Home » Eclipse Projects » SWTBot » SWTBOT record and playback(using the record and playback function)
SWTBOT record and playback [message #542550] Fri, 25 June 2010 06:06 Go to next message
Is there anywhere a tutorial how the record and playback function from SWTBOT can be used.
Re: SWTBOT record and playback [message #543071 is a reply to message #542550] Mon, 28 June 2010 06:46 Go to previous messageGo to next message
I read "SWTBot can record and playback tests... " and I am wondering where I can find this function and how it is yoused.
Re: SWTBOT record and playback [message #543074 is a reply to message #542550] Mon, 28 June 2010 06:57 Go to previous messageGo to next message
Ok I have found this
"There is no recorder anymore. The existing recorder[1] was generating
broken code as it was never updated for version 2.0.
The recorder was recently removed from trunk and moved off to it's own
branch[2] for any future work that may happen on it.
[1] - http://swtbot.sourceforge.net/experimental/recorder.html
[2] -
http://dev.eclipse.org/svnroot/technology/org.eclipse.swtbot /branches/recorder-spike/
-- Ketan"
Now is my question if and when there will be a update for the record and playback to version 2.0
Darius
Re: SWTBOT record and playback [message #543133 is a reply to message #543074] Mon, 28 June 2010 09:39 Go to previous messageGo to next message
Maybe, if someone has the time to implement the entire recorder and make
sure it stays up-to date.
> Regards
> Darius
Ketan
http://ketan.padegaonkar.name | http://eclipse.org/swtbot
Re: SWTBOT record and playback [message #543297 is a reply to message #543133] Mon, 28 June 2010 21:16 Go to previous messageGo to next message
Its a pity to hear this. My company was looking for a RCP testing tool with directly this function. I hope this function will be available some day. Is there anywhere a website to monitor the porgress of the SWTBot project where I can see which tools will be released in next time.
Darius
Re: SWTBOT record and playback [message #543366 is a reply to message #543297] Tue, 29 June 2010 04:34 Go to previous message
Hi Darius,
If you are looking for a RCP testing tool with record and playback feature, I am pretty sure you can
find a commercial tool which support this. Like other open-source projects, if you really want a feature, you could contribute it
or fund someone/a company to realize it. Otherwise you could wait someone else contribute it, but in this case you should not expect
to have mandatorily a roadmap including this feature.
Mariot
> Regards
> Darius
Previous Topic:Multiviews
Next Topic:How to access a List
Current Time: Sun Jul 27 11:22:18 EDT 2025
Powered by FUDForum. Page generated in 0.04613 seconds
