Home » Eclipse Projects » Standard Widget Toolkit (SWT) » INSTALLING SWT ON ECLIPSE UNDER WINDOWS(ERROR WHEN IMPORTING SWT ZIP)
INSTALLING SWT ON ECLIPSE UNDER WINDOWS [message #529554] Mon, 26 April 2010 07:23 Go to next message
Hello world!
I was importing the SWT zip file when Eclipse told me: "No projects are found to import"
What's wrong?
Eclipse version: Eclipse IDE for Java Developers
Version: 1.2.2.20100216-1730
Build id: 20100218-1602
SWT .zip file version: swt-3.6M6-win32-win32-x86
Thanks world!
Wink
Re: INSTALLING SWT ON ECLIPSE UNDER WINDOWS [message #529571 is a reply to message #529554] Mon, 26 April 2010 08:47 Go to previous messageGo to next message
> found to import"
It's not really clear to me what you tried. Could you please explain
in more detail, what you were doing?
- Daniel
Re: INSTALLING SWT ON ECLIPSE UNDER WINDOWS [message #529576 is a reply to message #529571] Mon, 26 April 2010 09:17 Go to previous messageGo to next message
Once i downloaded the .zip file from SWT project webpage, I opened Eclipse and I tried to import it into my workspace.
I clicked in the "import..." option.
I selected the approppiate .zip file.
At this point, Eclipse showed the message: "No projects are found to import".
What did I do wrong?
Thanks!
BRs,
Abelardo.
Re: INSTALLING SWT ON ECLIPSE UNDER WINDOWS [message #529577 is a reply to message #529554] Mon, 26 April 2010 09:23 Go to previous messageGo to next message
inside the zip file there is an swt.jar file. it is tha file that you need to add to your buil dpath if you want to use SWT
Re: INSTALLING SWT ON ECLIPSE UNDER WINDOWS [message #529579 is a reply to message #529576] Mon, 26 April 2010 09:19 Go to previous messageGo to next message
The ZIP you downloaded can not be imported. You should extract the .zip
and include the jars to your build path.
Tom
Am 26.04.10 15:17, schrieb Abelardo:
> import".
> Thanks!
> BRs,
> Abelardo.
Re: INSTALLING SWT ON ECLIPSE UNDER WINDOWS [message #529582 is a reply to message #529577] Mon, 26 April 2010 09:34 Go to previous messageGo to next message
Thanks Bernd van Velsen.
Finally, I did it you have commented.
Then, this message appeared:
Snippet164 cannot be resolved to a type
at this line of code:
Image image = new Image (display, Snippet164.class.getResourceAsStream ("eclipse.png"));
(I added both "swt-debug.jar" and "swt.jar" files)
Brs,
Abelardo.
Re: INSTALLING SWT ON ECLIPSE UNDER WINDOWS [message #529595 is a reply to message #529579] Mon, 26 April 2010 09:57 Go to previous messageGo to next message
Hi Tom,
According with the instructions showed at this page:
http://www.eclipse.org/swt/eclipse.php
the .zip downloaded from this page:
http://www.eclipse.org/downloads/download.php?file=/eclipse/ downloads/drops/S-3.6M6-201003121448/swt-3.6M6-win32-win32-x 86.zip
(for windows, obviously)
can be imported by using this option from Eclipse.
Brs,
Abelardo.
Re: INSTALLING SWT ON ECLIPSE UNDER WINDOWS [message #530115 is a reply to message #529582] Wed, 28 April 2010 10:22 Go to previous messageGo to next message
Thanks for pointing this out, these instructions are no longer valid, I've
logged https://bugs.eclipse.org/bugs/show_bug.cgi?id=310826 .
Snippet164 is not in an swt jar. I notice that it's referencing external
file "eclipse.png", so your best bet is probably to retrieve the
org.eclipse.swt.snippets project from CVS. For instructions on connecting
to eclipse's CVS repository see the first step of
http://www.eclipse.org/swt/cvs.php .
Grant
Re: INSTALLING SWT ON ECLIPSE UNDER WINDOWS [message #530297 is a reply to message #530115] Thu, 29 April 2010 05:12 Go to previous messageGo to next message
Thank you, Grant!
Brs,
Abelardo.
Re: INSTALLING SWT ON ECLIPSE UNDER WINDOWS [message #543796 is a reply to message #529554] Wed, 30 June 2010 11:08 Go to previous messageGo to next message
use stable (windows) build
3.5.2 Final Release - 26 February 2010
It works.
to developers: please change swt download address in eclipse tutorial, untill 3.6 package is fixed. Eclipse patch maybe?
http://dbojan.co.cc
[Updated on: Wed, 30 June 2010 14:49] by Moderator
Re: INSTALLING SWT ON ECLIPSE UNDER WINDOWS [message #544911 is a reply to message #529554] Mon, 05 July 2010 23:55 Go to previous messageGo to next message
Thanks for Round 1 of help -- finding the SWT Binary and Source page. (updating the tutorial would *really* help.)
Now for round 2 -- even specifying the swt.jar far STILL does not allow me to import the SWT stuff. I still get the "No projects are found to import" error. Sad
So now what do I do?
-- Attila
Re: INSTALLING SWT ON ECLIPSE UNDER WINDOWS [message #547449 is a reply to message #530115] Fri, 16 July 2010 16:50 Go to previous message
Why take away the import as project way of including SWT into java projects. I have several workspaces with multiple utility projects. When I upgrade Eclipse being able to delete the old SWT project and import the new one into my workspace works really well. With one operation all my projects get updated.
I personally don't really want to go back to setting up macros to point to SWT .jar files and then add them by hand to each of my projects.
Is it possible to change this decision? Is there something we all gain from doing it this new way that I am missing?
Ian
[quote title=Grant Gayed wrote on Wed, 28 April 2010 10:22]> According with the instructions showed at this page:
Previous Topic:Working with javascript on SWT browser yeild the different result from IE on Windows
Next Topic:Re: Integrating C++ GUI toolkit into RCP application?
Current Time: Thu Jul 24 22:01:52 EDT 2025
Powered by FUDForum. Page generated in 0.30993 seconds
