Home » Eclipse Projects » SWTBot » How to right-click in a column of a table  () 1 Vote
How to right-click in a column of a table [message #544793] Mon, 05 July 2010 10:24 Go to next message
Hi all,
I'm having some problems with tables inside editors.
I would like to right-click a whole column, like this image below.
http://www.students.ic.unicamp.br/~ra064940/example4.JPG
I've looked over forums and tried a lot of samples, but I just can't access the context menu of the table.
Someone can help me, please?
Victor
[Updated on: Mon, 05 July 2010 10:30] by Moderator
Re: How to right-click in a column of a table [message #544834 is a reply to message #544793] Mon, 05 July 2010 12:20 Go to previous messageGo to next message
On 7/5/10 7:24 AM, Victor wrote:
> Hi All,
> Someone can Help me, please?
> Victor
Are you looking for the context menu of a table or a table column ?
All widgets support a #contextMenu() method to access a menu item. To
access a table column you need to use:
bot.table().header("column heading").contextMenu("selection").click();
Ketan
http://ketan.padegaonkar.name | http://eclipse.org/swtbot
Re: How to right-click in a column of a table [message #544846 is a reply to message #544834] Mon, 05 July 2010 13:13 Go to previous messageGo to next message
Hi Ketan,
First, thanks for the reply.
I'm trying to access the context menu of the column values.
So I did:
bot.table().header("values").contextMenu("Clone").click();
I recieve an WidgetNotFounfException when I execute the contextMenu() method. If I execute:
bot.table().header("values").toString();
It works fine.
So, the problem is the contextMenu().
Is there any way to access the right-click menu, without using the contextMenu() method? Or how can I use the contextMenu() in the right way?
Thanks again.
Victor
Re: How to right-click in a column of a table [message #650236 is a reply to message #544793] Sun, 23 January 2011 10:21 Go to previous message
I want to know how to resolve this problem too.
Thank you~
Previous Topic:how to get screenshots, logger messages into results/${class-name}.html file?
Next Topic:SWTBotGefConnectionEditPart Move
Current Time: Sun Jul 27 11:48:38 EDT 2025
Powered by FUDForum. Page generated in 0.03497 seconds
