[TCS] Transformation files in TCSToolkit [message #378274] |
Wed, 27 June 2007 12:56  |
Originally posted by: quentin.glineur.obeo.fr
Where can I find the "source" version of the TCSToolkit transformations
(i.e. the .atl file instead of the .asm ones) ?
Quentin
Re: [TCS] Transformation files in TCSToolkit [message #378423 is a reply to message #378421] |
Wed, 04 July 2007 04:35  |
Hi Frédéric,
> I want to investigate TCS with UML models. Hence, I also need to modify
> the TCS2ANTLR.atl.
I do not understand why you would need to modify this transformation.
There may be a simpler way to achieve your goal ;-).
Could you please give us more details?
> When do you plan to upload the TCS toolkit sources on the gmt cvs
server ?
Soon ;-).
Frédéric Jouault
Re: [TCS] Transformation files in TCSToolkit [message #602185 is a reply to message #378278] |
Thu, 28 June 2007 04:21  |
Frédéric Jouault a écrit :
> Hello,
Hi Frédéric,
> It is not available yet, but should appear soon in the newly created
> Eclipse/GMT TCS component: http://www.eclipse.org/gmt/tcs/
> May I ask why you want the .atl file? ;-)
I would like to make some tests and see what kind of effects on the
produced parser code I can get by tuning the antlr grammar (through
tcs2antlr).
> Best regards,
> Frédéric Jouault
> Quentin Glineur wrote:
>> Hi,
>> transformations (i.e. the .atl file instead of the .asm ones) ?
>> Thanks
>> Quentin
Quentin Glineur
Re: [TCS] Transformation files in TCSToolkit [message #602206 is a reply to message #378279] |
Thu, 28 June 2007 08:55  |
Hello Quentin,
Thanks for the information ;-).
Frédéric Jouault
>> Hello,
> Hi Frédéric,
> tcs2antlr).
>> Best regards,
>> Frédéric Jouault
>>> Hi,
>>> Thanks
>>> Quentin
> Regards,
> Quentin Glineur
Re: [TCS] Transformation files in TCSToolkit [message #602216 is a reply to message #378419] |
Sun, 01 July 2007 12:29  |
the TCS2ANTLR.atl.
When do you plan to upload the TCS toolkit sources on the gmt cvs server ?
Best regards
Frédéric
Re: [TCS] Transformation files in TCSToolkit [message #602220 is a reply to message #378421] |
Hi Frédéric,
> the TCS2ANTLR.atl.
server ?
Soon ;-).
Frédéric Jouault
FUDForum. Page generated in 0.05092 seconds
