Home » Eclipse Projects » SWTBot » Renaming a node in a tree(Is there a method for renaming a node in a tree)
Renaming a node in a tree [message #515686] Fri, 19 February 2010 13:47 Go to next message
Hi -
As the topic suggests, I have a tree node which expects the user to type in a new name, but I have not been able to find a suitable method for setting the text to a new value.
Is this possible? If so--and I hope it is--what method should I use.
The node is the child of a child, like:
Parent
----- Child
        -----Child
               -----Please Rename Me!
Any assistance is appreciated!
Paul
Re: Renaming a node in a tree [message #515693 is a reply to message #515686] Fri, 19 February 2010 14:23 Go to previous messageGo to next message
Paul N wrote:
> Hi -
> Parent
> ----- Child
> -----Child
> Cheers,
> Paul
Surely there should be some kind of text box active... I don't know of
any way to "rename" a tree node in SWT. My bet would be something like
bot.text().setText("text");
If there isn't any text box active because you have some funky SWT stuff
happening that I don't know of, my second bet would be
KeyboardFactory.getDefaultKeyboard(widget, description).typeText("text");
Hell, another way might even be this, but I don't think it's exactly
what you want:
asyncExec(new VoidResult()
public void run()
treeItem.widget.setText("test");
Hope this helps.
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
Re: Renaming a node in a tree [message #515711 is a reply to message #515693] Fri, 19 February 2010 16:26 Go to previous messageGo to next message
Actually, it was a big help.
I'm new to SWTBot and am not a Java programmer, so I'm encountering a fairly steep learning curve. On the bright side, however, SWTBot seems to be capable of doing much of want I want to automate.
Good way to end the work week!
Paul
Re: Renaming a node in a tree [message #515731 is a reply to message #515686] Fri, 19 February 2010 19:07 Go to previous message
I suppose you'll need to doubleclick on the element and type stuff in a
textbox that pops up.
There's a similar test case for an editable table, you're probably
looking for something similar.
http://github.com/ketan/swtbot/blob/master/org.eclipse.swtbo t.swt.finder.test/src/org/eclipse/swtbot/swt/finder/widgets/ SWTBotTableDoubleClickTest.java
Cheers!
-- Ketan
On 2/20/10 12:17 AM, Paul N wrote:
> Hi -
> Parent
> ----- Child
> -----Child
> Cheers,
> Paul
Previous Topic:Ant: NoClassDEfFoundError while accessing another plugin
Next Topic:TreeItem.pressShortcut() stopped working
Current Time: Sat Jul 26 17:02:08 EDT 2025
Powered by FUDForum. Page generated in 0.27213 seconds
