Home » Eclipse Projects » SWTBot » SWTBot typeText is getting a java.lang.ExceptionInitializerError
SWTBot typeText is getting a java.lang.ExceptionInitializerError [message #528194] Mon, 19 April 2010 12:25 Go to next message
I am trying to use SWTBot on my laptop which has F-12 installed. I am running a test which runs fine on my F-12 desktop with SWTBot, but it fails in trying to do the SWTBotText.typeText() method with the exception above in org.eclipse.swtbot.swt.finder.keyboard.Keyboard.typeText.
Why is this happening? The release of SWTBot on my laptop is later than the one on the desktop (2.0.0.536-dev-e35 vs 2.0.0.512-dev-e35). Both are x86 platforms.
Re: SWTBot typeText is getting a java.lang.ExceptionInitializerError [message #528201 is a reply to message #528194] Mon, 19 April 2010 12:39 Go to previous messageGo to next message
Hi Jeff,
Could you provide a stack trace so we can figure out where and why it is
happening ?
– Ketan
> exception above in
> are x86 platforms.
Re: SWTBot typeText is getting a java.lang.ExceptionInitializerError [message #528224 is a reply to message #528201] Mon, 19 April 2010 14:08 Go to previous messageGo to next message
Appears not to like EN_CA keyboard layout. My keyboard preferences show USA and I also did a setxkbmap us which doesn't help.
java.lang.ExceptionInInitializerError
at org.eclipse.swtbot.swt.finder.keyboard.Keyboard.typeCharacte r(Keyboard.java:100)
at org.eclipse.swtbot.swt.finder.keyboard.Keyboard.typeText(Key board.java:89)
at org.eclipse.swtbot.swt.finder.widgets.SWTBotText.typeText(SW TBotText.java:92)
at org.eclipse.swtbot.swt.finder.widgets.SWTBotText.typeText(SW TBotText.java:78)
at org.eclipse.linuxtools.cdt.autotools.ui.tests.SetConfigurati onParameter.canSetConfigParm(SetConfigurationParameter.java: 105)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall( FrameworkMethod.java:44)
at org.junit.internal.runners.model.ReflectiveCallable.run(Refl ectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(Fr ameworkMethod.java:41)
at org.junit.internal.runners.statements.InvokeMethod.evaluate( InvokeMethod.java:20)
at org.junit.internal.runners.statements.RunBefores.evaluate(Ru nBefores.java:28)
at org.junit.internal.runners.statements.RunAfters.evaluate(Run Afters.java:31)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit 4ClassRunner.java:73)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit 4ClassRunner.java:46)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java :180)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java: 41)
at org.junit.runners.ParentRunner$1.evaluate(ParentRunner.java: 173)
at org.junit.runners.ParentRunner.run(ParentRunner.java:220)
at org.eclipse.swtbot.swt.finder.junit.SWTBotJunit4ClassRunner. run(SWTBotJunit4ClassRunner.java:54)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.r un(JUnit4TestReference.java:46)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:467)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:390)
at org.eclipse.swtbot.eclipse.core.RemotePluginTestRunner.main( RemotePluginTestRunner.java:64)
at org.eclipse.swtbot.eclipse.core.UITestApplication.runTests(U ITestApplication.java:117)
at org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.java:71)
at java.lang.Thread.run(Thread.java:636)
Caused by: java.lang.IllegalArgumentException: keyboard layout EN_CA not available.
at org.eclipse.swtbot.swt.finder.keyboard.KeyboardLayout.getKey boardLayout(KeyboardLayout.java:89)
at org.eclipse.swtbot.swt.finder.keyboard.KeyboardLayout.getDef aultKeyboardLayout(KeyboardLayout.java:75)
at org.eclipse.swtbot.swt.finder.keyboard.Keystrokes.<clinit>(Keystrokes.java:110)
... 33 more
Re: SWTBot typeText is getting a java.lang.ExceptionInitializerError [message #528258 is a reply to message #528224] Mon, 19 April 2010 16:21 Go to previous messageGo to next message
> available.
> at
> ... 33 more
Are you sure that SWTBotPreferences#KEYBOARD_LAYOUT is set to EN_US?
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
Re: SWTBot typeText is getting a java.lang.ExceptionInitializerError [message #528262 is a reply to message #528258] Mon, 19 April 2010 16:55 Go to previous messageGo to next message
Pascal G wrote on Mon, 19 April 2010 16:21
> available.
> at
> ... 33 more
It is not . The value of SWTBotPreferences.KEYBOARD_LAYOUT gets set to EN_CA which matches I guess my LANG env variable setting??. Manually setting the field to :"EN_US" in my @BeforeClass method fixes the problem but this seems rather hokey.
Is there a better way to set this up and why doesn't the code simply default to "EN_US" if such an error occurs?
Re: SWTBot typeText is getting a java.lang.ExceptionInitializerError [message #528274 is a reply to message #528262] Mon, 19 April 2010 17:25 Go to previous messageGo to next message
SWTBot tries to guess your keyboard layout based on your env language.
This would work really well if it wasn't for bug 280562 and bug 280824.
I have to do the same fix in a @BeforeClass method. You could also
define the java property (you know, -Dname=value)
org.eclipse.swtbot.keyboard.layout to EN_US to remove the need of a
@BeforeClass, but I prefer the @BeforeClass because it's a workaround
for those two bugs.
Defaulting to EN_US might sound like a good idea, except that you'll get
weird behavior while you type text if your native keyboard layout isn't
EN_US. And this would be way more complicated to debug than to fail
early with an exception.
Hope this helps.
*Nu Echo Inc.*
Re: SWTBot typeText is getting a java.lang.ExceptionInitializerError [message #528275 is a reply to message #528262] Mon, 19 April 2010 17:26 Go to previous message
Hi Jeff,
http://wiki.eclipse.org/SWTBot/Keyboard_Layouts might be helpful.
Greetings,
Ralf
Learn how to contribute to Eclipse here: http://eclipse.org/contribute/
Read my Blog here: http://www.ralfebert.de/blog/
Follow me on Twitter here: http://twitter.com/ralfebert/
Previous Topic:New SWTBot builds
Next Topic:SWTBot - Ant issue
Current Time: Fri Jul 25 08:34:55 EDT 2025
Powered by FUDForum. Page generated in 0.10402 seconds
