Home » Eclipse Projects » SWTBot » Text Fields by ID
Text Fields by ID [message #494827] Mon, 02 November 2009 15:00 Go to next message
Can anyone help me figure out why this isn't working:
http://github.com/gaffo/swtbotexamples/blob/master/junit/com /uberu/TextWithIdTest.java
Thanks!
Re: Text Fields by ID [message #494832 is a reply to message #494827] Mon, 02 November 2009 15:53 Go to previous messageGo to next message
Looks like one bug is that you call this twice:
textField1.setData
Re: Text Fields by ID [message #494837 is a reply to message #494827] Mon, 02 November 2009 16:07 Go to previous messageGo to next message
> Thanks!
line 96 should be textField2.setData, instead of textField1.setData
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
Re: Text Fields by ID [message #495016 is a reply to message #494827] Tue, 03 November 2009 09:46 Go to previous messageGo to next message
DOH! That seems to work. Thanks folks.
Re: Text Fields by ID [message #495687 is a reply to message #494827] Thu, 05 November 2009 13:38 Go to previous message
One comment to the test code. In order to avoid a dependency of your application code to any swtbot plugin by using org.eclipse.swtbot.swt.finder.utils.SWTBotPreferences.DEFAUL T_KEY, you should define your own ID_KEY and set this value in the SWTBotPreferences instead.
Kay
Previous Topic:Testing exported RCP fails with StackOverflow
Next Topic:SWTBot test run configuration type actually needed?
Current Time: Tue Jul 22 21:30:39 EDT 2025
Powered by FUDForum. Page generated in 0.08357 seconds
