Home » Eclipse Projects » SWTBot » How to relaunch AUT before each test class in test suite?
How to relaunch AUT before each test class in test suite? [message #500459] Thu, 26 November 2009 04:23 Go to next message
Hi All,
I see that by default SWTBot runner launches application under test for the whole test suite once. During testing I sometimes face critical issues that could shut down the application, so all other tests in suite fail afterwards. So I'm just wondering if it'spossible to relaunch AUT for each test class in the suite?
Thanks in advance,
Pavel
Re: How to relaunch AUT before each test class in test suite? [message #500522 is a reply to message #500459] Thu, 26 November 2009 09:26 Go to previous messageGo to next message
I'm interested in this answer too.
And I'v got a pretty simular question.
Is it possible to launch the AUT by hand, do something an then start SWTBot to test the already started application?
Thx for reply
Benni
Re: How to relaunch AUT before each test class in test suite? [message #500530 is a reply to message #500459] Thu, 26 November 2009 09:28 Go to previous messageGo to next message
Short answer:
You can't! Fix the critical issues that cause the application to shutdown.
Workaround:
You can mark the tests with an @Ignore annotation[1] to ignore running
them if they are a problem; and once the bug that causes the app to
shutdown is fixed, you can replace the @Ignore annotation with @Test.
-- Ketan
[1] - http://junit.org/apidocs/org/junit/Ignore.html
Pavel Stepanov wrote:
> Hi All,
> Thanks in advance,
> Pavel
Re: How to relaunch AUT before each test class in test suite? [message #502239 is a reply to message #500522] Mon, 07 December 2009 06:33 Go to previous message
1. Can't relaunch AUT... Because test suites resides at the AUT... But there's workaround, such as record the already executed tests and execute lefts after restarting
2. Use debug SWTBotTest, check Keep the JUnit running checkbox, you'll do something on AUT and rerun the testcases via remote execution commands
Previous Topic:New SWTBot build
Next Topic:running ui and non-ui tests with swtbot
Current Time: Thu Nov 06 01:20:49 EST 2025
Powered by FUDForum. Page generated in 0.06638 seconds
