Home » Archived » Buckminster » Changes to Headless Buckminster in Galileo M6 release
Changes to Headless Buckminster in Galileo M6 release [message #383551] |
Mon, 23 March 2009 16:01  |
--------------080105050306050502000002
First of all, please note that the following affects the headless
version of Buckminster for Eclipse 3.5 (Galileo) installation. Users on
3.4.x (Ganymede) will not be affected by what's described here.
Starting with the Galileo M6 release, we switched distribution method
for the headless support in Buckminster. The reason for this is that we
now abandon the deprecated old Update Manager to instead rely on P2.
This has two implications:
1. We cannot have more then one update site in one location since
site.xml files are no longer used. As many might have noticed already,
since P2 entered the scene, the Buckminster headless features have been
visible when installing new features using the IDE "Install New
Software" wizard. This is not desirable. So instead of the old sites:
download.eclipse.org/tools/buckminster/updates-3.5/site.xml
download.eclipse.org/tools/buckminster/updates-3.5/headless- site.xml
you will now see the P2 sites:
download.eclipse.org/tools/buckminster/headless-3.5/
The site.xml/headless-site.xml files are no longer provided.
2. The headless Buckminster product is self managed in the sense that it
is capable of updating itself by installing and uninstalling features.
This is nothing new, but in P2, such a product can not be platform
independent. An installation is always bound to a platform. This left us
with two choices; either we provide one product for each platform as a
zip, or we provide our product as a P2 Installable Unit (IU) from our
repo which we then require the end user to install. We chose the latter.
In order to support headless installation, we now also provide a
headless version of the P2 director application and since it is not
required that this installer can update itself, it can be provided as a
platform independent application. In a headless scenario, this installer
is the bootstrap to get Buckminster headless up and running.
So, how do you go about installing Buckminster then? Well, in short:
1. Download and unzip the director
2. Tell the director to install the buckminster product from the
headless repository.
More details can be found on our downloads page:
http://www.eclipse.org/buckminster/downloads.html
I have attached a build.xml that contains some useful macros/targets
that can be used from Apache Ant. A buckminster command script with a
sample configuration is also attached.
Documentation updates are pending and can be tracked here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=269736
Thomas Hallgren
Content-Type: text/xml;
name="build.xml"
Content-Disposition: inline;
filename="build.xml"
<?xml version="1.0"?>
* Copyright (c) 2006-2007, Cloudsmith Inc.
* The code, documentation and other materials contained herein have been
* licensed under the Eclipse Public License - v 1.0 by the copyright holder
* listed above, as the Initial Contributor under such license. The text of
* such license is available at www.eclipse.org.
<project name="project">
<!--Optional property file containing overrides for the default properties
<property file="build.properties" />
<!-- Default property settings
<property name="bm.headless.site" value="http://download.eclipse.org/tools/buckminster/headless-3.5/" />
<property name="buildtools" location="${user.home}/buildtools" />
<property name="product.config.script" location="product.config.bmscript" />
<!-- This macro executes the default application of an eclipse installation that resides
in the folder ${buildtools}/@app
<macrodef name="eclipse.launch">
<attribute name="app"/>
<element name="args" optional="true" />
<sequential>
<!-- We assume that the eclipse installation is beneath ${buildtools} -->
<property name="@{app}.deploy.dir" value="${buildtools}/@{app}"/>
<!-- Find the Eclipse launcher and assing its location to the @{app}.launcher property -->
<pathconvert property="@{app}.launcher">
<first count="1">
<sort>
<fileset dir="${@{app}.deploy.dir}/plugins" includes="**/org.eclipse.equinox.launcher_*.jar" />
<reverse xmlns="antlib:org.apache.tools.ant.types.resources.comparators ">
<date />
</reverse>
</sort>
</first>
</pathconvert>
<!-- Launch the eclipse application -->
<java fork="true" jar="${@{app}.launcher}" dir="${@{app}.deploy.dir}" failonerror="true">
<!-- Uncomment to debug <jvmarg value=" -agentlib:jdwp=transport=dt_socket,address=8000,server=y,sus pend=y "/> -->
<args />
</java>
</sequential>
</macrodef>
<!-- Macro to run a buckminster command -->
<macrodef name="buckminster">
<attribute name="command" default="--scriptfile"/>
<element name="globargs" optional="true" />
<element name="cmdargs" optional="true" />
<sequential>
<eclipse.launch app="buckminster">
<args>
<globargs />
<arg value="@{command}" />
<cmdargs />
</args>
</eclipse.launch>
</sequential>
</macrodef>
<!--Fetch and unzip the director
<property name="director.url" value=" http://www.eclipse.org/downloads/download.php?file=/tools/bu ckminster/products/director_1.0.0.r10030.zip&r=1" />
<available file="${buildtools}/director/director" property="director.exists" />
<target name="get.director" unless="director.exists">
<tempfile destdir="${java.io.tmpdir}" prefix="director-" suffix=".zip" property="director.zip" deleteonexit="true"/>
<get src="${director.url}" dest="${director.zip}" />
<unzip src="${director.zip}" dest="${buildtools}" />
</target>
<!--Configure the Buckminster product with needed features
<target name="install.buckminster" depends="get.director">
<delete dir="${buildtools}/buckminster" />
<eclipse.launch app="director">
<args>
<arg value="-ar"/>
<arg value="${bm.headless.site}"/>
<arg value="-mr"/>
<arg value="-dest"/>
<arg value="${buildtools}/buckminster"/>
<arg value="-bundlepool"/>
<arg value="-profile"/>
<arg value="Buckminster"/>
<arg value="-installIU"/>
<arg value="org.eclipse.buckminster.cmdline.product"/>
<jvmarg value="-Declipse.p2.data.area=${buildtools}/buckminster/p2"/ >
<jvmarg value="-Declipse.p2.profile=Buckminster"/>
</args>
</eclipse.launch>
</target>
<target name="configure.product" depends="install.buckminster">
<buckminster>
<globargs>
<jvmarg value="-Dbm.headless.site=${bm.headless.site}" />
</globargs>
<cmdargs>
<arg value="${product.config.script}" />
</cmdargs>
</buckminster>
</target>
<target name="clean.all" depends="clean.buckminster">
<delete dir="${buildtools}/director" />
</target>
<target name="clean.buckminster">
</target>
</project>
name="product.config.bmscript"
filename="product.config.bmscript"
install ${bm.headless.site} org.eclipse.buckminster.core.headless.feature
install ${bm.headless.site} org.eclipse.buckminster.maven.feature
install ${bm.headless.site} org.eclipse.buckminster.cvs.headless.feature
install ${bm.headless.site} org.eclipse.buckminster.pde.headless.feature
--------------080105050306050502000002--
Re: Changes to Headless Buckminster in Galileo M6 release [message #383563 is a reply to message #383551] |
Fri, 27 March 2009 06:37   |
Hello Thomas,
Thank you for the update, however what you've posted unfortunately does not
work :(.
I run your ANT script using Ant 1.7.1 but it fails when buckminster tries to
dowlnoad it's parts. Here is the how it is happening:
[noname:STPBPMN/build/buckminster] zubairov% !ant
ant -f buckminster35.xml configure.product
Buildfile: buckminster35.xml
get.director:
install.buckminster:
[delete] Deleting directory /Users/zubairov/buildtools/buckminster
[java] Installing org.eclipse.buckminster.cmdline.product
1.1.350.r10034.
[java] Operation completed in 40410 ms.
configure.product:
[java] org.eclipse.buckminster.cmdline.parser.InvalidOptionExceptio n:
The option '--loglevel DEBUG' is invalid
BUILD FAILED
/Users/zubairov/Repositories/STPBPMN/build/buckminster/buckm inster35.xml:104
: The following error occurred while executing this line:
/Users/zubairov/Repositories/STPBPMN/build/buckminster/buckm inster35.xml:57:
/Users/zubairov/Repositories/STPBPMN/build/buckminster/buckm inster35.xml:44:
Java returned: 1
Total time: 43 seconds
When I tried to install update from the command line with traces enabled
then I see following exception:
An error occurred while installing the items
[0]session context was:(profile=Buckminster,
phase=org.eclipse.equinox.internal.provisional.p2.engine.pha ses.Install,
operand=null --> [R]com.ibm.icu.base 4.0.1.v20090109,
action=org.eclipse.equinox.internal.p2.touchpoint.eclipse.ac tions.InstallBun
dleAction).
[0]Error while loading manipulator.
Caused by: [0]java.lang.IllegalStateException: Error while loading
manipulator.
at
org.eclipse.equinox.internal.p2.touchpoint.eclipse.LazyManip ulator.loadDeleg
ate(LazyManipulator.java:54)
at
org.eclipse.equinox.internal.p2.touchpoint.eclipse.LazyManip ulator.getConfig
Data(LazyManipulator.java:108)
at
org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.I nstallBundleActi
on.installBundle(InstallBundleAction.java:76)
at
on.execute(InstallBundleAction.java:29)
at
org.eclipse.equinox.internal.p2.engine.ParameterizedProvisio ningAction.execu
te(ParameterizedProvisioningAction.java:33)
BR
Renat
On 23.03.09 21:01, in article gq8pqs$hth$1@build.eclipse.org, "Thomas
> Regards,
> Thomas Hallgren
> that resides
> <sequential>
> property -->
> <first count="1">
> <sort>
> <date />
> </reverse>
> </sort>
> </first>
> </pathconvert>
> failonerror="true">
> <args />
> </java>
> </sequential>
> </macrodef>
> <sequential>
> <args>
> <globargs />
> <cmdargs />
> </args>
> </eclipse.launch>
> </sequential>
> </macrodef>
> </target>
> <args>
> <arg value="-ar"/>
> <arg value="-mr"/>
> </args>
> </eclipse.launch>
> </target>
> <buckminster>
> <globargs>
> </globargs>
> <cmdargs>
> </cmdargs>
> </buckminster>
> </target>
> </target>
> </target>
> </project>
Re: Changes to Headless Buckminster in Galileo M6 release [message #383566 is a reply to message #383563] |
Fri, 27 March 2009 07:27   |
Hi Renat,
Could this be caused by an invalid argument entry?
You would typically get this error if you add something that looks like
this:
<arg value="--loglevel DEBUG" />
instead of:
<arg value="--loglevel" />
<arg value="DEBUG" />
Not sure how this is related to the problems you see when loading the
manipulator though. What platform are you running on?
Thomas Hallgren
Renat Zubairov wrote:
> Hello Thomas,
> work :(.
> get.director:
> 1.1.350.r10034.
> configure.product:
> BUILD FAILED
> Java returned: 1
> dleAction).
> manipulator.
> at
> at
> at
> at
> at
> BR
> Renat
>> Regards,
>> Thomas Hallgren
>> that resides
>> <sequential>
>> property -->
>> <first count="1">
>> <sort>
>> <date />
>> </reverse>
>> </sort>
>> </first>
>> </pathconvert>
>> failonerror="true">
>> <args />
>> </java>
>> </sequential>
>> </macrodef>
>> <sequential>
>> <args>
>> <globargs />
>> <cmdargs />
>> </args>
>> </eclipse.launch>
>> </sequential>
>> </macrodef>
>> </target>
>> <args>
>> <arg value="-ar"/>
>> <arg value="-mr"/>
>> </args>
>> </eclipse.launch>
>> </target>
>> <buckminster>
>> <globargs>
>> </globargs>
>> <cmdargs>
>> </cmdargs>
>> </buckminster>
>> </target>
>> </target>
>> </target>
>> </project>
Re: Changes to Headless Buckminster in Galileo M6 release [message #383571 is a reply to message #383566] |
Fri, 27 March 2009 07:55   |
I'm running on Mac OS X Leopard. With java:
[noname:~] zubairov% java -version
java version "1.5.0_16"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_16-b06-284)
Java HotSpot(TM) Client VM (build 1.5.0_16-133, mixed mode, sharing)
And ANT:
Apache Ant version 1.7.1 compiled on June 27 2008
This can't be argument entry error since I haven't changed the build.xml
you've attached to your post. What is also interesting when I doing it by
hand, so downloading director and executing from command line everything
works, but not from the ANT.
Renat
On 27.03.09 12:27, in article gqid6m$56p$1@build.eclipse.org, "Thomas
> Hi Renat,
> this:
> instead of:
> Regards,
> Thomas Hallgren
>> Hello Thomas,
>> work :(.
>> get.director:
>> 1.1.350.r10034.
>> configure.product:
>> BUILD FAILED
>> Java returned: 1
>> dleAction).
>> manipulator.
>> at
>> at
>> at
>> at
>> at
>> BR
>> Renat
>>> Regards,
>>> Thomas Hallgren
>>> that resides
>>> <sequential>
>>> @{app}.launcher
>>> property -->
>>> <first count="1">
>>> <sort>
>>> <date />
>>> </reverse>
>>> </sort>
>>> </first>
>>> </pathconvert>
>>> failonerror="true">
>>> <args />
>>> </java>
>>> </sequential>
>>> </macrodef>
>>> <sequential>
>>> <args>
>>> <globargs />
>>> <cmdargs />
>>> </args>
>>> </eclipse.launch>
>>> </sequential>
>>> </macrodef>
>>> /p
>>> </target>
>>> <args>
>>> <arg value="-ar"/>
>>> <arg value="-mr"/>
>>> </args>
>>> </eclipse.launch>
>>> </target>
>>> <buckminster>
>>> <globargs>
>>> </globargs>
>>> <cmdargs>
>>> </cmdargs>
>>> </buckminster>
>>> </target>
>>> </target>
>>> </target>
>>> </project>
Re: Changes to Headless Buckminster in Galileo M6 release [message #383833 is a reply to message #383571] |
Mon, 30 March 2009 02:48   |
Hi Thomas,
Sorry it was my mistake, I posted the wrong exception message before, the
one with "-Dloglevel...", when I just trying to run ANT script you posted
before I got following exceptions:
Buildfile: build.xml
BUILD SUCCESSFUL
Total time: 0 seconds
[noname:/tmp/buckminster] zubairov% ant configure.product
get.director:
[get] Getting:
[get] To: /tmp/director-768361641.zip
[unzip] Expanding: /tmp/director-768361641.zip into
1.1.350.r10034.
[java] Operation completed in 48066 ms.
configure.product:
[java] INFO: install
'http://download.eclipse.org/tools/buckminster/headless-3.5/'
'org.eclipse.buckminster.core.headless.feature'
[java] An error occurred while installing the items
[java] [0]session context was:(profile=Buckminster,
dleAction).
[java] [0]Error while loading manipulator.
[java] Caused by:
BUILD FAILED
/private/tmp/buckminster/build.xml:104: The following error occurred while
/private/tmp/buckminster/build.xml:57: The following error occurred while
/private/tmp/buckminster/build.xml:44: Java returned: 1
Renat
On 27.03.09 12:55, in article C5F27D4B.22ED%renat.zubairov@sopera.de, "Renat
> And ANT:
> Renat
>> Hi Renat,
>> this:
>> instead of:
>> Regards,
>> Thomas Hallgren
>>> Hello Thomas,
>>> work :(.
>>> get.director:
>>> 1.1.350.r10034.
>>> configure.product:
>>> BUILD FAILED
>>> Java returned: 1
>>> dleAction).
>>> manipulator.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> BR
>>> Renat
>>>> Regards,
>>>> Thomas Hallgren
>>>> holder
>>>> that resides
>>>> <sequential>
>>>> @{app}.launcher
>>>> property -->
>>>> <first count="1">
>>>> <sort>
>>>> <date />
>>>> </reverse>
>>>> </sort>
>>>> </first>
>>>> </pathconvert>
>>>> failonerror="true">
value=" -agentlib:jdwp=transport=dt_socket,address=8000,server=y,sus pend=y "/>>>>
>>>> <args />
>>>> </java>
>>>> </sequential>
>>>> </macrodef>
>>>> <sequential>
>>>> <args>
>>>> <globargs />
>>>> <cmdargs />
>>>> </args>
>>>> </eclipse.launch>
>>>> </sequential>
>>>> </macrodef>
value=" http://www.eclipse.org/downloads/download.php?file=/tools/bu ckminste>>>>
r
>>>> /p
>>>> </target>
>>>> <args>
>>>> <arg value="-ar"/>
>>>> <arg value="-mr"/>
>>>> </args>
>>>> </eclipse.launch>
>>>> </target>
>>>> <buckminster>
>>>> <globargs>
>>>> </globargs>
>>>> <cmdargs>
>>>> </cmdargs>
>>>> </buckminster>
>>>> </target>
>>>> </target>
>>>> </target>
>>>> </project>
Problem with build.xml for Galileo headless install [message #387714 is a reply to message #383551] |
Wed, 08 July 2009 10:48  |
Hello Thomas,
Thanks for your posts on headless buckminster installation, they were
invaluable in getting it up and working.
When I ran buckminster.bat I initially got a "the system cannot find the
path specified" error. In my case, this was due to ${user.home} in
build.xml resolving to C:\Documents and Settings\jgoetz (note the spaces).
The solution was to enclose the path in "":
for /f "delims= tokens=1" %%c in ('dir /B /S /OD
"%EXE_DIR%\plugins\org.eclipse.equinox.launcher_*.jar"') do set
EQUINOXJAR=%%c
Hope others find this helpful.
John
Current Time: Sun Jul 20 20:10:20 EDT 2025
Powered by FUDForum. Page generated in 0.42086 seconds
