Home » Eclipse Projects » SWTBot » Getting @ to work with a UK keyboard(How do I define the active keyboard to SWTBot)
Getting @ to work with a UK keyboard [message #545429] |
Wed, 07 July 2010 13:59  |
Hello
I've just startes using this - it's great!
But... I met a brickwall when I tried to find a Tree entry with an '@' in it (to be precise the tree item's label was "eliza doolittle (eliza@localhost)".
I tried all sorts of ways to get this selected so I could click it, without success. Then I remembered that on a US keyboard, the '@' sign is upper case 2, whereas on mine it is upper case <single quote>.
When I changed the XP keyboard setting to US, the test worked.
Searches to see how I fix this, keep leading me to the wiki's page on keyboard layouts at: http://wiki.eclipse.org/SWTBot/Keyboard_Layouts
The problem is, that after reading it, and in spite of (or is it, because of) 40 years in IT, I have absolutely no idea what I should do!
To me, this page is aimed at people who already know a lot about SWTBot, whereas this problem is one that all people outside the US will meet early on. Apologies for being critical (I'm not ungrateful), but one thing I have l learned is that if I find something to be a problem, I am probably not the only one.
From what I have read, I can:
- set a system property "org.eclipse.swtbot.keyboard.strategy", but, what to and where?
- set a variable SWTBotPreferences#KEYBOARD_STRATEGY, again, what to and where?
- use a .keyboard file - where is it, I can't find one in the eclipse plugins.
The problem I'm having is that as there are no examples of using / creating a non-US keyboard definition, I have no idea how to proceed. In my case, most of the keys are the same, it's just a few that I need to overrride, in effect.
If anyone can point me to the answer, or provide a simple example, I'd imagine it would help me and others a lot.
Regards, John
Re: Getting @ to work with a UK keyboard [message #545775 is a reply to message #545429] |
Fri, 09 July 2010 00:38   |
Hi John,
The wiki page does seem a bit confusing, and I'm fixing the page as I
write this email, it should be fixed by the time you read this email :)
Tree selection is orthogonal to keyboard layouts, and keyboard layouts
are used only when you type something using the #typeText API.
Tree expansions/selections are a bit confusing to first time users. The
correct way to select the tree item is:
tree.expandNode("node 1").expandNode("node 1.1").select("node 1.1.1")
This will set the tree selection to "node 1.1.1".
Ketan
http://ketan.padegaonkar.name | http://eclipse.org/swtbot | @ketanpkr
On 7/7/10 10:59 AM, John Ormerod wrote:
> Hello
> mailto:'@' in it (to be precise the tree item's label was "eliza
> doolittle (mailto:eliza@localhost)".
> without success. Then I remembered that on a US keyboard, the mailto:'@'
> what to and where?
> where?
> plugins.
> Regards, John
Re: Getting @ to work with a UK keyboard [message #545915 is a reply to message #545908] |
Fri, 09 July 2010 11:21   |
On 7/9/10 8:04 AM, John Ormerod wrote:
> After I had changed my keyboard to US, selection started working.
> However, in one of those strange IT things, after I restored the
> keyboard to UK, selection continued to work! As they say, nothing breeds
> success like successs.
Let us know if you're able to reproduce it again.
> I'll see if I can create a UK .keyboard file following your updated
> instructions in the wiki - I assume its code would be EN-GB.
I think it might have to be EN_GB. If you do not set any value to the
SWTBotPreferences.KEYBOARD_LAYOUT, the error message will tell you what
file it expected.
> The link to 'SWTBot/Contributing SWTBot source repository' for the
> KeyboardLayoutGenerator source, results in an empty editor with a msg
> that the page doesn't exist - I guess I might be getting ahead of you.
The link was incorrect(http://wiki.eclipse.org/SWTBot/Contributing),
I've fixed it.
> I have created a version by pasting the code - it can't resolve the Keys
> class in the typeKeystrokes() method.
> So, I am perched here for the moment.
All the classes are in the same folder as the KeyboardLayoutGenerator
class(http://goo.gl/Chzz).
Ketan
Re: Getting @ to work with a UK keyboard [message #546252 is a reply to message #545915] |
Mon, 12 July 2010 05:59  |
Hi Ketan
Not sure if I will be able to recreate the 'learned behaviour', that I think I observed. Could be finger trouble, as I thought it had come back. Then spotted that the app's login had not remembered the previous userid. Correcting that, restored normal behaviour.
I have now followed the wiki instructions and generated a EN_GB.keyboard file - which is the one that SWTBot tells me it can't find as a default.
I now have a problem understanding where to put it, so it can be found, and/or how to tell SWTBot where it is.
I copied the EN_GB.keyboard file to the root of the test project. I provided a "-Dorg.eclipse.swtbot.keyboard.layout" parameter, and guessed at "/EN_GB.keyboard". That didn't work. Then I spotted the actual exception message said it couldn't find "/EN_GB.keyboard.keyboard". So, I tried using "/EN_GB", but it still can't find the "EN_GB.keyboard file".
The documentation refers to "/foo/bar/..." stuff. I have a psychological block when I see this as I usually find it confusing! (foo and bar appeared out of nowhere when I took my first steps in Java in the late 90s, and have never got comfortable with its usage).
Once I am past this step and all is working, I will create a description in "layman's" language, which might help others who are new to all this.
Regards, John
Current Time: Sun Jul 20 20:44:30 EDT 2025
Powered by FUDForum. Page generated in 0.03765 seconds
