New SWTBot builds [message #526370] |
Fri, 09 April 2010 17:16  |
I just pushed out a new SWTBot build which should make installing it
much easier in your target and your IDE.
Some of the important changes:
– Your IDE only needs the .ide feature installed, nothing else!
– Your target platform only needs the org.eclipse.swtbot,
org.eclipse.swtbot.eclipse (optionally .gef feature) installed.
– Instead of adding all the swtbot plugins as dependencies in your test
plugin, you merely need to add the .go plugin.
Expect a more detailed blog post during the weekend that will describe
in detail these recent changes.
Hope you enjoy the new release!
– Ketan
Re: New SWTBot builds [message #527661 is a reply to message #527574] |
Thu, 15 April 2010 22:10  |
Hi Markus,
I'll make it a point to publish the release notes on the download site
the next time I push. The release notes for the current build are
available on the download site[1].
Thanks for that input :)
– Ketan
[1] -
http://download.eclipse.org/technology/swtbot/galileo/dev-bu ild/RELEASE_NOTES.txt
On 4/15/10 9:11 AM, Markus wrote:
> Hi Ketan!
> It's great that you made the installation and use of SWTBot easier!
> But it would be great to find that information on a more prominent spot
> of the projects pages, or even better in some kind of release notes
> (which I couldn't find by now).
> (And - of course - the 5 minutes starter video should be updated as well
> or at least be marked as "outdated".)
> (I'm a Newbie to SWTBot, playing around now for two weeks. yesterday I
> updated my eclipse plugins using the built in update function and
> suddently i couldn't start my SWTBot-Tests anymore and couldn't find no
> reason for it, until I found your post here.)
> regards, Markus
FUDForum. Page generated in 0.03582 seconds
