Home » Eclipse Projects » SWTBot » Getting Exception starting swtbot with ant
Getting Exception starting swtbot with ant [message #40242] |
Tue, 23 June 2009 18:15  |
I get the following stacktrace starting my test swtbot-test with ant:
Can anyone please tell me, what I'm doing wrong,
Thank you, Greetings
Markus
java.lang.RuntimeException: Application
" org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplica tion " could
not be found in the registry. The applications available are:
org.eclipse.ant.core.antRunner, org.eclipse.equinox.app.error,
org.eclipse.equinox.p2.artifact.repository.mirrorApplication ,
org.eclipse.equinox.p2.director.app.application,
org.eclipse.equinox.p2.metadata.generator.EclipseGenerator,
org.eclipse.equinox.p2.metadata.repository.mirrorApplication ,
org.eclipse.equinox.p2.reconciler.application,
org.eclipse.help.base.infocenterApplication,
org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool,
org.eclipse.ui.ide.workbench, org.eclipse.update.core.standaloneUpdate,
org.eclipse.update.core.siteOptimizer,
org.eclipse.wst.server.preview.preview,
org.eclipse.wst.jsdt.core.JavaCodeFormatter, org.eclipse.pde.build.Build,
org.eclipse.swtbot.eclipse.core.swtbottestapplication,
org.eclipse.pde.junit.runtime.uitestapplication,
org.eclipse.pde.junit.runtime.legacytestapplication,
org.eclipse.pde.junit.runtime.coretestapplication,
org.eclipse.pde.junit.runtime.coretestapplicationnonmain,
org.eclipse.jdt.core.JavaCodeFormatter, org.eclipse.jdt.apt.core.aptBuild,
org.eclipse.emf.codegen.CodeGen, org.eclipse.emf.codegen.JMerger,
org.eclipse.emf.codegen.ecore.Generator,
org.eclipse.emf.importer.rose.Rose2GenModel,
org.eclipse.emf.importer.java.Java2GenModel,
org.eclipse.emf.importer.ecore.Ecore2GenModel,
org.eclipse.datatools.connectivity.console.profile.StorageFi leEditor,
org.eclipse.ant.ui.antRunner.
at
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:242)
at
org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
at org.eclipse.core.launcher.Main.main(Main.java:30)
Re: Getting Exception starting swtbot with ant [message #40533 is a reply to message #40242] |
Thu, 25 June 2009 14:58   |
Make sure your Eclipse you are running against has the SWTBot plugin
installed (headless and all) and make sure that you remove the junit3
entries (because from what I see, you want to use junit4).
Markus Oley wrote:
> Markus
> org.eclipse.jdt.apt.core.aptBuild, org.eclipse.emf.codegen.CodeGen,
> at
> at
> at
> at
> at
> at
> at
> at
Re: Getting Exception starting swtbot with ant [message #40620 is a reply to message #40557] |
Thu, 25 June 2009 15:34  |
Go on the download page of the project website
(http://www.eclipse.org/swtbot/downloads.php) and download the Headless
Testing Framework. That'll get you a zip file you need to unzip in your
eclipse directory.
Markus Oley wrote:
> Hi again,
> thank your for your answer....
> I don't know where to get all of the wanted plugins....
> I found the following: org.eclipse.swtbot.eclipse.core_2.0.0.320-dev.jar
> org.eclipse.swtbot.eclipse.finder_2.0.0.320-dev.jar
> org.eclipse.swtbot.eclipse.spy_2.0.0.320-dev.jar
> org.eclipse.swtbot.eclipse.ui_2.0.0.320-dev.jar
> org.eclipse.swtbot.junit4_x_2.0.0.320-dev.jar
> org.eclipse.swtbot.swt.finder_2.0.0.320-dev.jar
> my feature.jar doesn't define more jars - what jars do I need in
> addition and where do I get them?
> Thanks in advance
> Greetings
> Markus
Current Time: Sat Jul 19 00:29:14 EDT 2025
Powered by FUDForum. Page generated in 0.05066 seconds
