Home » Modeling » EMF » [CDO] problem I can't resolve
[CDO] problem I can't resolve [message #424578] Thu, 30 October 2008 10:38 Go to next message
I have a fairly simple model, all containment relationships. I populate
the resource from an asynchronous source of messages that correspond,
more or less, to classes in my model. So I basically receive a message,
create the model object, update the attributes and add to containing
object and commit or save the resource. Recently I started getting the
following exception after only a few 10s or maybe a hundred commits. The
only recent change in the frequency of the message has increased a bit.
I have tried 'moving' the commits around and doing more of them, like
after every model change, with no luck.
What does this mean exactly..?
Exception in thread "main"
org.eclipse.net4j.util.transaction.TransactionException: Can not
retrieve origin revision for
org.eclipse.emf.cdo.internal.common.revision.delta.CDORevisi onDeltaImpl @421350
at
org.eclipse.emf.internal.cdo.CDOTransactionImpl.commit(CDOTr ansactionImpl.java:243)
at dm.util.DmModelManager.save(DmModelManager.java:189)
at cse.dm.modelManager.DmOriginal.findPidObject(DmOriginal.java :78)
at
cse.dm.modelManager.DmOriginal.processMessageOriginal(DmOrig inal.java:49)
at cse.dm.modelManager.DmClient.main(DmClient.java:176)
Mark.
Re: [CDO] problem I can't resolve [message #424579 is a reply to message #424578] Thu, 30 October 2008 10:46 Go to previous messageGo to next message
Hi Mark,
which version of CDO are you using.
We fixed some problems related to them in
243282: java.lang.IllegalStateException with MEMStore
https://bugs.eclipse.org/bugs/show_bug.cgi?id=243282
Simon
> at
> at
> Mark.
Re: [CDO] problem I can't resolve [message #424580 is a reply to message #424579] Thu, 30 October 2008 10:49 Go to previous messageGo to next message
Simon,
I am running 1.0.2 on the client side, but I think 1.0.0, the Ganymede
version, on the server side.
Mark.
Simon McDuff wrote:
> Hi Mark,
> Simon
>> at
>> at
>> Mark.
Re: [CDO] problem I can't resolve [message #424581 is a reply to message #424580] Thu, 30 October 2008 11:06 Go to previous messageGo to next message
That problem (if it is the same) was fixed in 1.0.1.
Can you used 1.0.2 on the client and server ?
Simon
Mark Geib wrote:
> Simon,
> Mark.
> Simon McDuff wrote:
>> Hi Mark,
>> Simon
>>> at
>>> at
>>> Mark.
Re: [CDO] problem I can't resolve [message #424582 is a reply to message #424581] Thu, 30 October 2008 11:12 Go to previous messageGo to next message
Will do. I will post back my findings.
Mark.
> Simon
> Mark Geib wrote:
>> Simon,
>> Mark.
>> Simon McDuff wrote:
>>> Hi Mark,
>>> Simon
>>>> The
>>>> at
>>>> at
>>>> Mark.
Re: [CDO] problem I can't resolve [message #424597 is a reply to message #424582] Thu, 30 October 2008 15:54 Go to previous messageGo to next message
Simon,
The exception is different now, but still seems to occur at the commit
after I add/put and Entry into a Hashmap collection. That is the
TransactionDbs class in the model uses an instance class name of
java.util.Map$Entry so I can access the collection as a Hashmap using
key-value pairs.
The call ...
modelHeader.getTransactionsDbs().put(new Integer(index),
modelTransaction);
DmModelManager.access().save();
results in ...
org.eclipse.net4j.util.transaction.TransactionException: Index: 1, Size: 0
at
org.eclipse.emf.internal.cdo.CDOTransactionImpl.commit(CDOTr ansactionImpl.java:246)
at
cse.dm.modelManager.DmOriginal.processTransactionOriginal(Dm Original.java:223)
at
cse.dm.modelManager.DmOriginal.processSectionOriginal(DmOrig inal.java:154)
at
cse.dm.modelManager.DmOriginal.processMessageOriginal(DmOrig inal.java:50)
Mark.
> Mark.
>> Simon
>> Mark Geib wrote:
>>> Simon,
>>> Mark.
>>> Simon McDuff wrote:
>>>> Hi Mark,
>>>> Simon
>>>>> The
>>>>> at
>>>>> at
>>>>> Mark.
Re: [CDO] problem I can't resolve [message #424598 is a reply to message #424597] Thu, 30 October 2008 15:55 Go to previous messageGo to next message
Sorry, this is now with 1.0.2 of CDO and NET4J on both client and server
side.
Mark.
Mark Geib wrote:
> Simon,
> key-value pairs.
> The call ...
> modelTransaction);
> results in ...
> at
> at
> at
> at
> Mark.
>> Thanks,
>> Mark.
>>> Simon
>>> Mark Geib wrote:
>>>> Simon,
>>>> Mark.
>>>> Simon McDuff wrote:
>>>>> Hi Mark,
>>>>> Simon
>>>>>> The
>>>>>> at
>>>>>> at
>>>>>> Mark.
Re: [CDO] problem I can't resolve [message #424599 is a reply to message #424598] Thu, 30 October 2008 16:14 Go to previous messageGo to next message
Looks like I am getting this exception in other places as well, not just
putting to a Hashmap, put just adding to a reference list...
Mark.
> side.
> Mark.
> Mark Geib wrote:
>> Simon,
>> key-value pairs.
>> The call ...
>> modelTransaction);
>> results in ...
>> at
>> at
>> at
>> at
>> Mark.
>>> Thanks,
>>> Mark.
>>>> Simon
>>>> Mark Geib wrote:
>>>>> Simon,
>>>>> Mark.
>>>>> Simon McDuff wrote:
>>>>>> Hi Mark,
>>>>>> Simon
>>>>>>> The
>>>>>>> at
>>>>>>> at
>>>>>>> Mark.
Re: [CDO] problem I can't resolve [message #424600 is a reply to message #424599] Thu, 30 October 2008 16:23 Go to previous messageGo to next message
Question: Did you configure your application with SetReferenceChunkSize ?
If you can have the stack trace at the server side would be great!!
Simon
> Mark.
>> side.
>> Mark.
>> Mark Geib wrote:
>>> Simon,
>>> key-value pairs.
>>> The call ...
>>> modelTransaction);
>>> results in ...
>>> at
>>> at
>>> at
>>> at
>>> Mark.
>>>> Thanks,
>>>> Mark.
>>>>> Simon
>>>>> Mark Geib wrote:
>>>>>> Simon,
>>>>>> Mark.
>>>>>> Simon McDuff wrote:
>>>>>>> Hi Mark,
>>>>>>> Simon
>>>>>>>> The
>>>>>>>> at
>>>>>>>> at
>>>>>>>> Mark.
Re: [CDO] problem I can't resolve [message #424601 is a reply to message #424600] Thu, 30 October 2008 16:23 Go to previous messageGo to next message
No on the SetReferenceChunkSize, should I??
I will get the server side logs soon.
Mark.
> Simon
>> Mark.
>>> side.
>>> Mark.
>>> Mark Geib wrote:
>>>> Simon,
>>>> key-value pairs.
>>>> The call ...
>>>> modelTransaction);
>>>> results in ...
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Mark.
>>>>> Thanks,
>>>>> Mark.
>>>>>> Simon
>>>>>> Mark Geib wrote:
>>>>>>> Simon,
>>>>>>> Ganymede
>>>>>>> Mark.
>>>>>>> Simon McDuff wrote:
>>>>>>>> Hi Mark,
>>>>>>>> Simon
>>>>>>>>> populate
>>>>>>>>> correspond,
>>>>>>>>> message,
>>>>>>>>> containing
>>>>>>>>> getting the
>>>>>>>>> commits.
>>>>>>>>> The
>>>>>>>>> increased a bit.
>>>>>>>>> them, like
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> Mark.
Re: [CDO] problem I can't resolve [message #424602 is a reply to message #424601] Thu, 30 October 2008 16:41 Go to previous messageGo to next message
Mark,
Comments below...
Have a look at our amazing wiki article on tweaking CDO performance:
http://wiki.eclipse.org/Tweaking_CDO_Performance
Since Simon already takes care of your particular issue, I just want to
mention that many of the bugs we solved since Ganymede did not make
their way into the maintenance stream because the APIs are partly
changed dramatically (not to speak about the internal implementation).
Cheers
/Eike
http://wiki.eclipse.org/CDO
http://wiki.eclipse.org/Net4j
> Mark.
>> Simon
>>> Mark.
>>>> side.
>>>> Mark.
>>>> Mark Geib wrote:
>>>>> Simon,
>>>>> key-value pairs.
>>>>> The call ...
>>>>> modelTransaction);
>>>>> results in ...
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Mark.
>>>>>> Thanks,
>>>>>> Mark.
>>>>>>> Simon
>>>>>>> Mark Geib wrote:
>>>>>>>> Simon,
>>>>>>>> Ganymede
>>>>>>>> Mark.
>>>>>>>> Simon McDuff wrote:
>>>>>>>>> Hi Mark,
>>>>>>>>> Simon
>>>>>>>>>> populate
>>>>>>>>>> correspond,
>>>>>>>>>> message,
>>>>>>>>>> containing
>>>>>>>>>> getting the
>>>>>>>>>> commits.
>>>>>>>>>> The
>>>>>>>>>> increased a bit.
>>>>>>>>>> them, like
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> Mark.
Re: [CDO] problem I can't resolve [message #424603 is a reply to message #424601] Thu, 30 October 2008 16:50 Go to previous messageGo to next message
Not specifically! SetReferenceChunkSize.
Just to know the context.
Simon
> Mark.
>> Simon
>>> Mark.
>>>> side.
>>>> Mark.
>>>> Mark Geib wrote:
>>>>> Simon,
>>>>> key-value pairs.
>>>>> The call ...
>>>>> modelTransaction);
>>>>> results in ...
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Mark.
>>>>>> Thanks,
>>>>>> Mark.
>>>>>>> Simon
>>>>>>> Mark Geib wrote:
>>>>>>>> Simon,
>>>>>>>> Ganymede
>>>>>>>> Mark.
>>>>>>>> Simon McDuff wrote:
>>>>>>>>> Hi Mark,
>>>>>>>>> Simon
>>>>>>>>>> populate
>>>>>>>>>> correspond,
>>>>>>>>>> message,
>>>>>>>>>> containing
>>>>>>>>>> getting the
>>>>>>>>>> commits.
>>>>>>>>>> The
>>>>>>>>>> increased a bit.
>>>>>>>>>> them, like
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> Mark.
Re: [CDO] problem I can't resolve [message #424604 is a reply to message #424602] Thu, 30 October 2008 16:58 Go to previous messageGo to next message
Eike,
I will take a look.
We are not able, at least now, to migrate to newer Eclipse/EMF/CDO/...
We are forced to stay with Ganymede family for near future.
Thanks for the info.
Mark.
Eike Stepper wrote:
> Mark,
> Comments below...
> Cheers
> /Eike
>> Mark.
>>> Simon
>>>> just
>>>> Mark.
>>>>> server
>>>>> side.
>>>>> Mark.
>>>>> Mark Geib wrote:
>>>>>> Simon,
>>>>>> commit
>>>>>> key-value pairs.
>>>>>> The call ...
>>>>>> modelTransaction);
>>>>>> results in ...
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Mark.
>>>>>>> Thanks,
>>>>>>> Mark.
>>>>>>>> Simon
>>>>>>>> Mark Geib wrote:
>>>>>>>>> Simon,
>>>>>>>>> Ganymede
>>>>>>>>> Mark.
>>>>>>>>> Simon McDuff wrote:
>>>>>>>>>> Hi Mark,
>>>>>>>>>> Simon
>>>>>>>>>>> populate
>>>>>>>>>>> correspond,
>>>>>>>>>>> message,
>>>>>>>>>>> containing
>>>>>>>>>>> getting the
>>>>>>>>>>> commits.
>>>>>>>>>>> The
>>>>>>>>>>> increased a bit.
>>>>>>>>>>> them, like
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> Mark.
Re: [CDO] problem I can't resolve [message #424605 is a reply to message #424600] Thu, 30 October 2008 17:30 Go to previous messageGo to next message
Server side trace:
[INFO] CDO Server starting
[INFO] CDO Server started
[ERROR] Index: 7, Size: 0
java.lang.IndexOutOfBoundsException: Index: 7, Size: 0
at java.util.ArrayList.add(ArrayList.java:367)
at
org.eclipse.emf.cdo.internal.common.revision.delta.CDOAddFea tureDeltaImpl.apply(CDOAddFeatureDeltaImpl.java:48)
at
org.eclipse.emf.cdo.internal.common.revision.delta.CDOListFe atureDeltaImpl.apply(CDOListFeatureDeltaImpl.java:109)
at
org.eclipse.emf.cdo.internal.common.revision.delta.CDORevisi onDeltaImpl.apply(CDORevisionDeltaImpl.java:141)
at
org.eclipse.emf.cdo.internal.server.Transaction.computeDirty Object(Transaction.java:305)
at
org.eclipse.emf.cdo.internal.server.Transaction.computeDirty Objects(Transaction.java:287)
at
org.eclipse.emf.cdo.internal.server.Transaction.commit(Trans action.java:179)
at
org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicating(CommitTransactionIndication.java:109 )
at
org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:46)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:143)
at org.eclipse.net4j.signal.Signal.run(Signal.java:124)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:886)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Mark.
> Simon
>> Mark.
>>> side.
>>> Mark.
>>> Mark Geib wrote:
>>>> Simon,
>>>> key-value pairs.
>>>> The call ...
>>>> modelTransaction);
>>>> results in ...
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Mark.
>>>>> Thanks,
>>>>> Mark.
>>>>>> Simon
>>>>>> Mark Geib wrote:
>>>>>>> Simon,
>>>>>>> Ganymede
>>>>>>> Mark.
>>>>>>> Simon McDuff wrote:
>>>>>>>> Hi Mark,
>>>>>>>> Simon
>>>>>>>>> populate
>>>>>>>>> correspond,
>>>>>>>>> message,
>>>>>>>>> containing
>>>>>>>>> getting the
>>>>>>>>> commits.
>>>>>>>>> The
>>>>>>>>> increased a bit.
>>>>>>>>> them, like
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> Mark.
Re: [CDO] problem I can't resolve [message #424608 is a reply to message #424605] Thu, 30 October 2008 18:50 Go to previous messageGo to next message
Thank you Mark,
I think we should continue in a bugzilla. Can you open one please?
I will start recreating the problem. I will assume you are using DBStore
with Mysql. if not let me know.
Simon
Mark Geib wrote:
> Server side trace:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Mark.
>> Simon
>>> Mark.
>>>> side.
>>>> Mark.
>>>> Mark Geib wrote:
>>>>> Simon,
>>>>> key-value pairs.
>>>>> The call ...
>>>>> modelTransaction);
>>>>> results in ...
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Mark.
>>>>>> Thanks,
>>>>>> Mark.
>>>>>>> Simon
>>>>>>> Mark Geib wrote:
>>>>>>>> Simon,
>>>>>>>> Ganymede
>>>>>>>> Mark.
>>>>>>>> Simon McDuff wrote:
>>>>>>>>> Hi Mark,
>>>>>>>>> Simon
>>>>>>>>>> populate
>>>>>>>>>> correspond,
>>>>>>>>>> message,
>>>>>>>>>> containing
>>>>>>>>>> getting the
>>>>>>>>>> commits.
>>>>>>>>>> The
>>>>>>>>>> increased a bit.
>>>>>>>>>> them, like
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> Mark.
Re: [CDO] problem I can't resolve [message #424609 is a reply to message #424608] Thu, 30 October 2008 19:04 Go to previous messageGo to next message
Yes DBStore with mysql.
I will open bugzilla..
Mark.
Simon McDuff wrote:
> Thank you Mark,
> Simon
> Mark Geib wrote:
>> Server side trace:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Mark.
>>> Simon
>>>> just
>>>> Mark.
>>>>> server
>>>>> side.
>>>>> Mark.
>>>>> Mark Geib wrote:
>>>>>> Simon,
>>>>>> commit
>>>>>> key-value pairs.
>>>>>> The call ...
>>>>>> modelTransaction);
>>>>>> results in ...
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Mark.
>>>>>>> Thanks,
>>>>>>> Mark.
>>>>>>>> Simon
>>>>>>>> Mark Geib wrote:
>>>>>>>>> Simon,
>>>>>>>>> Ganymede
>>>>>>>>> Mark.
>>>>>>>>> Simon McDuff wrote:
>>>>>>>>>> Hi Mark,
>>>>>>>>>> Simon
>>>>>>>>>>> populate
>>>>>>>>>>> correspond,
>>>>>>>>>>> message,
>>>>>>>>>>> containing
>>>>>>>>>>> getting the
>>>>>>>>>>> commits.
>>>>>>>>>>> The
>>>>>>>>>>> increased a bit.
>>>>>>>>>>> them, like
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> Mark.
Re: [CDO] problem I can't resolve [message #425230 is a reply to message #424609] Thu, 20 November 2008 06:08 Go to previous messageGo to next message
I encouter the same problem.
I use one transaction with lot of data (hundreds of add and
modification). If I commit the transaction at the end of my application
there is no problem. But if I commit the transaction every 10
modifications, I have the exception :
at
I'm working with CDO 1.0.0 on both client and server side
I patched (https://bugs.eclipse.org/bugs/show_bug.cgi?id=243282) the
server but i have the same problem.
Mark, I don't find the corresponding bugzilla ? Have you created it ?
David
> Mark.
> Simon McDuff wrote:
>> Thank you Mark,
>> Simon
>> Mark Geib wrote:
>>> Server side trace:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Mark.
>>>> Simon
>>>>> just
>>>>> Mark.
>>>>>> server
>>>>>> side.
>>>>>> Mark.
>>>>>> Mark Geib wrote:
>>>>>>> Simon,
>>>>>>> commit
>>>>>>> key-value pairs.
>>>>>>> The call ...
>>>>>>> modelTransaction);
>>>>>>> results in ...
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Mark.
>>>>>>>> Thanks,
>>>>>>>> Mark.
>>>>>>>>> Simon
>>>>>>>>> Mark Geib wrote:
>>>>>>>>>> Simon,
>>>>>>>>>> Ganymede
>>>>>>>>>> Mark.
>>>>>>>>>> Simon McDuff wrote:
>>>>>>>>>>> Hi Mark,
>>>>>>>>>>> Simon
>>>>>>>>>>>> populate
>>>>>>>>>>>> correspond,
>>>>>>>>>>>> message,
>>>>>>>>>>>> containing
>>>>>>>>>>>> getting the
>>>>>>>>>>>> commits.
>>>>>>>>>>>> The
>>>>>>>>>>>> increased a bit.
>>>>>>>>>>>> them, like
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> Mark.
Re: [CDO] problem I can't resolve [message #425231 is a reply to message #425230] Thu, 20 November 2008 06:49 Go to previous messageGo to next message
Hi David,
The fix is available for each branch
for Branch 1.0.x
252982: [DB] exception when trying to commit changes
https://bugs.eclipse.org/bugs/show_bug.cgi?id=252982
for branch 2.0
https://bugs.eclipse.org/bugs/show_bug.cgi?id=252909
We release a maintenance release to fix that issue.
Could you use maintenance 1.0.3 ?
Simon
David Bonneau wrote:
> Hi
> at
> David
>> Mark.
>> Simon McDuff wrote:
>>> Thank you Mark,
>>> Simon
>>> Mark Geib wrote:
>>>> Server side trace:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Mark.
>>>>> Simon
>>>>>> just
>>>>>> Mark.
>>>>>>> server
>>>>>>> side.
>>>>>>> Mark.
>>>>>>> Mark Geib wrote:
>>>>>>>> Simon,
>>>>>>>> commit
>>>>>>>> using
>>>>>>>> key-value pairs.
>>>>>>>> The call ...
>>>>>>>> modelTransaction);
>>>>>>>> results in ...
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> Mark.
>>>>>>>>> Thanks,
>>>>>>>>> Mark.
>>>>>>>>>> Simon
>>>>>>>>>> Mark Geib wrote:
>>>>>>>>>>> Simon,
>>>>>>>>>>> Ganymede
>>>>>>>>>>> Mark.
>>>>>>>>>>> Simon McDuff wrote:
>>>>>>>>>>>> Hi Mark,
>>>>>>>>>>>> Simon
>>>>>>>>>>>>> populate
>>>>>>>>>>>>> correspond,
>>>>>>>>>>>>> message,
>>>>>>>>>>>>> containing
>>>>>>>>>>>>> getting the
>>>>>>>>>>>>> commits.
>>>>>>>>>>>>> The
>>>>>>>>>>>>> increased a bit.
>>>>>>>>>>>>> them, like
>>>>>>>>>>>>> Can not
>>>>>>>>>>>>> at
>>>>>>>>>>>>> at
>>>>>>>>>>>>> at
>>>>>>>>>>>>> Mark.
Re: [CDO] problem I can't resolve [message #425237 is a reply to message #425231] Thu, 20 November 2008 09:08 Go to previous messageGo to next message
Ok thanks !
How can I upgrade easily to maintenance 1.0.3 build ? I try to download
the sdk and dependencies, then drop in dropins folder of my ganymede
installation, but it doesn't work ! Is there an update site ? (I don't
find it).
I also try with a clean install, with the emf-cdo-runtime-1.0.3, with an
"eclipse -clean",... It still doesn't work :(
David
Simon McDuff a écrit :
> Hi David,
> for Branch 1.0.x
> for branch 2.0
> Simon
>> Hi
>> application there is no problem. But if I commit the transaction every
>> 10 modifications, I have the exception :
>> at
>> David
>>> Mark.
>>> Simon McDuff wrote:
>>>> Thank you Mark,
>>>> DBStore
>>>> Simon
>>>> Mark Geib wrote:
>>>>> Server side trace:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Mark.
>>>>>> Simon
>>>>>>> just
>>>>>>> Mark.
>>>>>>>> server
>>>>>>>> side.
>>>>>>>> Mark.
>>>>>>>> Mark Geib wrote:
>>>>>>>>> Simon,
>>>>>>>>> commit
>>>>>>>>> using
>>>>>>>>> key-value pairs.
>>>>>>>>> The call ...
>>>>>>>>> modelTransaction);
>>>>>>>>> results in ...
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> Mark.
>>>>>>>>>> Thanks,
>>>>>>>>>> Mark.
>>>>>>>>>>> Simon
>>>>>>>>>>> Mark Geib wrote:
>>>>>>>>>>>> Simon,
>>>>>>>>>>>> Ganymede
>>>>>>>>>>>> Mark.
>>>>>>>>>>>> Simon McDuff wrote:
>>>>>>>>>>>>> Hi Mark,
>>>>>>>>>>>>> Simon
>>>>>>>>>>>>>> relationships. I
>>>>>>>>>>>>>> populate
>>>>>>>>>>>>>> correspond,
>>>>>>>>>>>>>> receive a
>>>>>>>>>>>>>> message,
>>>>>>>>>>>>>> containing
>>>>>>>>>>>>>> getting the
>>>>>>>>>>>>>> commits.
>>>>>>>>>>>>>> The
>>>>>>>>>>>>>> increased a bit.
>>>>>>>>>>>>>> them, like
>>>>>>>>>>>>>> Can not
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> Mark.
Re: [CDO] problem I can't resolve [message #425239 is a reply to message #425237] Thu, 20 November 2008 09:46 Go to previous messageGo to next message
Hi David,
> Ok thanks !
> find it).
We do not have an update site!! :-)
Did you unzip them ?
Be sure to remove the old one.
Also, go look under
-Windows/Preferences
After
- Plug-in Dev/Target Platform if the right version is there!
Simon
> David
>> Hi David,
>> for Branch 1.0.x
>> for branch 2.0
>> Simon
>>> Hi
>>> every 10 modifications, I have the exception :
>>> at
>>> David
>>>> Mark.
>>>> Simon McDuff wrote:
>>>>> Thank you Mark,
>>>>> DBStore
>>>>> Simon
>>>>> Mark Geib wrote:
>>>>>> Server side trace:
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Mark.
>>>>>>> Simon
>>>>>>>> just
>>>>>>>> Mark.
>>>>>>>>> server
>>>>>>>>> side.
>>>>>>>>> Mark.
>>>>>>>>> Mark Geib wrote:
>>>>>>>>>> Simon,
>>>>>>>>>> commit
>>>>>>>>>> Hashmap using
>>>>>>>>>> key-value pairs.
>>>>>>>>>> The call ...
>>>>>>>>>> modelTransaction);
>>>>>>>>>> results in ...
>>>>>>>>>> Index: 1,
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> Mark.
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Mark.
>>>>>>>>>>>> Simon
>>>>>>>>>>>> Mark Geib wrote:
>>>>>>>>>>>>> Simon,
>>>>>>>>>>>>> Ganymede
>>>>>>>>>>>>> Mark.
>>>>>>>>>>>>> Simon McDuff wrote:
>>>>>>>>>>>>>> Hi Mark,
>>>>>>>>>>>>>> Simon
>>>>>>>>>>>>>>> relationships. I
>>>>>>>>>>>>>>> populate
>>>>>>>>>>>>>>> correspond,
>>>>>>>>>>>>>>> receive a
>>>>>>>>>>>>>>> message,
>>>>>>>>>>>>>>> containing
>>>>>>>>>>>>>>> getting the
>>>>>>>>>>>>>>> commits.
>>>>>>>>>>>>>>> The
>>>>>>>>>>>>>>> increased a bit.
>>>>>>>>>>>>>>> them, like
>>>>>>>>>>>>>>> Can not
>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>> Mark.
Re: [CDO] problem I can't resolve [message #425240 is a reply to message #425239] Thu, 20 November 2008 10:52 Go to previous messageGo to next message
Thanks a lot !
I'm a newbie on eclipse and I forgot to remove the old plugins ...
I upgraded cdo and net4j from 1.0.0 to 1.0.3
But now, I have another error on the server :
[ERROR] ClassRef unresolveable:
CDOClassRef(http://www.example.com/expression, 22)
java.lang.IllegalStateException: ClassRef unresolveable:
at
org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl . <init>(CDORevisionImpl.java:117)
at
org.eclipse.emf.cdo.common.revision.CDORevisionUtil.read(CDO RevisionUtil.java:48)
at
org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicating(CommitTransactionIndication.java:95)
at
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:885)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:907)
It looks like
http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg3 5056.html
Is it the same problem ?
David
> Hi David,
>> Ok thanks !
>> download the sdk and dependencies, then drop in dropins folder of my
>> ganymede installation, but it doesn't work ! Is there an update site ?
>> (I don't find it).
>> an "eclipse -clean",... It still doesn't work :(
> Also, go look under
> After
> Simon
>> David
>>> Hi David,
>>> for Branch 1.0.x
>>> for branch 2.0
>>> Simon
>>>> Hi
>>>> at
>>>> David
>>>>> Mark.
>>>>> Simon McDuff wrote:
>>>>>> Thank you Mark,
>>>>>> DBStore
>>>>>> Simon
>>>>>> Mark Geib wrote:
>>>>>>> Server side trace:
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Mark.
>>>>>>>> Simon
>>>>>>>>> not
>>>>>>>>> just
>>>>>>>>> Mark.
>>>>>>>>>> server
>>>>>>>>>> side.
>>>>>>>>>> Mark.
>>>>>>>>>> Mark Geib wrote:
>>>>>>>>>>> Simon,
>>>>>>>>>>> commit
>>>>>>>>>>> Hashmap using
>>>>>>>>>>> key-value pairs.
>>>>>>>>>>> The call ...
>>>>>>>>>>> modelTransaction);
>>>>>>>>>>> results in ...
>>>>>>>>>>> Index: 1,
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> Mark.
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Mark.
>>>>>>>>>>>>> Simon
>>>>>>>>>>>>> Mark Geib wrote:
>>>>>>>>>>>>>> Simon,
>>>>>>>>>>>>>> Ganymede
>>>>>>>>>>>>>> Mark.
>>>>>>>>>>>>>> Simon McDuff wrote:
>>>>>>>>>>>>>>> Hi Mark,
>>>>>>>>>>>>>>> Simon
>>>>>>>>>>>>>>>> relationships. I
>>>>>>>>>>>>>>>> populate
>>>>>>>>>>>>>>>> correspond,
>>>>>>>>>>>>>>>> receive a
>>>>>>>>>>>>>>>> message,
>>>>>>>>>>>>>>>> containing
>>>>>>>>>>>>>>>> getting the
>>>>>>>>>>>>>>>> commits.
>>>>>>>>>>>>>>>> The
>>>>>>>>>>>>>>>> increased a bit.
>>>>>>>>>>>>>>>> them, like
>>>>>>>>>>>>>>>> Can not
>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>> Mark.
Re: [CDO] problem I can't resolve [message #425241 is a reply to message #425240] Thu, 20 November 2008 11:05 Go to previous messageGo to next message
HUmm.. this seems to be related with missing packages..or packages that
evolve..
Did your model changed since you did previous commit ?
A good test to know is to restart from a fresh database...(as a test)
Simon
> Thanks a lot !
> at
> at
> at
> at
> at
> at
> It looks like
> David
>> Hi David,
>>> Ok thanks !
>>> ? (I don't find it).
>> Also, go look under
>> After
>> Simon
>>> David
>>>> Hi David,
>>>> for Branch 1.0.x
>>>> for branch 2.0
>>>> Simon
>>>>> Hi
>>>>> at
>>>>> the server but i have the same problem.
>>>>> David
>>>>>> Mark.
>>>>>> Simon McDuff wrote:
>>>>>>> Thank you Mark,
>>>>>>> DBStore
>>>>>>> Simon
>>>>>>> Mark Geib wrote:
>>>>>>>> Server side trace:
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> Mark.
>>>>>>>>> great!!
>>>>>>>>> Simon
>>>>>>>>>> well, not
>>>>>>>>>> just
>>>>>>>>>> Mark.
>>>>>>>>>>> and
>>>>>>>>>>> server
>>>>>>>>>>> side.
>>>>>>>>>>> Mark.
>>>>>>>>>>> Mark Geib wrote:
>>>>>>>>>>>> Simon,
>>>>>>>>>>>> commit
>>>>>>>>>>>> the
>>>>>>>>>>>> name of
>>>>>>>>>>>> Hashmap using
>>>>>>>>>>>> key-value pairs.
>>>>>>>>>>>> The call ...
>>>>>>>>>>>> modelTransaction);
>>>>>>>>>>>> results in ...
>>>>>>>>>>>> Index: 1,
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> Mark.
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Mark.
>>>>>>>>>>>>>> Simon
>>>>>>>>>>>>>> Mark Geib wrote:
>>>>>>>>>>>>>>> Simon,
>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>> Ganymede
>>>>>>>>>>>>>>> Mark.
>>>>>>>>>>>>>>> Simon McDuff wrote:
>>>>>>>>>>>>>>>> Hi Mark,
>>>>>>>>>>>>>>>> Simon
>>>>>>>>>>>>>>>>> relationships. I
>>>>>>>>>>>>>>>>> populate
>>>>>>>>>>>>>>>>> correspond,
>>>>>>>>>>>>>>>>> receive a
>>>>>>>>>>>>>>>>> message,
>>>>>>>>>>>>>>>>> containing
>>>>>>>>>>>>>>>>> getting the
>>>>>>>>>>>>>>>>> hundred
>>>>>>>>>>>>>>>>> commits.
>>>>>>>>>>>>>>>>> The
>>>>>>>>>>>>>>>>> increased a bit.
>>>>>>>>>>>>>>>>> them, like
>>>>>>>>>>>>>>>>> Can not
>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>> Mark.
Re: [CDO] problem I can't resolve [message #425242 is a reply to message #425241] Thu, 20 November 2008 11:19 Go to previous messageGo to next message
> evolve..
My model is the same.
I re-start with an empty database and I have the illegalStateException
I didn't upgrade EMF, I'm still in 2.4.0. It could be a problem ?
> Simon
>> Thanks a lot !
>> at
>> at
>> at
>> at
>> at
>> at
>> It looks like
>> David
>>> Hi David,
>>>> Ok thanks !
>>>> with an "eclipse -clean",... It still doesn't work :(
>>> Also, go look under
>>> After
>>> Simon
>>>> David
>>>>> Hi David,
>>>>> for Branch 1.0.x
>>>>> for branch 2.0
>>>>> Simon
>>>>>> Hi
>>>>>> at
>>>>>> David
>>>>>>> Mark.
>>>>>>> Simon McDuff wrote:
>>>>>>>> Thank you Mark,
>>>>>>>> DBStore
>>>>>>>> Simon
>>>>>>>> Mark Geib wrote:
>>>>>>>>> Server side trace:
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> Mark.
>>>>>>>>>> great!!
>>>>>>>>>> Simon
>>>>>>>>>>> well, not
>>>>>>>>>>> just
>>>>>>>>>>> Mark.
>>>>>>>>>>>> client and
>>>>>>>>>>>> server
>>>>>>>>>>>> side.
>>>>>>>>>>>> Mark.
>>>>>>>>>>>> Mark Geib wrote:
>>>>>>>>>>>>> Simon,
>>>>>>>>>>>>> the
>>>>>>>>>>>>> commit
>>>>>>>>>>>>> is the
>>>>>>>>>>>>> name of
>>>>>>>>>>>>> Hashmap using
>>>>>>>>>>>>> key-value pairs.
>>>>>>>>>>>>> The call ...
>>>>>>>>>>>>> modelTransaction);
>>>>>>>>>>>>> results in ...
>>>>>>>>>>>>> Index: 1,
>>>>>>>>>>>>> at
>>>>>>>>>>>>> at
>>>>>>>>>>>>> at
>>>>>>>>>>>>> at
>>>>>>>>>>>>> Mark.
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> Mark.
>>>>>>>>>>>>>>> Simon
>>>>>>>>>>>>>>> Mark Geib wrote:
>>>>>>>>>>>>>>>> Simon,
>>>>>>>>>>>>>>>> 1.0.0, the
>>>>>>>>>>>>>>>> Ganymede
>>>>>>>>>>>>>>>> Mark.
>>>>>>>>>>>>>>>> Simon McDuff wrote:
>>>>>>>>>>>>>>>>> Hi Mark,
>>>>>>>>>>>>>>>>> Simon
>>>>>>>>>>>>>>>>>> relationships. I
>>>>>>>>>>>>>>>>>> populate
>>>>>>>>>>>>>>>>>> correspond,
>>>>>>>>>>>>>>>>>> receive a
>>>>>>>>>>>>>>>>>> message,
>>>>>>>>>>>>>>>>>> containing
>>>>>>>>>>>>>>>>>> started
>>>>>>>>>>>>>>>>>> getting the
>>>>>>>>>>>>>>>>>> hundred
>>>>>>>>>>>>>>>>>> commits.
>>>>>>>>>>>>>>>>>> The
>>>>>>>>>>>>>>>>>> increased a bit.
>>>>>>>>>>>>>>>>>> more of
>>>>>>>>>>>>>>>>>> them, like
>>>>>>>>>>>>>>>>>> Can not
>>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>>> Mark.
Re: [CDO] problem I can't resolve [message #425243 is a reply to message #425242] Thu, 20 November 2008 11:34 Go to previous messageGo to next message
Hi David,
First to be sure you've done the basic stuff:
Did you add the package to the session like the following:
cdoSession.getPackageRegistry().putEPackage(??);
if Yes, I will need more info to be able to reproduce the problem.
Can you explain me the steps to reproduce it ?
Which back-end are you using ?
Can you also provide me your ecore ?
Could be related to what you mention.. but also
249383: Dynamic models in the global EPackage.Registry are not committed
https://bugs.eclipse.org/bugs/show_bug.cgi?id=249383
Simon
>> that evolve..
>> Simon
>>> Thanks a lot !
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> It looks like
>>> David
>>>> Hi David,
>>>>> Ok thanks !
>>>>> my ganymede installation, but it doesn't work ! Is there an update
>>>>> site ? (I don't find it).
>>>> Also, go look under
>>>> After
>>>> Simon
>>>>> David
>>>>>> Hi David,
>>>>>> for Branch 1.0.x
>>>>>> for branch 2.0
>>>>>> Simon
>>>>>>> Hi
>>>>>>> at
>>>>>>> it ?
>>>>>>> David
>>>>>>>> Mark.
>>>>>>>> Simon McDuff wrote:
>>>>>>>>> Thank you Mark,
>>>>>>>>> using DBStore
>>>>>>>>> Simon
>>>>>>>>> Mark Geib wrote:
>>>>>>>>>> Server side trace:
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> Mark.
>>>>>>>>>>> great!!
>>>>>>>>>>> Simon
>>>>>>>>>>>> well, not
>>>>>>>>>>>> just
>>>>>>>>>>>> Mark.
>>>>>>>>>>>>> client and
>>>>>>>>>>>>> server
>>>>>>>>>>>>> side.
>>>>>>>>>>>>> Mark.
>>>>>>>>>>>>> Mark Geib wrote:
>>>>>>>>>>>>>> Simon,
>>>>>>>>>>>>>> at the
>>>>>>>>>>>>>> commit
>>>>>>>>>>>>>> is the
>>>>>>>>>>>>>> name of
>>>>>>>>>>>>>> Hashmap using
>>>>>>>>>>>>>> key-value pairs.
>>>>>>>>>>>>>> The call ...
>>>>>>>>>>>>>> modelTransaction);
>>>>>>>>>>>>>> results in ...
>>>>>>>>>>>>>> Index: 1,
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> at
>>>>>>>>>>>>>> Mark.
>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>> Mark.
>>>>>>>>>>>>>>>> Simon
>>>>>>>>>>>>>>>> Mark Geib wrote:
>>>>>>>>>>>>>>>>> Simon,
>>>>>>>>>>>>>>>>> 1.0.0, the
>>>>>>>>>>>>>>>>> Ganymede
>>>>>>>>>>>>>>>>> Mark.
>>>>>>>>>>>>>>>>> Simon McDuff wrote:
>>>>>>>>>>>>>>>>>> Hi Mark,
>>>>>>>>>>>>>>>>>> Simon
>>>>>>>>>>>>>>>>>>> relationships. I
>>>>>>>>>>>>>>>>>>> populate
>>>>>>>>>>>>>>>>>>> that
>>>>>>>>>>>>>>>>>>> correspond,
>>>>>>>>>>>>>>>>>>> receive a
>>>>>>>>>>>>>>>>>>> message,
>>>>>>>>>>>>>>>>>>> add to
>>>>>>>>>>>>>>>>>>> containing
>>>>>>>>>>>>>>>>>>> started
>>>>>>>>>>>>>>>>>>> getting the
>>>>>>>>>>>>>>>>>>> hundred
>>>>>>>>>>>>>>>>>>> commits.
>>>>>>>>>>>>>>>>>>> The
>>>>>>>>>>>>>>>>>>> increased a bit.
>>>>>>>>>>>>>>>>>>> more of
>>>>>>>>>>>>>>>>>>> them, like
>>>>>>>>>>>>>>>>>>> Can not
>>>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>>>> Mark.
Re: [CDO] problem I can't resolve [message #425246 is a reply to message #425243] Thu, 20 November 2008 12:21 Go to previous messageGo to next message
Simon,
I don't use session.getPackageRegistry().putEPackage(...), but
CDOSessionConfiguration.setDemandPopulatingPackageRegistry() ;
I will try to reproduce the problem with a little unit test.
Thank you for your help !
David
> Hi David,
> Simon
>>> that evolve..
>>> Simon
>>>> Thanks a lot !
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> It looks like
>>>> David
>>>>> Hi David,
>>>>>> Ok thanks !
>>>>> Also, go look under
>>>>> After
>>>>> Simon
>>>>>> David
>>>>>>> Hi David,
>>>>>>> for Branch 1.0.x
>>>>>>> for branch 2.0
>>>>>>> Simon
>>>>>>>> Hi
>>>>>>>> at
>>>>>>>> it ?
>>>>>>>> David
>>>>>>>>> Mark.
>>>>>>>>> Simon McDuff wrote:
>>>>>>>>>> Thank you Mark,
>>>>>>>>>> please?
>>>>>>>>>> using DBStore
>>>>>>>>>> Simon
>>>>>>>>>> Mark Geib wrote:
>>>>>>>>>>> Server side trace:
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> Mark.
>>>>>>>>>>>> great!!
>>>>>>>>>>>> Simon
>>>>>>>>>>>>> well, not
>>>>>>>>>>>>> just
>>>>>>>>>>>>> Mark.
>>>>>>>>>>>>>> client and
>>>>>>>>>>>>>> server
>>>>>>>>>>>>>> side.
>>>>>>>>>>>>>> Mark.
>>>>>>>>>>>>>> Mark Geib wrote:
>>>>>>>>>>>>>>> Simon,
>>>>>>>>>>>>>>> at the
>>>>>>>>>>>>>>> commit
>>>>>>>>>>>>>>> is the
>>>>>>>>>>>>>>> name of
>>>>>>>>>>>>>>> Hashmap using
>>>>>>>>>>>>>>> key-value pairs.
>>>>>>>>>>>>>>> The call ...
>>>>>>>>>>>>>>> modelTransaction);
>>>>>>>>>>>>>>> results in ...
>>>>>>>>>>>>>>> Index: 1,
>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>> Mark.
>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>> Mark.
>>>>>>>>>>>>>>>>> Simon
>>>>>>>>>>>>>>>>> Mark Geib wrote:
>>>>>>>>>>>>>>>>>> Simon,
>>>>>>>>>>>>>>>>>> 1.0.0, the
>>>>>>>>>>>>>>>>>> Ganymede
>>>>>>>>>>>>>>>>>> Mark.
>>>>>>>>>>>>>>>>>> Simon McDuff wrote:
>>>>>>>>>>>>>>>>>>> Hi Mark,
>>>>>>>>>>>>>>>>>>> Simon
>>>>>>>>>>>>>>>>>>>> relationships. I
>>>>>>>>>>>>>>>>>>>> populate
>>>>>>>>>>>>>>>>>>>> that
>>>>>>>>>>>>>>>>>>>> correspond,
>>>>>>>>>>>>>>>>>>>> receive a
>>>>>>>>>>>>>>>>>>>> message,
>>>>>>>>>>>>>>>>>>>> add to
>>>>>>>>>>>>>>>>>>>> containing
>>>>>>>>>>>>>>>>>>>> started
>>>>>>>>>>>>>>>>>>>> getting the
>>>>>>>>>>>>>>>>>>>> hundred
>>>>>>>>>>>>>>>>>>>> commits.
>>>>>>>>>>>>>>>>>>>> The
>>>>>>>>>>>>>>>>>>>> increased a bit.
>>>>>>>>>>>>>>>>>>>> more of
>>>>>>>>>>>>>>>>>>>> them, like
>>>>>>>>>>>>>>>>>>>> Can not
>>>>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>>>>> Mark.
Re: [CDO] problem I can't resolve [message #425268 is a reply to message #425239] Fri, 21 November 2008 06:50 Go to previous message
David, Simon,
Comments below...
Simon McDuff schrieb:
> Hi David,
>> Ok thanks !
We do!
Although there is http://www.eclipse.org/modeling/emf/updates/ I have
the feeling that the Ganymede update site is more complete and more
up-to-date: http://download.eclipse.org/releases/ganymede/staging/
Be careful to install the needed third party components *in advance* :
http://wiki.eclipse.org/FAQ_for_CDO_and_Net4j#Why_does_p2_co mplain_about_unsatisfied_dependencies.3F
Cheers
/Eike
> Also, go look under
> After
> Simon
>> David
>>> Hi David,
>>> for Branch 1.0.x
>>> for branch 2.0
>>> Simon
>>>> Hi
>>>> at
>>>> David
>>>>> Mark.
>>>>> Simon McDuff wrote:
>>>>>> Thank you Mark,
>>>>>> DBStore
>>>>>> Simon
>>>>>> Mark Geib wrote:
>>>>>>> Server side trace:
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Mark.
>>>>>>>> great!!
>>>>>>>> Simon
>>>>>>>>> well, not
>>>>>>>>> just
>>>>>>>>> Mark.
>>>>>>>>>> and
>>>>>>>>>> server
>>>>>>>>>> side.
>>>>>>>>>> Mark.
>>>>>>>>>> Mark Geib wrote:
>>>>>>>>>>> Simon,
>>>>>>>>>>> commit
>>>>>>>>>>> the
>>>>>>>>>>> name of
>>>>>>>>>>> Hashmap using
>>>>>>>>>>> key-value pairs.
>>>>>>>>>>> The call ...
>>>>>>>>>>> modelTransaction);
>>>>>>>>>>> results in ...
>>>>>>>>>>> Index: 1,
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> Mark.
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Mark.
>>>>>>>>>>>>> Simon
>>>>>>>>>>>>> Mark Geib wrote:
>>>>>>>>>>>>>> Simon,
>>>>>>>>>>>>>> the
>>>>>>>>>>>>>> Ganymede
>>>>>>>>>>>>>> Mark.
>>>>>>>>>>>>>> Simon McDuff wrote:
>>>>>>>>>>>>>>> Hi Mark,
>>>>>>>>>>>>>>> Simon
>>>>>>>>>>>>>>>> relationships. I
>>>>>>>>>>>>>>>> populate
>>>>>>>>>>>>>>>> correspond,
>>>>>>>>>>>>>>>> receive a
>>>>>>>>>>>>>>>> message,
>>>>>>>>>>>>>>>> containing
>>>>>>>>>>>>>>>> getting the
>>>>>>>>>>>>>>>> hundred
>>>>>>>>>>>>>>>> commits.
>>>>>>>>>>>>>>>> The
>>>>>>>>>>>>>>>> increased a bit.
>>>>>>>>>>>>>>>> them, like
>>>>>>>>>>>>>>>> Can not
>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>> Mark.
Previous Topic:Issue with chunking in CDO
Next Topic:[Teneo] JpoxStoreException initializing dataStore when object uses Enumerator
Current Time: Sun Jul 20 22:26:32 EDT 2025
Powered by FUDForum. Page generated in 0.07428 seconds
