Home » Eclipse Projects » SWTBot » accessing SwtWidgets
accessing SwtWidgets [message #511372] Mon, 01 February 2010 08:16 Go to next message
hI!
i´ve got a rcp-application with own swt-items.. for example there is a "QCombo extends Composite"
how can i access this combobox with the swtbot? it´s not a ccombobox and not a combobox so i dont know how can i change the selected item with the swtbot.
can swtbot list all widgets?
thnx for any help
Re: accessing SwtWidgets [message #511387 is a reply to message #511372] Mon, 01 February 2010 08:48 Go to previous messageGo to next message
Thomas Py wrote:
> hI!
> "QCombo extends Composite" how can i access this combobox with the
> i change the selected item with the swtbot. can swtbot list all widgets?
> thnx for any help
Finding the widget is quite easy. Using it is something else...
To find your QCombo widget, do this:
QCombo widget = bot.widget(widgetOfType(QCombo.class));
Now to use it, you can't just do QCombo.setSelectedItem() (or whatever
API it might have), you must ensure that the code that needs running in
the UI thread be run in the UI thread, using sync or async execution.
For some quick testing, you could do this:
asyncExec(new VoidResult()
void run()
widget.setSelectedItem();
but it quickly burdens your test code. What you should do instead is use
the page object pattern: make a wrapper for your widget. Ex:
public class SWTBotQCombo extends AbstractSWTBot<QCombo>
public SWTBotQCombo(QCombo w) throws WidgetNotFoundException
this(w, null);
public SWTBotQCombo(QCombo w, SelfDescribing description) throws
super(w, description);
public void setSelectedItem()
void run()
Hope this helps.
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
Re: accessing SwtWidgets [message #511450 is a reply to message #511387] Mon, 01 February 2010 06:06 Go to previous messageGo to next message
Thanks for the great explanation Pascal!
I've copied the entire text to the FAQ :)
-- Ketan
On 2/1/10 5:48 AM, Pascal Gelinas wrote:
> Thomas Py wrote:
>> hI!
>> thnx for any help
> void run()
> this(w, null);
> void run()
> Hope this helps.
Re: accessing SwtWidgets [message #512151 is a reply to message #511450] Thu, 04 February 2010 03:17 Go to previous message
ok yeah! thanks! it worked. now i can copypaste-rename it and access all the swt-items i find Smile
thank you!
Previous Topic:Archived SWTBot builds available.
Next Topic:perspective getLabel
Current Time: Tue Jul 22 20:37:48 EDT 2025
Powered by FUDForum. Page generated in 0.25597 seconds
