Home » Eclipse Projects » SWTBot » [Solved] InputDialog - buttons not found
[Solved] InputDialog - buttons not found [message #509171] Thu, 21 January 2010 10:11 Go to next message
I'm trying to access an input dialog (org.eclipse.jface.dialogs.InputDialog) with SWTBot. But the OK / Cancel buttons are not found. Is the input dialog supported by SWTBot?
What I tried:
bot.button("OK").click();
Exception:
Caused by: org.eclipse.swtbot.swt.finder.widgets.TimeoutException: Timeout after: 5000 ms.: Could not find widget matching: (of type 'Button' and with mnemonic 'OK' and with style 'SWT.PUSH')
I also tried:
SWTBotButton button = new SWTBotButton((Button) bot.widget(withMnemonic("OK")));
button.click();
But that caused the exception:
Caused by: org.eclipse.swtbot.swt.finder.widgets.TimeoutException: Timeout after: 5000 ms.: Could not find widget matching: with mnemonic 'OK'
The InputDialog is invoked like this:
InputDialog x = new InputDialog(parentshell, title, message, initVal, null);
x.open();
(the parentshell is the global shell (IWorkbenchWindow.getShell()))
Any ideas or hints what may be the cause of this?
Thanks!
[Updated on: Mon, 25 January 2010 03:28] by Moderator
Re: InputDialog - buttons not found [message #509265 is a reply to message #509171] Thu, 21 January 2010 09:28 Go to previous messageGo to next message
div0@gmx.net wrote:
> What I tried:
> Exception:
> I also tried:
> bot.widget(withMnemonic("OK"))); button.click();
> But that caused the exception: Caused by:
> null);
> x.open();
> Thanks!
I do think they are supported, since they are not native dialog. It's
only a custom made shell with some widget in it. Are you sure that the
button's label is "OK"? I'd try "Ok" just to be sure; I think the 'K'
should be lower-case. If that doesn't solve the problem, I'd try this to
see if you get a WidgetNotFound:
SWTBotShell shell = bot.shell(title);
if this fails, then its probably that your input dialog is not open. If
this doesn't fail, I'd do this:
bot.widget(allOf(widgetOfType(Button.class), withMnemonic("OK")));
Then again, if you try this make sure you have the good mnemonic. If
this doesn't work... well it should work :P
Hope this helps.
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
Re: InputDialog - buttons not found [message #509289 is a reply to message #509171] Thu, 21 January 2010 15:53 Go to previous messageGo to next message
You may want to try:
bot.shell("Your input dialog title").activate();
before clicking on the button. If swtbot tries to find the button before
the input dialog opens, then it's looking for the button in the current
active shell.
-- Ketan
On 1/21/10 7:11 AM, div0@gmx.net wrote:
> What I tried:
> Exception:
> I also tried:
> null);
> x.open();
> Thanks!
Re: InputDialog - buttons not found [message #509357 is a reply to message #509265] Fri, 22 January 2010 03:52 Go to previous messageGo to next message
Hi Pascal, hi Ketan,
thanks for your replies. I think the problem has to do with the shell. I tried to get the shell (SWTBotShell shell = bot.shell(title)) but got a widget not found exception.
I also added bot.activeShell().getText() right before and after the command that opens die InputDialog. The active shell was always the same one (the main RCP workbench shell).
When I iterate over bot.shells() I can't find the InputDialog shell either. It's strange, because I see the dialog on screen, so it has to be there somewhere Confused
Re: InputDialog - buttons not found [message #509500 is a reply to message #509171] Fri, 22 January 2010 11:09 Go to previous messageGo to next message
I got the chronology wrong. The commands to click a button were not executed while the InputDialog was active.
from my test class:
System.out.println("Active shell: "+bot.activeShell().getText());
SWTBotGefEditor editor = bot.gefEditor("Editor");
editor.activateTool("Part1");
editor.mouseMoveLeftClick(200, 200);
The InputDialog is shown when a part is droped to the editor.
The second println is executed not until the InputDialog is closed (manually).
So the bot.button(...).click(); commands are not executed while the dialog is active. The dialog blocks the test somehow.
Re: InputDialog - buttons not found [message #509513 is a reply to message #509500] Fri, 22 January 2010 06:38 Go to previous messageGo to next message
mouseMoveLeftClick should launch the click asynchronously :
public void mouseMoveLeftClick(final int xPosition, final int yPosition) {
UIThreadRunnable.asyncExec(new VoidResult() {
The modification was made the 10 December (revision 452), so maybe you use an older version of SWTBot ?
Mariot
> from my test class:
> editor.mouseMoveLeftClick(200, 200); System.out.println("Active shell:
> "+bot.activeShell().getText()); bot.button("OK").click();
> (manually).
Re: InputDialog - buttons not found [message #509725 is a reply to message #509171] Mon, 25 January 2010 03:28 Go to previous message
Hi Mariot,
thanks a lot! I've used rev 433. I just updated to 467 and it works like a charm!
Previous Topic:test org.rcpmail using ant not work
Next Topic:PressShortcut
Current Time: Sat Jul 26 06:48:36 EDT 2025
Powered by FUDForum. Page generated in 0.05577 seconds
