Home » Eclipse Projects » SWTBot » How to access TestData from headless build
How to access TestData from headless build [message #525271] Mon, 05 April 2010 20:27 Go to next message
In our SWTBot test plugin, we have a folder of Test Data that the test setups use to populate projects with data that can be used in the test. When running in the IDE this is great and in the test source code we can loadup files using a project relative path (e.g., new File ("TestData/mymodel.xml")
However when running headless in an exported product we have a problem in that these files cannot be accessed. They are included in the build, and the test plugin is unpacked, but the files cannot be read. Does anyone know how SWTBot test code can load up test data when the tests are being invoked headlessly and are embedded in an RCP app?
Thanks in advance,
Richard
Re: How to access TestData from headless build [message #525275 is a reply to message #525271] Mon, 05 April 2010 20:55 Go to previous messageGo to next message
Hi Richard,
What we do is ensure that the file is actually packed as part of the
build and then get an inputstream for it using SWTBot's FileUtils class:
bundle = Platform.getBundle('com.example.bundle');
internalUrl = bundle.getEntry('/path/to/file.txt');
url = FileLocator.resolve(internalUrl);
inputstream = url.openStream();
contents = FileUtils.read(inputstream);
There are a few other utility methods in FileLocator that you may find
useful.
Cheers!
-- Ketan
On 4/5/10 5:27 PM, Richard Adams wrote:
> Hello,
> Thanks in advance,
> Richard
Re: How to access TestData from headless build [message #525371 is a reply to message #525271] Tue, 06 April 2010 07:55 Go to previous messageGo to next message
Hi Richard,
I'm putting such resources along with my test classes on the class path, because that's
the only way I'm aware of loading resources independently from OSGi, f.e.:
TestResources.getStream("somefile.txt");
public class TestResources {
public static InputStream getStream(String filename) {
return TestResources.class.getResourceAsStream(filename);
Greetings,
Ralf
http://www.ralfebert.de/blog/
http://twitter.com/ralfebert/
Re: How to access TestData from headless build [message #525446 is a reply to message #525275] Tue, 06 April 2010 11:35 Go to previous message
Thanks, that absolutely did the trick.
Since our app expects files, we write the stream
to tmp files and then cache the tmp file so the names are consistent through all tests
Cheers
Richard
http://csbe.bio.ed.ac.uk/adams.php
http://richardadams606blog.blogspot.com/
Previous Topic:SWTBot Ant Build Time out
Next Topic:Would like to have relative searching based on Composite parent
Current Time: Sat Jul 26 02:43:42 EDT 2025
Powered by FUDForum. Page generated in 0.07313 seconds
