| Home » Eclipse Projects » SWTBot » UI deadlock when typing character with SWTKeyboardStrategy
 Goto Forum:|
| UI deadlock when typing character with SWTKeyboardStrategy [message #40829] | Fri, 26 June 2009 13:23  |  |
| Eclipse User  |  |  |  |  | Hi again,
 As you know, I'm using the typeText methods to simulate real user input
 and with the AltGr problem we are having, I started using the EN_US
 keyboard layout for the tests. I found out that the layout couldn't
 write the ' character with AWTKeyboardStrategy, so I started using
 SWTKeyboardStrategy; problem is, I'm getting UI deadlock.
 First, Display.post synchronize on the Device class (Display, line 2900)
 then obtains the display pointer with OS.GDK_DISPLAY() (Display, line
 2904). This method then lock on a field of the OS class and that's where
 the WorkbenchTestable thread (SWTBot's thread) holds.
 Meanwhile, in the UI thread, a paint event has been dispatched by SWT
 using OS.gtk_main_do_event (OS, line 5783) which holds the lock on the
 OS field. During the paint event handling, the widget being painted
 tries to access something (could be the GC, system color, anything, I
 got the deadlocks at different places) in the Display class: the class
 check for validity and tries to synchronize on the Device class before
 doing so, but this lock is hold by Display.post, on another thread. DEADLOCK
 I tried wrapping up the calls to my calls to typeText into syncExec and
 the text that was typed only appeared at the end of the exec. If a
 problem happens (and it did) then the UI is frozen.
 For now, I have fallen back to a custom AWTStrategy which map ' to
 KeyEvent.VK_QUOTE, but if anyone has any ideas about this issue, I would
 appreciate it.
 P
| Re: UI deadlock when typing character with SWTKeyboardStrategy [message #40860 is a reply to message #40829] | Fri, 26 June 2009 13:45   |  |
| Eclipse User  |  |  |  |  | I'd recommend opening a bug against SWT if you're sure that's the case. I'm not on GTK and can't reproduce this.
 Ketan
 http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
 On 26/6/09 22:53, Pascal Gelinas wrote:
 > Hi again,
 > DEADLOCK
 > appreciate it.
 > Regards,
 > P
 Current Time: Fri Oct 31 10:21:55 EDT 2025
 Powered by FUDForum . Page generated in 0.04292 seconds |
