Home » Eclipse Projects » SWTBot » Get GEF edtior nested in a multi-page editor
Get GEF edtior nested in a multi-page editor [message #496576] Tue, 10 November 2009 10:48 Go to next message
My GEF editor is actually a tab page in a multi-page eidtor (which contains visual editor, text edior, etc).
Is it possible to get my GEF editor by calling the method bot.gefEditor("myEditor.editor") ?
Thanks.
Re: Get GEF edtior nested in a multi-page editor [message #496626 is a reply to message #496576] Tue, 10 November 2009 12:13 Go to previous messageGo to next message
This should work fine with the correction applied for this bug : https://bugs.eclipse.org/bugs/show_bug.cgi?id=294301
It will be available in the next release.
I also added an example see testCreateMFile() in
http://dev.eclipse.org/svnroot/technology/org.eclipse.swtbot /trunk/examples/gef/org.eclipse.gef.examples.logic.test/src/ org/eclipse/gef/examples/logic/test/OpenGefEditorTest.java.
Mariot
QIU Mengjie a écrit :
> Hello,
> Thanks.
Re: Get GEF edtior nested in a multi-page editor [message #497005 is a reply to message #496626] Thu, 12 November 2009 03:38 Go to previous messageGo to next message
Thanks, Mariot.
Re: Get GEF edtior nested in a multi-page editor [message #503490 is a reply to message #496576] Mon, 14 December 2009 03:34 Go to previous message
Hello QIU,
I am new to GEF and want to use GEF Shape Editor inside the Multipage Editor.
While doing so I am getting streamCorrupt exception inside setInput method. and I am not able to see the palatee tools also (only palaatte area is visble). Can you please help me on this or share some code so that I can resolve from this problem.
Please help me.
Thanks in advnace.
Previous Topic:Issue in disabling the check menu item
Next Topic:SWTBOT testing trees with Label decorators applied
Current Time: Fri Jul 18 09:57:27 EDT 2025
Powered by FUDForum. Page generated in 0.05076 seconds
