Home » Eclipse Projects » Rich Client Platform (RCP) » Memory consumption
Memory consumption [message #499528] Mon, 23 November 2009 04:08 Go to next message
I have a problem of memory consumption in my RCP.
When I launch my application, the memory consumption is about 100Mo, but during its used, it can rise to 600Mo, and it never decreases after.
I would like to know if it is possible to deallocate memory and how, in order to decrease memory consumption?
Thanks for your help.
David.
Re: Memory consumption [message #499529 is a reply to message #499528] Mon, 23 November 2009 04:23 Go to previous messageGo to next message
You likely have a memory leak somewhere; some static variable holding a pointer to something for example.
You may need to get a profiling tool (like Jprofiler) to find the objects that are in memory and why they are there.
Re: Memory consumption [message #501365 is a reply to message #499528] Tue, 01 December 2009 18:10 Go to previous messageGo to next message
David CHAUTARD schrieb:
> Hello,
> David.
Probably you have some kind of Packratting problem.
Following steps may help you to find the culprit for your problem.
Connect to your program with jconsole
dump the heap to a file xyz.hprof (MBeans -> com.sun.management ->
HotSpotDiagnostics -> Operations)
then use Eclipse MAT ( http://www.eclipse.org/mat/ ) to analyze the heap
to find some object that dominates large ammounts of data...
Re: Memory consumption [message #501388 is a reply to message #499528] Wed, 02 December 2009 00:46 Go to previous messageGo to next message
Have a look at the MAT project. Little intro:
http://www.vogella.de/articles/EclipseMemoryAnalyser/article .html
David CHAUTARD wrote:
> Hello,
> David.
Re: Memory consumption [message #501875 is a reply to message #501388] Fri, 04 December 2009 04:16 Go to previous message
thanks for your answers.
I try to use Memory Analyzer (MAT), but I can't generate the .hprof file. I launch my product, with the VM arguments (Run configuration) :
-Dcom.sun.management.jmxremote
-Dcom.sun.management.jmxremote.port=8084
-Dcom.sun.management.jmxremote.ssl=false
-Dcom.sun.management.jmxremote.authenticate=false
-XX:+HeapDumpOnOutOfMemoryError
Then I perform some actions in order to increase the memory consumption. I can see the consumption climbing from 200Mo to 570Mo in the Windows tasks manager, but no file is generated.
Did I forget something, what should I do to get this file?
David.
Previous Topic:Open a View
Next Topic:Add new plug-ins to a RCP
Current Time: Thu Jul 24 19:26:12 EDT 2025
Powered by FUDForum. Page generated in 0.03812 seconds
