SWTBot and log4j 1.2.15 [message #531227] |
Tue, 04 May 2010 05:02  |
Hello... I'm new to SWTBot and unfortunately I've been having a lot of problems trying to get it to work with my RCP application. I'm working under Eclipse 3.5 and my application has a dependency to log4j 1.2.15 which is what seems to be causing the problems. I presume that is where the problem lies because when I set up the Run Configuration to use log4j 1.2.13, the unit test runs but fails because instead of loading the actual application I want to test, it opens a resource window. However, if I use the right version of log4j for my application, this is loaded but the unit test is unable to execute and throws a "No Classloader found for plug-in org.eclipsecon.swtbot.example":
Exception in thread "WorkbenchTestable" java.lang.IllegalArgumentException: No Classloader found for plug-in org.eclipsecon.swtbot.example
at org.eclipse.swtbot.eclipse.core.RemotePluginTestRunner.getCl assLoader(RemotePluginTestRunner.java:79)
at org.eclipse.swtbot.eclipse.core.RemotePluginTestRunner.getTe stClassLoader(RemotePluginTestRunner.java:73)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.loadC lass(RemoteTestRunner.java:693)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.loadC lasses(RemoteTestRunner.java:429)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:452)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:390)
at org.eclipse.swtbot.eclipse.core.RemotePluginTestRunner.main( RemotePluginTestRunner.java:64)
at org.eclipse.swtbot.eclipse.core.UITestApplication.runTests(U ITestApplication.java:117)
at org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.java:71)
at java.lang.Thread.run(Thread.java:619)
Has anyone else had this kind of problem before or knows how this could be resolved?
Thank you.
Re: SWTBot and log4j 1.2.15 [message #537324 is a reply to message #531227] |
Tue, 01 June 2010 19:57  |
Also it seems that swtbot has a dep on org.apache.log4j=1.2.13, it
should instead be >=1.2.13. Could you open a bug ?
Ketan
http://ketan.padegaonkar.name | http://eclipse.org/swtbot
> be resolved?
> Thank you.
FUDForum. Page generated in 0.28706 seconds
