Home » Eclipse Projects » SWTBot » PDE headless throws java return 13 error
PDE headless throws java return 13 error [message #35288] Wed, 13 May 2009 13:08 Go to next message
Hi there,
I'm in the process of making the swtBot test cases run in the nightly
builds, to achieve this I downloaded the Ketan's PDE source and modified
the files as per readme instructions.
I've downloaded eclipse 3.4.2 verison and replaced the older
buid.properties file. As it is mentioned in the readme I changed the
values in the build.developer.properties.sample to:
os = win32
ws = win32
arch = x86
update-site-location = update-site
eclipse.sdk.archive = eclipse-SDK-3.4.2-win32.zip
and renamed it to build.developer.properties. I got an error. Java
returned: 13 Here is the log:-
Buildfile: build.xml
[delete] Deleting: C:\DOCUME~1\SUNMIC~1\LOCALS~1\Temp\git.svn.properties
[touch] Creating C:\DOCUME~1\SUNMIC~1\LOCALS~1\Temp\git.svn.properties
[delete] Deleting: C:\DOCUME~1\SUNMIC~1\LOCALS~1\Temp\svn.properties
[touch] Creating C:\DOCUME~1\SUNMIC~1\LOCALS~1\Temp\svn.properties
check-dependencies:
download-eclipse-sdk:
download-purge-task:
download-ant-contrib-task:
download-ant-cobertura-task:
download-ant-libs:
download-dependencies:
check-windows-preconditions:
[echo] Checking for unzip on path.
[echo] Found unzip on path.
check-other-preconditions:
check-conditions:
[echo] Checking for svn on path.
[echo] Found svn on path.
guess-junit-version:
[echo] Guessing plugin version of org.junit4.
[echo] Plugin version of org.junit is "4.3.1"
[echo] isJunit4.5: ${isJunit4.5}
guess-pde-build-version:
[echo] Guessing plugin version of org.eclipse.pde.build.
[echo] Plugin version of org.eclipse.pde.build is
"3.4.1.R34x_v20081217"
create-build-properties-from-template:
[copy] Copying 1 file to
C:\asif\PDEUnitTest\ketan\ketan-swtbot\org.eclipse.swtbot.re leng
initialize-environment:
printjvm:
[exec] The command attribute is deprecated.
[exec] Please use the executable attribute and nested arg elements.
[exec] java version "1.6.0_13"
[exec] Java(TM) SE Runtime Environment (build 1.6.0_13-b03)
[exec] Java HotSpot(TM) Client VM (build 11.3-b02, mixed mode,
sharing)
[echoproperties] #Ant properties
[echoproperties] #Wed May 13 10:04:07 PDT 2009
[echoproperties] java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
[echoproperties] java.awt.printerjob=sun.awt.windows.WPrinterJob
[echoproperties]
java.class.path=C\:\\eclipse_Europa\\eclipse\\plugins\\org.a pache.ant_1.7.0.v200706080842\\bin\\..\\lib\\ant-launcher.ja r;C\:\\jdk\\jre\\bin;C\:\\eclipse_Europa\\eclipse\\plugins\\ org.apache.ant_1.7.0.v200706080842\\bin "
;C\:\\eclipse_Europa\\eclipse\\plugins\\org.apache.ant_1.7.0 .v200706080842\\lib\\ant-antlr.jar;C\:\\eclipse_Europa\\ecli pse\\plugins\\org.apache.ant_1.7.0.v200706080842\\lib\\ant-a pache-bcel.jar;C\:\\eclipse_Europa\\eclipse\\plugins\\org.ap ache.ant_1.7.0.v200706080842\\lib\\ant-apache-bsf.jar;C\:\\e clipse_Europa\\eclipse\\plugins\\org.apache.ant_1.7.0.v20070 6080842\\lib\\ant-apache-log4j.jar;C\:\\eclipse_Europa\\ecli pse\\plugins\\org.apache.ant_1.7.0.v200706080842\\lib\\ant-a pache-oro.jar;C\:\\eclipse_Europa\\eclipse\\plugins\\org.apa che.ant_1.7.0.v200706080842\\lib\\ant-apache-regexp.jar;C\:\ \eclipse_Europa\\eclipse\\plugins\\org.apache.ant_1.7.0.v200 706080842\\lib\\ant-apache-resolver.jar;C\:\\eclipse_Europa\ \eclipse\\plugins\\org.apache.ant_1.7.0.v200706080842\\lib\\ ant-commons-logging.jar;C\:\\eclipse_Europa\\eclipse\\plugin s\\org.apache.ant_1.7.0.v200706080842\\lib\\ant-commons-net. jar;C\:\\eclipse_Europa\\eclipse\\plugins\\org.apache.ant_1. 7.0.v200706080842\\lib\\ant-jai.jar;C\:\\eclipse_Europa\\ecl ipse\\plugins\\org.apache.ant_1.7.0.v200706080842\\lib\\ant- javamail.jar;C\:\\eclipse_Europa\\eclipse\\plugins\\org.apac he.ant_1.7.0.v200706080842\\lib\\ant-jdepend.jar;C\:\\eclips e_Europa\\eclipse\\plugins\\org.apache.ant_1.7.0.v2007060808 42\\lib\\ant-jmf.jar;C\:\\eclipse_Europa\\eclipse\\plugins\\ org.apache.ant_1.7.0.v200706080842\\lib\\ant-jsch.jar;C\:\\e clipse_Europa\\eclipse\\plugins\\org.apache.ant_1.7.0.v20070 6080842\\lib\\ant-junit.jar;C\:\\eclipse_Europa\\eclipse\\pl ugins\\org.apache.ant_1.7.0.v200706080842\\lib\\ant-launcher .jar;C\:\\eclipse_Europa\\eclipse\\plugins\\org.apache.ant_1 .7.0.v200706080842\\lib\\ant-netrexx.jar;C\:\\eclipse_Europa \\eclipse\\plugins\\org.apache.ant_1.7.0.v200706080842\\lib\ \ant-nodeps.jar;C\:\\eclipse_Europa\\eclipse\\plugins\\org.a pache.ant_1.7.0.v200706080842\\lib\\ant-starteam.jar;C\:\\ec lipse_Europa\\eclipse\\plugins\\org.apache.ant_1.7.0.v200706 080842\\lib\\ant-stylebook.jar;C\:\\eclipse_Europa\\eclipse\ \plugins\\org.apache.ant_1.7.0.v200706080842\\lib\\ant-swing .jar;C\:\\eclipse_Europa\\eclipse\\plugins\\org.apache.ant_1 .7.0.v200706080842\\lib\\ant-trax.jar;C\:\\eclipse_Europa\\e clipse\\plugins\\org.apache.ant_1.7.0.v200706080842\\lib\\an t-weblogic.jar;C\:\\eclipse_Europa\\eclipse\\plugins\\org.ap ache.ant_1.7.0.v200706080842\\lib\\ant.jar;C\:\\Program
Files\\Java\\jre6\\lib\\tools.jar
[echoproperties] java.class.version=50.0
[echoproperties] java.endorsed.dirs=C\:\\Program
Files\\Java\\jre6\\lib\\endorsed
[echoproperties] java.ext.dirs=C\:\\Program
Files\\Java\\jre6\\lib\\ext;C\:\\WINDOWS\\Sun\\Java\\lib\\ex t
[echoproperties] java.home=C\:\\Program Files\\Java\\jre6
[echoproperties] java.io.tmpdir=C\:\\DOCUME~1\\SUNMIC~1\\LOCALS~1\\Temp\\
[echoproperties]
java.library.path=C\:\\WINDOWS\\system32;.;C\:\\WINDOWS\\Sun \\Java\\bin;C\:\\WINDOWS\\system32;C\:\\WINDOWS;C\:\\Program
Files\\CollabNet Subversion
Server;C\:\\WINDOWS\\system32;C\:\\WINDOWS;C\:\\WINDOWS\\Sys tem32\\Wbem;C\:\\jdk\\jre\\bin;C\:\\jdk\\bin;C\:\\eclipse_Eu ropa\\eclipse\\plugins\\org.apache.ant_1.7.0.v200706080842\\ bin;c\:\\unzip;C\:\\svn\\git\\git-1.6.3;c\:\\mksnt
[echoproperties] java.runtime.name=Java(TM) SE Runtime Environment
[echoproperties] java.runtime.version=1.6.0_13-b03
[echoproperties] java.specification.name=Java Platform API Specification
[echoproperties] java.specification.vendor=Sun Microsystems Inc.
[echoproperties] java.specification.version=1.6
[echoproperties] java.vendor=Sun Microsystems Inc.
[echoproperties] java.vendor.url=http\://java.sun.com/
[echoproperties]
java.vendor.url.bug=http\://java.sun.com/cgi-bin/bugreport.cgi
[echoproperties] java.version=1.6.0_13
[echoproperties] java.vm.info=mixed mode, sharing
[echoproperties] java.vm.name=Java HotSpot(TM) Client VM
[echoproperties] java.vm.specification.name=Java Virtual Machine
Specification
[echoproperties] java.vm.specification.vendor=Sun Microsystems Inc.
[echoproperties] java.vm.specification.version=1.0
[echoproperties] java.vm.vendor=Sun Microsystems Inc.
[echoproperties] java.vm.version=11.3-b02
clean:
[echo] Cleaning all in
C:\asif\PDEUnitTest\ketan\ketan-swtbot\org.eclipse.swtbot.re leng/target
[delete] Deleting directory
C:\asif\PDEUnitTest\ketan\ketan-swtbot\org.eclipse.swtbot.re leng\artifacts
init:
[mkdir] Created dir:
copy-features:
[sync] Copying 6 files to
C:\asif\PDEUnitTest\ketan\ketan-swtbot\org.eclipse.swtbot.re leng\target\features
copy-plugins:
[sync] Copying 93 files to
C:\asif\PDEUnitTest\ketan\ketan-swtbot\org.eclipse.swtbot.re leng\target\plugins
copy-sources:
copy-all:
pde-build:
[echo] ###### basedir amius
[echo] ######eclipseLocation amius =
../eclipse/plugins/org.eclipse.pde.build_3.4.1.R34x_v2008121 7/scripts/build.xml
[java] Install location:
[java] file:/c:/asif/PDEUnitTest/ketan/ketan-swtbot/eclipse/
[java] Configuration file:
[java]
file:/c:/asif/PDEUnitTest/ketan/ketan-swtbot/eclipse/configu ration/config.ini
loaded
[java] Configuration location:
[java]
[java] Framework located:
[java]
file:/c:/asif/PDEUnitTest/ketan/ketan-swtbot/eclipse/plugins /org.eclipse.osgi_3.4.3.R34x_v20081215-1030.jar
[java] Framework classpath:
[java]
[java] Debug options:
[java]
file:/C:/asif/PDEUnitTest/ketan/ketan-swtbot/org.eclipse.swt bot.releng/.options
not found
[java] Time to load bundles: 15
Any advice is much appreciated
Mohammed
Re: PDE headless throws java return 13 error [message #35329 is a reply to message #35288] Wed, 13 May 2009 15:26 Go to previous messageGo to next message
Here is consoleLog for more information:-
pde-build:
[echo] ######buildDirectory amius =
[java] !SESSION 2009-05-13 12:20:37.468
[java] eclipse.buildId=M20090211-1700
[java] java.version=1.6.0_13
[java] java.vendor=Sun Microsystems Inc.
[java] BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
[java] Framework arguments: -application
org.eclipse.ant.core.antRunner -buildfile
-Dtimestamp=007 -DbuildId=2.0.0.${svn.LastChangedRev}-dev
-DforceContextQualifier=${svn.LastChangedRev}-dev -Dbaseos=win32
-Dbasews=win32 -Dbasearch=x86
-Dbuilder=C:\asif\PDEUnitTest\ketan\ketan-swtbot\org.eclipse .swtbot.releng
-Dbasedir=C:\asif\PDEUnitTest\ketan\ketan-swtbot\org.eclipse .swtbot.releng
-Dbuild_directory=C:\asif\PDEUnitTest\ketan\ketan-swtbot\org .eclipse.swtbot.releng/target
[java] Command-line arguments: -application
-consoleLog
[java]
[java] !ENTRY org.eclipse.osgi 4 0 2009-05-13 12:20:38.187
[java] !MESSAGE Application error
[java] !STACK 1
[java] java.lang.IllegalStateException: Unable to acquire application
service. Ensure that the org.eclipse.core.runtime bundle is resolved and
started (see config.ini).
[java] at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
[java] at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
[java] at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
[java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown
Source)
[java] at java.lang.reflect.Method.invoke(Unknown Source)
[java] at
org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
[java] at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
[java] at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
[java] at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Re: PDE headless throws java return 13 error [message #35362 is a reply to message #35329] Wed, 13 May 2009 21:06 Go to previous messageGo to next message
After some research I could able to proceed further but stuck at this
point to find Missing required plug-in com.thoughtworks.qdox_0.0.0. due
to which ant target is failed to execute successfully. This is the latest
log. If anyone give me clue to fix this issue would be appreciated.
check-dependencies:
[get] Getting:
http://sunsite.informatik.rwth-aachen.de:3080/eclipse/downlo ads/drops/R-3.4.2-200902111700/eclipse-SDK-3.4.2-win32.zip
[get] To:
C:\swtBot\swtbot\org.eclipse.swtbot.releng\externals\eclipse -SDK-3.4.2-win32.zip
[get] local file date : Wed May 13 17:33:01 PDT 2009
[get] Not modified - so not downloaded
download-ant-libs:
check-conditions:
[copy] Copying 1 file to C:\swtBot\swtbot\org.eclipse.swtbot.releng
printjvm:
sharing)
[echoproperties] #Wed May 13 18:01:30 PDT 2009
[echoproperties]
[echoproperties]
[echoproperties]
Specification
clean:
C:\swtBot\swtbot\org.eclipse.swtbot.releng/target
C:\swtBot\swtbot\org.eclipse.swtbot.releng\artifacts
init:
copy-features:
C:\swtBot\swtbot\org.eclipse.swtbot.releng\target\features
[sync] Removed 4 dangling files from
copy-plugins:
C:\swtBot\swtbot\org.eclipse.swtbot.releng\target\plugins
[sync] Copied 31 empty directories to 21 empty directories under
[sync] Removed 20 dangling files from
copy-sources:
copy-all:
pde-build:
[java] Buildfile:
[java]
[java] main:
[java]
[java] preBuild:
[java]
[java] preSetup:
[java]
[java] checkLocalMaps:
[java]
[java] getMapFiles:
[java] [concat] No existing resources and no nested text, doing
nothing
[java]
[java] postSetup:
[java]
[java] checkLocalBase:
[java]
[java] getBaseComponents:
[java]
[java] fetch:
[java]
[java] generate:
[java]
[java] preGenerate:
[java]
[java] allElements:
[java]
[java] allElementsDelegator:
[java]
[java] init:
[java]
[java] generateScript:
[java] [eclipse.buildScript] Some inter-plug-in dependencies have not
been satisfied.
[java] [eclipse.buildScript] Bundle org.eclipse.swtbot.generator:
[java] [eclipse.buildScript] Missing required plug-in
[java] [eclipse.buildScript] Bundle org.eclipse.swtbot.generator.test:
org.eclipse.swtbot.generator_0.0.0.
[java] [eclipse.buildScript] Bundle org.eclipse.swtbot.swt.finder:
[java] [eclipse.buildScript] Another singleton version selected:
org.eclipse.swtbot.swt.finder_2.0.0.275-dev
[java]
[java] init:
[java]
been satisfied.
[java]
[java] BUILD FAILED
[java]
C:\swtBot\swtbot\eclipse\plugins\org.eclipse.pde.build_3.4.1 .R34x_v20081217\scripts\build.xml:24:
The following error occurred while executing this line:
[java]
C:\swtBot\swtbot\eclipse\plugins\org.eclipse.pde.build_3.4.1 .R34x_v20081217\scripts\build.xml:64:
[java]
C:\swtBot\swtbot\org.eclipse.swtbot.releng\customTargets.xml :11: The
[java] C:\swtBot\swtbot\org.eclipse.swtbot.releng\allElements.xml:1 7:
[java]
C:\swtBot\swtbot\eclipse\plugins\org.eclipse.pde.build_3.4.1 .R34x_v20081217\scripts\genericTargets.xml:88:
Bundle org.eclipse.swtbot.generator.test_0.0.0 failed to resolve.:
[java] Missing required plug-in org.eclipse.swtbot.generator_0.0.0.
[java]
[java]
[java] Total time: 2 seconds
Re: PDE headless throws java return 13 error [message #35397 is a reply to message #35362] Thu, 14 May 2009 00:59 Go to previous message
The readme file[1] should tell you what to do.
[1] -
http://github.com/ketan/swtbot/blob/master/org.eclipse.swtbo t.releng/readme.txt
-- Ketan
> latest log. If anyone give me clue to fix this issue would be appreciated.
> Thanks
> check-dependencies:
> [get] Getting:
> [get] To:
> download-ant-libs:
> check-conditions:
> [echo] Plugin version of org.eclipse.pde.build is "3.4.1.R34x_v20081217"
> printjvm:
> [exec] Java HotSpot(TM) Client VM (build 11.3-b02, mixed mode, sharing)
> [echoproperties]
jai.jar;C\:\\eclipse_Europa\\eclipse\\plugins\\org.apache.an t_1.7.0.v200706080842\\lib\\ant-javamail.jar;C\:\\eclipse_Eu ropa\\eclipse\\plugins\\org.apache.ant_1.7.0.v200706080842\\ lib\\ant-jdepend.jar;C\:\\eclipse_Europa\\eclipse\\plugins\\ org.apache.ant_1.7.0.v200706080842\\lib\\ant-jmf.jar;C\:\\ec lipse_Europa\\eclipse\\plugins\\org.apache.ant_1.7.0.v200706 080842\\lib\\ant-jsch.jar;C\:\\eclipse_Europa\\eclipse\\plug ins\\org.apache.ant_1.7.0.v200706080842\\lib\\ant-junit.jar; C\:\\eclipse_Europa\\eclipse\\plugins\\org.apache.ant_1.7.0. v200706080842\\lib\\ant-launcher.jar;C\:\\eclipse_Europa\\ec lipse\\plugins\\org.apache.ant_1.7.0.v200706080842\\lib\\ant -netrexx.jar;C\:\\eclipse_Europa\\eclipse\\plugins\\org.apac he.ant_1.7.0.v200706080842\\lib\\ant-nodeps.jar;C\:\\eclipse _Europa\\eclipse\\plugins\\org.apache.ant_1.7.0.v20070608084 2\\lib\\ant-starteam.jar;C\:\\eclipse_Europa\\eclipse\\plugi ns\\org.apache.ant_1.7.0.v200706080842\\lib\\ant-stylebook.j ar;C\:\\eclipse_Europa\\eclips
e\\plugins\\org.apache.ant_1.7.0.v200706080842\\lib\\ant-swi ng.jar;C\:\\eclipse_Europa\\eclipse\\plugins\\org.apache.ant _1.7.0.v200706080842\\lib\\ant-trax.jar;C\:\\eclipse_Europa\ \eclipse\\plugins\\org.apache.ant_1.7.0.v200706080842\\lib\\ ant-weblogic.jar;C\:\\eclipse_Europa\\eclipse\\plugins\\org. apache.ant_1.7.0.v200706080842\\lib\\ant.jar;C\:\\Program
> [echoproperties]
> [echoproperties]
> Specification
> clean:
> [echo] Cleaning all in C:\swtBot\swtbot\org.eclipse.swtbot.releng/target
> init:
> [mkdir] Created dir: C:\swtBot\swtbot\org.eclipse.swtbot.releng\artifacts
> copy-features:
> copy-plugins:
> copy-sources:
> copy-all:
> pde-build:
> [java] Buildfile:
> [java] [java] main:
> [java] [java] preBuild:
> [java] [java] preSetup:
> [java] [java] checkLocalMaps:
> [java] [java] getMapFiles:
> [java] [concat] No existing resources and no nested text, doing nothing
> [java] [java] postSetup:
> [java] [java] checkLocalBase:
> [java] [java] getBaseComponents:
> [java] [java] fetch:
> [java] [java] generate:
> [java] [java] preGenerate:
> [java] [java] allElements:
> [java] [java] allElementsDelegator:
> [java] [java] init:
> [java] [java] generateScript:
> been satisfied.
> [java] [java] init:
> been satisfied.
> [java] [java] BUILD FAILED
> [java]
> [java]
> [java] C:\swtBot\swtbot\org.eclipse.swtbot.releng\customTargets.xml :11:
> [java]
> [java] [java] [java] Total time: 2 seconds
Previous Topic:[3.5 M7] Test launch problem
Next Topic:SWTBot support for GEF
Current Time: Fri Jul 18 19:38:37 EDT 2025
Powered by FUDForum. Page generated in 0.05166 seconds
