Home » Eclipse Projects » SWTBot » TestSuite execution problem
TestSuite execution problem [message #527202] Wed, 14 April 2010 09:15 Go to next message
Hi!
I've got a little problem with SWTBot test execution when I wanna execute more than one test cases. For that purpose I use a test runner given by Ketan:
http://github.com/ketan/swtbot/blob/master/org.eclipse.swtbo t.eclipse.finder.test/src/org/eclipse/swtbot/eclipse/finder/ AllTests.java
The point is that I wanna run each TestCase in a clear enviroment (workbench) for not being in conflict each individual TestCase with the others...
Anyone knows how to run all the TestCases but each one in a clean workbench environment?
Thank in advance.
Urtzi
Re: TestSuite execution problem [message #527217 is a reply to message #527202] Wed, 14 April 2010 09:55 Go to previous messageGo to next message
Urtzi Odriozola wrote:
> Hi!
> given by Ketan:
> others...
> Thank in advance.
> Regards,
> Urtzi
It depends on what you mean by clean workbench... for me, a clean
workbench is one with the proper perspective open and the example
project provided by my plugin open. It strongly depends on your test cases.
To achieve a "clean workbench", simply make sure that every test case
has a proper tearDown() (or @After annotated if you are using JUnit4)
that clean up the mess that the test case just made. Let's take an
example: you have a test case that create a new java project using the
new java project wizard. The tearDown() method should close the wizard
if it's still open (because an error happened and the test case did not
properly finish) and delete the created project. This way, you are back
to the same state you were at the beginning of your test.
Hope this helps.
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
Re: TestSuite execution problem [message #527229 is a reply to message #527202] Wed, 14 April 2010 10:20 Go to previous messageGo to next message
Just added this to the wiki:
http://wiki.eclipse.org/SWTBot/Custom_Before_And_After_Tasks _for_Tests
– Ketan
On 4/14/10 6:15 AM, Urtzi Odriozola wrote:
> Hi!
> given by Ketan:
> others...
> Thank in advance.
> Regards,
> Urtzi
Re: TestSuite execution problem [message #527420 is a reply to message #527217] Thu, 15 April 2010 04:35 Go to previous messageGo to next message
Pascal G wrote on Wed, 14 April 2010 09:55
> Hi!
> given by Ketan:
> others...
> Thank in advance.
> Regards,
> Urtzi
Hope this helps.
*Nu Echo Inc.*
Ok, I understand. And yes, definitely you catch out my idea of "clean workbench".
I thought that there was a simpler way of clean up the mess of my TestCases. I think that doing like you said, you do much effort because you have to write a test 2 times (the second one backwards...).
For example, when I run my tests individually, each test starts in a fresh workbench even if they messed the configuration before. But if I run all my test like I explained above, this not happens.
Thank you for your contribution!
Re: TestSuite execution problem [message #527499 is a reply to message #527420] Thu, 15 April 2010 09:13 Go to previous message
That's unit testing for you :P It's not a SWTBot-only problem: every
test cases that modify some kind of persistent state (the UI, a
database, the filesystem) must clean it up afterwards.
It would definitely be better with a simpler way, but it would be kinda
hard to guess what to do to clean up the workbench. Each test case is
unique, so each clean up is unique
My two cents.
*Nu Echo Inc.*
Previous Topic:Problem with CommandFinder...
Next Topic:New SWTBot builds
Current Time: Sat Jul 26 01:07:49 EDT 2025
Powered by FUDForum. Page generated in 0.03565 seconds
