Home » Archived » BIRT » Hyperlink support
Hyperlink support [message #38207] Wed, 18 May 2005 12:18 Go to next message
say I render a report that contains multiple tables of data and one
column might be names and I want to be able to click on name to have it
take me to another rendered area of the report, or even another report
altogether.
how might this be accomplished, support in 2.0?
Re: Hyperlink support [message #38340 is a reply to message #38207] Wed, 18 May 2005 15:16 Go to previous messageGo to next message
You use Bookmark for links to areas in the same report; you use
drillthrough links to other reports. Bookmark support is in R1;
Drillthrough links are also working for normal cases. See the ROM spec for
detail.
Stanley Wang
BIRT Lead
Re: Hyperlink support [message #38406 is a reply to message #38207] Wed, 18 May 2005 16:13 Go to previous messageGo to next message
Mike,
The ROM specs envision a "bookmark" on each report item. The "action"
(hyperlink) property would be extended to target a bookmark within the same
report or another report. There is some implementation "magic" required when
BIRT supports multiple-page reports.
There is no support for this in Release 1, but it is on the wish-list for a
future release.
- Paul
Paul Rogers
BIRT PMC
"Mike Boyersmith" <mjboyers@us.ibm.com> wrote in message
news:d6fpub$8vp$1@news.eclipse.org...
> say I render a report that contains multiple tables of data and one column
> might be names and I want to be able to click on name to have it take me
> to another rendered area of the report, or even another report altogether.
Re: Hyperlink support [message #38501 is a reply to message #38406] Wed, 18 May 2005 17:14 Go to previous messageGo to next message
Thanks to both you guys for replies, a quick clarification
Do you mean there is no support at all in version 1 for the feature you
guys describe or just no support for multiple report and element hyper
linking?
> Mike,
> future release.
> - Paul
> Paul Rogers
> BIRT PMC
Re: Hyperlink support -- can't find info on Bookmarks [message #39427 is a reply to message #38340] Mon, 23 May 2005 19:04 Go to previous messageGo to next message
Hi Stanley!
I did a search for 'Bookmark' and 'Bookmarks' in the ROM spec at
http://www.eclipse.org/birt/ref/ROM_Scripting_SPEC.pdf
and the search didn't find anything... am I looking at the wrong spec?
> for detail.
> Stanley Wang
> BIRT Lead
Re: Hyperlink support -- can't find info on Bookmarks [message #40569 is a reply to message #39427] Tue, 24 May 2005 18:35 Go to previous messageGo to next message
Mike,
Hmmm... The bookmark property should be in the spec. However, it has not yet
been implemented. The idea is that "bookmark" is an expression that
evaluates to a string. The string provides an "anchor" position within the
report. In a simple HTML report, it would translate to an <a
name="yourExpr">...</a> tag.
Try the new on-line ROM documentation.
http://www.eclipse.org/birt/ref/rom/index.html
Scroll to the bottom to find the Property Index. The index shows that the
bookmark property is defined on ReportItem and Row. The bookmark property
info that was previously in the ROM specs has moved into this on-line ROM
documentation.
Then, check out the action property on Data, Label and Image for information
about how the bookmark will be used.
- Paul
Paul Rogers
BIRT PMC
news:d6tnn9$at$1@news.eclipse.org...
> Hi Stanley!
>> for detail.
>> Stanley Wang
>> BIRT Lead
Re: Hyperlink support [message #40993 is a reply to message #38501] Tue, 24 May 2005 21:42 Go to previous message
Bookmark is not supported in R1.
Linking to another report, however, can be worked out. You can set the
hyperlink property to an expression that evaluates to a URL that points to
another report.
Stanley Wang
BIRT Engine
Previous Topic:DataTypeMapping Question
Next Topic:JVM Terminated. Exit code=1
Current Time: Wed Sep 03 02:12:06 EDT 2025
Powered by FUDForum. Page generated in 0.06445 seconds
