Home » Eclipse Projects » SWTBot » java.lang.NoSuchMethodError while running SWTBot on Mac OS
java.lang.NoSuchMethodError while running SWTBot on Mac OS [message #32675] Fri, 17 April 2009 10:44 Go to next message
I run our SWTBot tests on Windows, but just I've tried to run them on Mac
OS Leopard (Eclipse 3.5). I've received such kind of error:
java.lang.NoSuchMethodError:
org.eclipse.pde.internal.ui.launcher.LaunchPluginValidator.g etPluginsToRun(Lorg/eclipse/debug/core/ILaunchConfiguration; )Ljava/util/Map;
at org.eclipse.swtbot.eclipse.ui.JUnitLaunchConfigurationDelega te
preLaunchCheck(JUnitLaunchConfigurationDelegate.java:347)
at
org.eclipse.jdt.junit.launcher.JUnitLaunchConfigurationDeleg ate.launch(JUnitLaunchConfigurationDelegate.java:112)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:855)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:705)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:866)
at org.eclipse.debug.internal.ui.DebugUIPlugin
$8.run(DebugUIPlugin.java:1069)
Can anyone help to understand what could be the problem?
Pavel
Re: java.lang.NoSuchMethodError while running SWTBot on Mac OS [message #32711 is a reply to message #32675] Fri, 17 April 2009 11:18 Go to previous messageGo to next message
What Eclipse build are you using? I've been making some changes to PDE
launching code for 3.5 M7. It looks like SWTBot is using some internals
here. If you need to get the list of bundles that are running, I highly
recommend using BundleLauncherHelper methods as that's where things are
moving too.
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: java.lang.NoSuchMethodError while running SWTBot on Mac OS [message #32742 is a reply to message #32711] Fri, 17 April 2009 16:39 Go to previous message
The class under question[1] does use quite some internals from PDE and
is essentially a copy of PDE's JUnitLaunchConfigurationDelegate.
[1] -
http://github.com/ketan/swtbot/blob/master/org.eclipse.swtbo t.eclipse.ui/src/org/eclipse/swtbot/eclipse/ui/JUnitLaunchCo nfigurationDelegate.java
-- Ketan
> moving too.
> Cheers,
Previous Topic:How to determine on-screen object hierarchy structure?
Next Topic:Swing support
Current Time: Sat Jul 19 00:50:27 EDT 2025
Powered by FUDForum. Page generated in 0.21457 seconds
