Home » Eclipse Projects » SWTBot » Click on SWTBotToolbarButton - nothing happens
Click on SWTBotToolbarButton - nothing happens [message #482848] Fri, 28 August 2009 06:40 Go to next message
i have a view with a Tree and want to run an action with
SWTBotToolbarButton(for example: collapse the tree).
I get the button, can click on it, but nothing happens.
Bug ?
Re: Click on SWTBotToolbarButton - nothing happens [message #483327 is a reply to message #482848] Tue, 01 September 2009 03:26 Go to previous messageGo to next message
Hi Aleksey,
could you show some code?
I tried it some days ago and it worked for me.
Benni
Re: Click on SWTBotToolbarButton - nothing happens [message #483330 is a reply to message #483327] Tue, 01 September 2009 03:39 Go to previous messageGo to next message
Hi Benni,
here is the code :
SWTBotView view =
workbenchbot.viewById(IPageLayout.ID_OUTLINE);
SWTBotToolbarButton toolBarButton =
view.toolbarButton(toolTipText);
toolBarButton.click();
Benjamin Glaser schrieb:
> Hi Aleksey,
> Benni
Re: Click on SWTBotToolbarButton - nothing happens [message #483367 is a reply to message #483330] Tue, 01 September 2009 07:31 Go to previous messageGo to next message
Sorry, but I can't replicate the issue.
SWTBotView view = bot.viewByTitle("title");
SWTBotToolbarButton toolBarButton = view.toolbarButton("tooltip");
works fine for me.
The Tree collaps as expected.
I used viewbytitle because my testview didn't have an ID so far.
But I don't think this will change a lot.
You don't get any exceptions?
It just don't happens anything?
Pretty weird...
Re: Click on SWTBotToolbarButton - nothing happens [message #483655 is a reply to message #483367] Wed, 02 September 2009 09:38 Go to previous messageGo to next message
> works fine for me.
> Pretty weird...
The run-Method of the action is called, but isChecked() returns always
false ...
As a consequence the implementation assumes that the action is not
enabled and can not add a filter(ViewerFilter) to the tree => no change
in the tree...
Re: Click on SWTBotToolbarButton - nothing happens [message #483687 is a reply to message #483655] Wed, 02 September 2009 11:04 Go to previous messageGo to next message
>> works fine for me.
>> Pretty weird...
> false ...
> in the tree...
.... could be an OS-problem ? (i have ubuntu)
Re: Click on SWTBotToolbarButton - nothing happens [message #483711 is a reply to message #483687] Wed, 02 September 2009 11:46 Go to previous messageGo to next message
>>> works fine for me.
>>> Pretty weird...
>> false ...
>> change in the tree...
I don't think it's an OS problem. The SWTBotToolbarButton doesn't set
the checked status of the button, you should instead use a
SWTBotToolbarCheckboxButton, like this:
view.bot().toolbarToggleButton("tooltip");
I think this should work now. Or maybe not, I don't know if the bot will
search in the global toolbar or the views toolbar. Give it a try and
we'll know.
Another way would be:
new SWTBotToolbarCheckboxButton(toolBarButton.widget).click();
I'm pretty sure this one will work, althought it looks clumsy to me...
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
Re: Click on SWTBotToolbarButton - nothing happens [message #483712 is a reply to message #483711] Wed, 02 September 2009 12:06 Go to previous messageGo to next message
>>>> works fine for me.
>>>> Pretty weird...
>>> false ...
> we'll know.
thank you Pascal, the second way works fine!
Re: Click on SWTBotToolbarButton - nothing happens [message #483855 is a reply to message #483655] Thu, 03 September 2009 07:49 Go to previous messageGo to next message
Well, you never mentioned that you want to click on an toggleButton.
"colapseAll" isn't a toggleButton.
Have a closer look at: https://bugs.eclipse.org/bugs/show_bug.cgi?id=282982
Re: Click on SWTBotToolbarButton - nothing happens [message #484071 is a reply to message #483855] Fri, 04 September 2009 04:04 Go to previous message
depends on the the implementation of the "collapseAll" action(i have my
own) :-)
sorry, was my fault ...
Previous Topic:Bugfixing of local swtbot plugins
Next Topic:Wait for progressmonitordialog close
Current Time: Sun Jul 20 23:44:09 EDT 2025
Powered by FUDForum. Page generated in 0.27894 seconds
