Home » Archived » Eclipse Communications Framework (ECF) » Getting started with ECF & Dependencies on Eclipse
Getting started with ECF & Dependencies on Eclipse [message #509730] |
Mon, 25 January 2010 03:11  |
Originally posted by: Florian.Rampp.jambit.com
I'm working on a project which is trying to introduce a notion of
information and services to my client, including support of transparent
remote service invocation, information sharing, information and service
discovery and synchronization of data. I stumbled over ECF and I believe
it's a good candidate for being evaluated further.
Since your documentation is not the greatest, I would be glad about some
initial advice. Most important for me are the following two points:
1. How many dependencies does ECF have on any other Eclipse modules
(except core Equinox modules)? This is important since my client
requires a lightweight solution, running in a resource restricted
environment.
2. I'm using Maven as a build tool. Are there Maven artifacts of the
latest ECF release available?
Otherwise, where can I get the ECF 3.1 artifacts from, except by doing
an eclipse update over p2?
I also checked out the sources from the CVS repository, but this neither
provided a quick start, since I didn't really understand the repository
layout.
In the case that ECF suits our needs, we would like to dive a little
deeper into the code and there is a chance of contributing code at a
later stage of the project. So I would be very glad about some initial
advice, especially how to get ECF running without the full-fledged Eclipse.
Thanks a lot,
Florian
Re: Getting started with ECF & Dependencies on Eclipse [message #510176 is a reply to message #509730] |
Tue, 26 January 2010 05:52   |
Hi Florian,
Florian R. wrote:
> Hello,
> environment.
Except for some of the example apps (which have Eclipse-based user
interfaces and therefore dependencies on things like swt, jface, etc),
ECF's dependencies are indeed minimal. They do *not* depend upon
Eclipse (but rather just on OSGi and Equinox).
Specifically, the only external (non-ECF) dependencies in the remote
service API are:
(From Equinox):
org.osgi.framework
org.eclipse.equinox.common
org.eclipse.equinox.concurrent
org.eclipse.equinox.registry
The only exception for the above dependencies is the discovery UI, which
also depends upon 5 EMF bundles. It's not required that you even use
this discovery UI, however, and it's only relevant in some situations
(e.g. RCP apps that wish to use this view). Discovery can/will work
without the discovery UI.
Further, we've been very careful to use the minimum execution
environment possible...and in most cases that minimum is CDC
1.1/Foundation 1.1 (which is less/smaller than jre 1.4).
As an example, I've been using ECF recently in a small/lightweight web
server situation...here is a blog posting about some of that work:
http://eclipseecf.blogspot.com/2009/12/cloud-osgi-gwt-ecf-re st-twitter-api.html
No. We simply don't have the resources to do this. Since we are using
Buckminster for our own build (which is available here, btw):
https://ecf2.osuosl.org/hudson/
....and I understand that Buckminster can product Maven artifacts it may
not be a huge deal to do this, but we can't commit to doing it ourselves.
You can get them from the zip available on the download page
http://www.eclipse.org/ecf/downloads.php
Here's a link directly to the zip
http://www.eclipse.org/downloads/download.php?file=/rt/ecf/3 .1/3.5/org.eclipse.ecf.sdk-3.1.0.v20091012-1618.zip
> layout.
Did you use the project set file we have available? This is much easier
than trying to figure out all the relevant parts and their locations in
CVS. Here are instructions for getting things from the releng project
set file:
http://www.eclipse.org/ecf/dev_resources.php
Another thing you can do, btw, is with Eclipse 3.5 (or newer) you can
add the entire ECF SDK (which is still less than 10M btw) directly to
the target platform, and then ECF APIs will be available both at compile
time and will be automatically added to the built system as part of PDE
build.
BTW, it's my (Scott's) desire to have for Helios new/additional features
that *just* expose the remote service bundles (rather than all of ECF),
but given our current resource limitations I'm not sure if we'll be able
to do it for Helios.
I would suggest, BTW, that you consider using the ECF 3.2 stream (which
is in development/testing now and will be out Feb 19), because a big
part of that work was the move over to using the OSGI 4.2 remote
services standard as described by this post:
http://eclipseecf.blogspot.com/2010/01/osgi-remote-services- from-ecf.html
and this is quite a large break from ECF 3.1 (which was using RFC119 for
remote services standardization...and that standard is now obsolete).
Also, it might be a good idea for you to join the ECF dev mailing list:
https://dev.eclipse.org/mailman/listinfo/ecf-dev
The coverage of that list is higher/faster (from me, anyway :).
Also, if you want to reach me directly (I'm the project lead and could
provide direct support for your usage or even custom development) please
send an email to slewis at composent.com.
Scott
Re: Getting started with ECF & Dependencies on Eclipse [message #510295 is a reply to message #510176] |
Wed, 27 January 2010 02:21  |
Hello Scott,
>> transparent remote service invocation, information sharing,
>> information and service discovery and synchronization of data. I
>> stumbled over ECF and I believe it's a good candidate for being
>> evaluated further.
>> some initial advice. Most important for me are the following two points:
>> environment.
> service API are:
> (From Equinox):
> org.osgi.framework
That is good news. Seems like you designed it pretty much decoupled from
other Eclipse modules.
I didn't do much work with the Eclipse platform yet (except using it as
my IDE :), so I just got in touch with Buckminster and other Eclipse
platform concepts recently.
>> neither provided a quick start, since I didn't really understand the
>> repository layout.
> set file:
Never new of something like a project set file, so thanks for pointing
this out. Same thing as above, I'm rather new to Eclipse as a platform.
>> Eclipse.
> build.
So, thanks a lot for all the help. I will digest all this information
now and will definitely come back to you later.
Florian
Re: Getting started with ECF & Dependencies on Eclipse [message #625039 is a reply to message #509730] |
Tue, 26 January 2010 10:48  |
Hi Florian,
Florian R. wrote:
> Hello,
> environment.
service API are:
(From Equinox):
org.osgi.framework
> layout.
set file:
build.
Scott
Re: Getting started with ECF & Dependencies on Eclipse [message #625047 is a reply to message #625039] |
Hello Scott,
>> evaluated further.
>> environment.
> service API are:
> (From Equinox):
> org.osgi.framework
>> repository layout.
> set file:
>> Eclipse.
> build.
Florian
Current Time: Sat Jul 26 07:58:49 EDT 2025
Powered by FUDForum. Page generated in 0.04496 seconds
