Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Selection event for CCombo should not fire when arrow-navigating in the dropDown
Selection event for CCombo should not fire when arrow-navigating in the dropDown [message #496456] Tue, 10 November 2009 02:52 Go to next message
--------------040307040702070601020302
Content-Type: text/plain; charset=ISO-8859-2; format=flowed
In current implementation (SWT 3.5.1), CCombo fires Selection event, if the user navigates in the drop-down box using arrows. I think this is not necessary, especially in case of READ_ONLY combo-boxes. I have processing attached to Selection event and it fires to often from the user point of view. The standard Combo (at least under Windows) does not behave like this.
What others think about this? I made a patch for me that I'd like to be included in the next release.
Viliam
name="CCombo.diff"
Content-Disposition: inline;
filename="CCombo.diff"
59a60
> String preDropDownValue;
520a522,524
> // send Selection event, if the value was changed since dropDown(true)
> if ( ! preDropDownValue.equals(text.getText()))
> notifyListeners(SWT.Selection, null);
521a526,528
> } else {
> // keep original value before showing dropDown for comparison
> preDropDownValue = text.getText();
1032a1040,1046
> // post the value from list to text for selection event fired in dropDown(false)
> int index = list.getSelectionIndex ();
> if (index == -1) return;
> text.setText (list.getItem (index));
> text.selectAll ();
> list.setSelection (index);
1042c1056,1057
< Event e = new Event ();
> // Don't post the event here - will be posted in dropDown(false)
> /*Event e = new Event ();
1047c1062
< event.doit = e.doit;
> event.doit = e.doit;*/
--------------040307040702070601020302--
Re: Selection event for CCombo should not fire when arrow-navigating in the dropDown [message #496885 is a reply to message #496456] Wed, 11 November 2009 10:53 Go to previous messageGo to next message
Hi Viliam,
When you say "arrows" you mean the arrow keys, right? Assuming so, this
behaviour does match what I see in Combos on win32. This is needed because
arrowing through the items does select them (ie.- pressing Esc
dismisses/cancels the list but does not revert the selection to its previous
value). The previously-logged bug for Combo selection on win32 is
https://bugs.eclipse.org/bugs/show_bug.cgi?id=95479 .
There's no requirement for CCombo's behaviour to match Combo, but doing so
where possible is desirable since these behaviours are generally well
thought-out and expected by users. The behaviour that you want matches gtk
but not win32, so there's no obvious "correct" behaviour here. I would
suggest logging a Feature Request with SWT (
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=SWT&bug_severity=enhancement )
and provide a patch with the proposed change. I don't know if it will be
taken or not, it depends on whether others agree with the change (mention
that GTK's Combo behaves like this). Also, your patch format doesn't look
like one that is easily applied here, the best steps for creating a patch
are:
- retrieve swt from cvs: http://www.eclipse.org/swt/cvs.php
- make your changes to the org.eclipse.swt project in your workspace
- select the org.eclipse.swt project, right-click, invoke Team > Create
Patch...
Grant
"Viliam Durina" <viliam.durina@gmail.com> wrote in message
news:hdb63l$rbm$1@build.eclipse.org...
> Viliam
> 59a60
> 520a522,524
> 521a526,528
> > } else {
> 1032a1040,1046
dropDown(false)
> > text.selectAll ();
> 1042c1056,1057
> 1047c1062
Re: Selection event for CCombo should not fire when arrow-navigating in the dropDown [message #497070 is a reply to message #496885] Thu, 12 November 2009 07:43 Go to previous message
Hi Grant,
In Slovak we press "arrow", not "arrow key" :)
I think that the order and count of delivered events should not be something considered native to platform, as most user don't see it. Event handling is one of the most challenging issue in SWT applications portability, which is another goal of SWT.
Navigating with arrow keys should be considered "browsing the items" not "selecting item by item". When I listen to SelectionEvent, I expect it to be delivered after the user browsed the items up and down and chose the one he wants, no matter whether by the keyboard or mouse. Do you think user will consider accepting the selection after pressing the enter key a non-windows behaviour? I think not.
Another example is that scroll event is delivered to a focused widget instead of to the one the mouse is over. This is much more annoying than the case with combobox. No modern Windows application except Eclipse scrolls in this stupid way, even though it is native to Windows. And programmers have to work it around and pay attention to break it not on GTK, where it works out of the box.
I'm not going to fill enhancement request as I have no hope (and it was already refused in bug you mentioned).
Viliam
Grant Gayed wrote / napísal(a):
> Hi Viliam,
> are:
> Patch...
> Grant
>> Viliam
>> 59a60
>> 520a522,524
>> 521a526,528
>>> } else {
>> 1032a1040,1046
> dropDown(false)
>>> text.selectAll ();
>> 1042c1056,1057
>> 1047c1062
Previous Topic:Listen IProgressMonitor stop button
Next Topic:listener for enable/disable events?
Current Time: Wed Jul 23 13:19:44 EDT 2025
Powered by FUDForum. Page generated in 0.04301 seconds
