Home » Eclipse Projects » SWTBot » RCP with SWTBOT(RCP with SWTBOT)
RCP with SWTBOT [message #529734] Mon, 26 April 2010 23:11 Go to next message
HI All,
I'm new to start with SWTBot. I have installed eclipse galileo and org.eclipse.swtbot.eclipse-2.0.0.536-dev-e34. I have never used it before. I have to test one RCP based Application. Please let me know how to start it.
let us consider the sample Hello RCP application in RCP.
how to test that Hello RCP application.
Please help me and let me know the way to test it.
Thanks and Regards,
Yogeshkumar.S
Re: RCP with SWTBOT [message #529736 is a reply to message #529734] Mon, 26 April 2010 23:21 Go to previous messageGo to next message
yogeshkumar wrote on Mon, 26 April 2010 23:11
HI All,
Thanks and Regards,
Yogeshkumar.S
Re: RCP with SWTBOT [message #529884 is a reply to message #529734] Tue, 27 April 2010 10:21 Go to previous messageGo to next message
Geez, calm down. It's not by spamming the newsgroup in the middle of
night (for most users) that you'll get an answer.....
You can start with the User guide [1], which contains two five minutes
screencast for starters.
[1] http://wiki.eclipse.org/SWTBot/UsersGuide
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
Re: RCP with SWTBOT [message #530251 is a reply to message #529884] Thu, 29 April 2010 02:33 Go to previous messageGo to next message
Dear Pascal,
Thank you for the reply.
I have followed the userguide mentioned by you.
I am struggling in one point ,(ie) they run the testcase against SWTBot Test in Run configuration,
I dont have the SWTBot Test in my Run configurations.
Please let me know how to configure that.
Please help me in fixing the issue.
Thanks and Regards,
Yogeshkumar.S
Re: RCP with SWTBOT [message #530277 is a reply to message #529734] Thu, 29 April 2010 04:09 Go to previous messageGo to next message
There is also a tutorial about SWTBot specifically working with the RCP mail example app here:
http://richardadams606blog.blogspot.com/
which also covers running as an ant task as well
Richard
Re: RCP with SWTBOT [message #530285 is a reply to message #530277] Thu, 29 April 2010 04:41 Go to previous messageGo to next message
Dear Richard Adams,
Thanks a lot for your reply, very kind of you..
I have followed your Tutorial mentioned below:
http://richardadams606blog.blogspot.com/2010_04_01_archive.h tml
I am facing some problem while execution of the same.
Step 1: working fine, I'm able to launch the application.
Step 2: Since i want to test frrom stand alone,I left the same(please let me whether i am correct).
Step 3 : I have followed all the process of step 3,If i want to run against 'mail.product' its working fine(sorry but i didnt understand how its testing and what its testing,it simply loads the product), else if I am running the same class in junit it says widget not found.
Step 4: I left..
Please help me in fixing this issues.
Thanks and Regards,
Yogeshkumar.S
Re: RCP with SWTBOT [message #530312 is a reply to message #529734] Thu, 29 April 2010 06:25 Go to previous messageGo to next message
Hi Yogeshkumar,
I've updated step 3 on the tutorial by adding screenshots on how to set up the launch configuration to run the tests.
Richard
Re: RCP with SWTBOT [message #530333 is a reply to message #530312] Thu, 29 April 2010 08:13 Go to previous messageGo to next message
Dear Richards,
Thanks for your support.
I am struggling in one point ,(ie) you run the testcase against SWTBot Test in Run configuration,
Thanks and Regards,
Yogeshkumar.S
Re: RCP with SWTBOT [message #530360 is a reply to message #530333] Thu, 29 April 2010 09:42 Go to previous messageGo to next message
Did you download[1] and install SWTBot in your IDE from the download
manager[2] ?
Ketan
ketan.padegaonkar.name | eclipse.org/swtbot
[1] - http://eclipse.org/swtbot/downloads.php
[2] -
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.user/tasks/tasks-124.htm
On 4/29/10 5:13 AM, yogeshkumar wrote:
> Dear Richards,
> Thanks and Regards,
> Yogeshkumar.S
Re: RCP with SWTBOT [message #530537 is a reply to message #529734] Fri, 30 April 2010 01:07 Go to previous messageGo to next message
Dear Ketan,
I have installed softwares from
http://download.eclipse.org/technology/swtbot/ganymede/dev-b uild/update-site
I have installed
SWTBot for Eclipse Testing
SWTBot for SWT Testing
but still i am not able to see the SWTBot Test in my Run configurations.
Thanks and Regards,
Yogeshkumar.S
Re: RCP with SWTBOT [message #530538 is a reply to message #530537] Fri, 30 April 2010 01:17 Go to previous messageGo to next message
Yogesh,
You need to install SWTBot IDE Support for the run configuration to appear.
See http://swtbot.org/doc/ for more information. This documentation is
still work in progress so let me know if I'm missing something.
Ketan
http://ketan.padegaonkar.name | http://eclipse.org/swtbot
On 4/29/10 10:07 PM, yogeshkumar wrote:
> Dear Ketan,
> I have installed
> Thanks and Regards,
> Yogeshkumar.S
Re: RCP with SWTBOT [message #530540 is a reply to message #530538] Fri, 30 April 2010 01:56 Go to previous messageGo to next message
Dear Ketan,
Thanks a lot for your support.
When i tried to install
SWTBOT IDE support
I'm facing error like
An error occurred during the org.eclipse.equinox.internal.provisional.p2.engine.phases.Ch eckTrust phase.
session context was:(profile=PlatformProfile, phase=org.eclipse.equinox.internal.provisional.p2.engine.pha ses.CheckTrust, operand=, action=).
Cannot connect to keystore.
Uninitialized keystore
Please help me in fixing this issue.
Thanks and Regards,
Yogeshkumar.S
Re: RCP with SWTBOT [message #530541 is a reply to message #530538] Fri, 30 April 2010 01:57 Go to previous messageGo to next message
Dear Ketan,
SWTBOT IDE support
Thanks and Regards,
Yogeshkumar.S
Re: RCP with SWTBOT [message #530546 is a reply to message #530540] Fri, 30 April 2010 02:11 Go to previous messageGo to next message
Chances are you're using a non-sun JDK. Try installing java 1.6 from
http://java.sun.com/javase/downloads/widget/jdk6.jsp
Could you also provide the output of running 'java -version' on the
command line ?
Also see for more information
http://wiki.eclipse.org/IRC_FAQ#When_I_try_to_install_a_plug -in.2C_I_get_a_.22Cannot_connect_to_keystore..22_error.2C_wh at_should_I_do.3F
Ketan
On 4/29/10 10:56 PM, yogeshkumar wrote:
> Dear Ketan,
> SWTBOT IDE support
> phase.
> Thanks and Regards,
> Yogeshkumar.S
Re: RCP with SWTBOT [message #530559 is a reply to message #530546] Fri, 30 April 2010 03:46 Go to previous messageGo to next message
Dear Ketan,
please find my output for the command java -version
java version "1.6.0_13"
Java(TM) SE Runtime Environment (build 1.6.0_13-b03)
Java HotSpot(TM) Client VM (build 11.3-b02, mixed mode)
please also find the configuration details in my eclipse
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\tptp.runtime.allInOne.win32.win32.x86-TPT P-4.6.2\eclipse\plugins/org.eclipse.equinox.launcher_1.0.201 .R35x_v20090715.jar
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jre6\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre6\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre6
java.io.tmpdir=C:\DOCUME~1\syogesh\LOCALS~1\Temp\
java.library.path=C:\tptp.runtime.allInOne.win32.win32.x86-T PTP-4.6.2\eclipse;.;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\syste m32;C:\WINDOWS;C:/Program Files/Java/jre6/bin/client;C:/Program Files/Java/jre6/bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOW S\System32\Wbem;C:\Documents and Settings\All Users\Application Data\lotus\notes\data\;C:\WINDOWS\system32\WindowsPowerShell \v1.0;C:\Program Files\Java\jdk1.6.0_02\bin;C:\DUKE CODE AND DOCUMENT\apache-ant-1.8.0-bin\apache-ant-1.8.0\bin;
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_13-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_13
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=11.3-b02
Thanks and Regards,
Yogeshkumar.S
[Updated on: Fri, 30 April 2010 03:53] by Moderator
Re: RCP with SWTBOT [message #530576 is a reply to message #530559] Fri, 30 April 2010 04:29 Go to previous messageGo to next message
Dear Ketan,
I am able to install the SWTBOT Ide
when i try to run the file against SWTBOT test, Its throwing error like
An internal error occurred during: "Launching New_configuration".
org.eclipse.pde.internal.ui.launcher.LaunchPluginValidator.g etPluginsToRun(Lorg/eclipse/debug/core/ILaunchConfiguration; )Ljava/util/Map;
Please help me in resolving this.
Thanks and Regards,
Yoegshkumar.S
icon14.gif  Re: RCP with SWTBOT [message #530591 is a reply to message #530576] Fri, 30 April 2010 05:27 Go to previous messageGo to next message
Hi Richards/ketan,
Thanks a lot for your support,
My first sample with RCP mail has worked.
Please let me know how to take screenshot for each testcase.
Thanks and Regards,
Yogeshkumar.S
Re: RCP with SWTBOT [message #530593 is a reply to message #530576] Fri, 30 April 2010 05:15 Go to previous messageGo to next message
It looks like the version of PDE you have in your Eclipse is not compatible with this version of SWTBot.
Which version of PDE do you have?
yogeshkumar a écrit :
> Dear Ketan,
> )Ljava/util/Map;
> Thanks and Regards,
> Yoegshkumar.S
Mickael Istria - BonitaSoft S.A.
http://www.bonitasoft.com/products/downloads.php
Re: RCP with SWTBOT [message #530687 is a reply to message #530591] Fri, 30 April 2010 10:13 Go to previous messageGo to next message
Hey,
Great to hear that things worked for you.
Would you like to share what you had to do to make it work so someone
else who has similar problems can find the solution ?
I've updated the same doc with info on screenshots.
-- Ketan
On 4/30/10 2:27 AM, yogeshkumar wrote:
> Hi Richards/ketan,
> Thanks and Regards,
> Yogeshkumar.S
Re: RCP with SWTBOT [message #530934 is a reply to message #530687] Mon, 03 May 2010 01:54 Go to previous messageGo to next message
Dear Ketan,
My VM was pointing to some other version of JRE, So i got the error mentioned below.
> )Ljava/util/Map;
To fix the error,
I made the configuration to vm to point it to the corresponding JDK:javaw.exe.
I had a look in to the document mentioned below
Sorry , I was not able to find the process for taking the screenshot for the testcase,
Please help me in taking the screenshot for the testcase.
Thanks and Regards,
Yogeshkumar.S
Re: RCP with SWTBOT [message #531052 is a reply to message #530934] Mon, 03 May 2010 10:10 Go to previous messageGo to next message
http://swtbot.org/doc/#_investigating_test_failures
Ketan
On 5/2/10 10:54 PM, yogeshkumar wrote:
> Dear Ketan,
> mentioned below.
>> )Ljava/util/Map;
> To fix the error,
> JDK:javaw.exe.
> the testcase,
> Thanks and Regards,
> Yogeshkumar.S
Re: RCP with SWTBOT [message #531234 is a reply to message #531052] Tue, 04 May 2010 05:22 Go to previous messageGo to next message
Dear Ketan,
I follow the same
@RunWith(SWTBotJunit4ClassRunner.class)
Sorry, But I was not able to see the screenshot folder in my project.
Thanks and Regards,
Yogeshkumar.S
Re: RCP with SWTBOT [message #531259 is a reply to message #531234] Tue, 04 May 2010 06:58 Go to previous message
I am facing a new problem.
I am using Eclipse Ganymade and I have installed SWTBOT from the below mentioned site.
http://download.eclipse.org/technology/swtbot/ganymede/dev-b uild/update-site/
The problem I am facing here is:
I have created a new plugin project,In MANIFEST.MF, in dependency page,If i try to add swtbot configuration,
It was not showing any SWTBOT configuration.
I tried searching using *swtbot
What might be the problem.
Thanks and Regards,
Yogeshkumar.S
Previous Topic:Using SWT Bot with GMF - GEF
Next Topic:Headless junit4 runner can't find my plug-in
Current Time: Mon Jul 21 00:00:58 EDT 2025
Powered by FUDForum. Page generated in 0.27457 seconds
