Home » Eclipse Projects » SWTBot » Support of Nebula FormattedText widget
Support of Nebula FormattedText widget [message #42690] Fri, 10 July 2009 03:54 Go to next message
Good morning,
I want to use SWTBot to write all the tests for our Eclipse RCP
application.
Now I got a problem with an widget that is used in the application.
It's the Nebula FormattedText widget.
The application uses a lot of these textfields.
If I use the setText() methode on a formattedText (as seen below)
bot.textWithId("key", "value").setText("65451,4545");
it only sets the text until the comma ("65451") the rest is ignored.
Mabye the problem is the Formatter the application uses for this textfield.
But if I type the same text into the formattedText widget by hand, it's
all fine.
Is there a possibility to get it working?
Benjamin
Re: Support of Nebula FormattedText widget [message #42753 is a reply to message #42690] Fri, 10 July 2009 08:02 Go to previous messageGo to next message
Benjamin Glaser wrote:
> Good morning,
> application.
> all fine.
> Benjamin
Have you tried using the typeText(String) method? This one emulates
real user input by sending OS event. The only drawback is that it only
supports (for now) a standard US keyboard.
If you plan on trying it, I suggest you set
SWTBotPreferences#KEYBOARD_STRATEGY to
"org.eclipse.swtbot.swt.finder.keyboard.SWTKeyboardStrategy"
Hope this help.
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
Re: Support of Nebula FormattedText widget [message #42846 is a reply to message #42753] Fri, 10 July 2009 09:57 Go to previous message
I did a workaround with the typeText() methode.
That works fine after I changed the keyboard layout of my OS to US_EN.
Issue solved.
Thank you for your help.
Benjamin
Previous Topic:how to test swing code
Next Topic:swtBotEclipseEditor.typeText issue
Current Time: Sat Jul 19 17:20:36 EDT 2025
Powered by FUDForum. Page generated in 0.04019 seconds
