Home » Eclipse Projects » SWTBot » Can't access Console view?
Can't access Console view? [message #507877] Thu, 14 January 2010 18:26 Go to next message
The following always fails with a WidgetNotFoundException:
SWTBotView consoleView= bot.viewByTitle("Console");
even when I can see that the Console view is visible when this
query executes.
Is this the wrong way of getting at the Console?
-- Bob
Robert M. Fuhrer
Research Staff Member
Programming Technologies Dept.
IBM T.J. Watson Research Center
IDE Meta-tooling Platform Project Lead (http://www.eclipse.org/imp)
X10: Productive High-Performance Parallel Programming (http://x10.sf.net)
Re: Can't access Console view? [message #507885 is a reply to message #507877] Thu, 14 January 2010 19:46 Go to previous messageGo to next message
Seems to work for me. Do you have a stack trace to help diagnose ?
Here's my test. I'm opening the console view programatically the first
time, but that should not matter.
@Test
public void canOpenConsoleView() throws Exception {
syncExec(new VoidResult() {
public void run() {
try {
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().showView( "org.eclipse.ui.console.ConsoleView");
} catch (PartInitException e) {
e.printStackTrace();
bot.viewByTitle("Problems").show();
bot.viewByTitle("Console").show();
-- Ketan
> query executes.
Re: Can't access Console view? [message #507886 is a reply to message #507885] Thu, 14 January 2010 20:22 Go to previous messageGo to next message
Ok, this is weird - it's working now, every time. I don't know what
was wrong.
Anyway, sorry for the false alarm.
><...snip...>
>> query executes.
-- Bob
Robert M. Fuhrer
Re: Can't access Console view? [message #508029 is a reply to message #507886] Fri, 15 January 2010 10:41 Go to previous message
Perils of UI testing. Happens all the time ;)
-- Ketan
Previous Topic:Dirty editor causes failing SWTBot test to block on 'Save changes?' dialog
Next Topic:WidgetNotFound when looking for menu item?
Current Time: Wed Jul 23 12:43:37 EDT 2025
Powered by FUDForum. Page generated in 0.07495 seconds
