Home » Eclipse Projects » SWTBot » How to test the ControlDecoration?
How to test the ControlDecoration? [message #43100] Mon, 13 July 2009 09:28 Go to next message
If the product code use ControlDecoration to show the hover text besides a
text control, does SWTBot support testing it? If support, which API should
I use? Thanks in advance!
Re: How to test the ControlDecoration? [message #43206 is a reply to message #43100] Mon, 13 July 2009 18:05 Go to previous messageGo to next message
> a text control, does SWTBot support testing it? If support, which API
> should I use? Thanks in advance!
Short answer: This should probably be tested using using a mock.
Long answer:
The ControlDecoration seems be an ugly untestable mess that creates an
empty 'hover shell' on which things are drawn. Yes as in literally draw
on a blank canvas. See the constructor in the ControlDecorator#Hover
class for the paint listener that uses the graphic canvas.
hoverShell.addPaintListener(new PaintListener() {
public void paintControl(PaintEvent pe) {
pe.gc.drawText(text, hm, hm);
if (!MAC) {
pe.gc.drawPolygon(getPolygon(true));
Ketan
http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
Re: How to test the ControlDecoration? [message #43239 is a reply to message #43206] Mon, 13 July 2009 19:06 Go to previous messageGo to next message
Ketan,
I think the code you mentioned is only for the cartoon-style form of the
"tooltip" shell. This is something which should be tested by JFace - not
the application developers.
I think it will be much more interesting to test that the decoration
appears in a test scenario. You may check the visible flag if there is
any way to access it outside. Or even the shouldShow method.
Greets
Ben
> Long answer:
> if (!MAC) {
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Re: How to test the ControlDecoration? [message #43364 is a reply to message #43239] Tue, 14 July 2009 03:39 Go to previous messageGo to next message
In one of my project I had to solve the same problem. I wanted to write a
test, which checks whether the (required) decorators are visible or not. I
used the following approach.
1. Write your own CustomDecoration which extends ControlDecoration to
access the current state of the decoration, e.g. I added a isShow method,
to test whether the decoration is visible or not.
2. In your application code put the CustomDecoration object into the
widget with setData.("DECORATION_KEY", CustomDecoration):
3. In your swtbot test code write a utility method which uses a UIRunnable
to extract the CustomDecoration from the AbstractSWTBot object and which
calls the corresponding method, e.g. isShow.
Kay
Re: How to test the ControlDecoration? [message #44936 is a reply to message #43364] Wed, 22 July 2009 16:31 Go to previous messageGo to next message
Thanks Kay, that is a great idea. I filed
http://bugs.eclipse.org/bugs/284330 to request an isVisible API from
ControlDecoration to avoid subclassing.
"Kay-Uwe Graw" <kugraw@web.de> wrote in message
news:58debefc26517611b39b79dbcd06a16b$1@www.eclipse.org...
> Kay
Re: How to test the ControlDecoration? [message #44964 is a reply to message #44936] Wed, 22 July 2009 17:11 Go to previous message
P.S. Here is a sketch of a class that encapsulates this (assumes the control
has its decoration in getData("CONTROL_DECORATION") and uses reflection for
checking if the decoration is visible):
public class SWTBotControlDecoration {
private final AbstractSWTBot<? extends Control> mControl;
private final Field mVisibleField;
public SWTBotControlDecoration(AbstractSWTBot<? extends Control>
control) throws Exception {
mControl = control;
mVisibleField =
ControlDecoration.class.getDeclaredField("visible");
mVisibleField.setAccessible(true);
public Image getImage() {
return UIThreadRunnable.syncExec(mControl.display, new
Result<Image>() {
public Image run() {
return getDecoration().getImage();
public boolean isVisible() throws Throwable {
Result<Boolean>() {
public Boolean run() {
try {
return mVisibleField.getBoolean(getDecoration());
} catch (Exception e) {
throw new RuntimeException(e);
private ControlDecoration getDecoration() {
return (ControlDecoration)
mControl.widget.getData("CONTROL_DECORATION");
"Will Horn" <will.horn@gmail.com> wrote in message
news:h47sv3$61m$1@build.eclipse.org...
>> I used the following approach.
>> UIRunnable to extract the CustomDecoration from the AbstractSWTBot object
>> and which calls the corresponding method, e.g. isShow.
>> Kay
Previous Topic:select a tree node and its child
Next Topic:Target Executable from the Command Line
Current Time: Sat Nov 08 07:21:01 EST 2025
Powered by FUDForum. Page generated in 0.03362 seconds
