0.0.595-dev-e35
osgi> ProviderTracker: New service detected...
ProviderTracker: Added service org.eclipse.persistence.jpa.osgi.PersistenceProviderOSGi
osgi> ss ant
id State Bundle
114 ACTIVE org.apache.ant_1.7.1.v20090120-1145
Fragments=412
133 ACTIVE org.eclipse.ant.core_3.2.100.v20090520
134 RESOLVED org.eclipse.ant.ui_3.4.1.v20090901_r351
180 ACTIVE org.eclipse.emf.ant_2.4.0.v200906151043
402 ACTIVE org.eclipse.persistence.antlr_1.1.2.v20090612-r4475
Master=114
osgi> diag org.eclipse.swtbot.swt.finder
reference:file:/C:/SonicInstall8.1_142/Workbench8.1/eclipse/ plugins/org.eclipse.swtbot.swt.finder_2.0.0.595-dev-e35.jar [421]
No unresolved constraints.
My scenario is:
Our product has lot of eclipse plugins, out of which I have written a test plugin for one of them.
From the ant script I pass the eclipse-home = <eclipse under product>.
I made sure that this eclipse has all the required swtbot plugins and my new test plugin.
Now when run my ant script for swtbot with the formatter, I see the exception: "Exception in thread "WorkbenchTestable" java.lang.NoClassDefFoundError: junit/framework/TestListener".
I saw the code inside EclipseTestRunner:
EclipseTestRunner.class.getClassLoader().loadClass(classname ); where the classname is the formatter's classname.
How to have the junit.framework.TestListener to be loaded in the same class loader as EclipseTestRunner?
As I have mentioned earlier, I am able to run the swtbot tests through ant. But, once I give the formatter, I see this exception.
Please help me out as I am stuck badly.
Tilak
Previous Topic:SWTBot and active Eclipse window
Next Topic:Contract Job Offered - SWTBOT Tester/Developer
Current Time: Wed Jul 23 07:31:04 EDT 2025
Powered by FUDForum. Page generated in 0.07567 seconds
