Home » Eclipse Projects » SWTBot » More shells than expected
More shells than expected [message #28442] Wed, 18 March 2009 13:05 Go to next message
Since a few weeks (or even longer) I get more shells than I expect.
I use bot.shells().lenght
Previously it returned 1 if there was no modal dialog. But now it returns
2 or even more, although there is no modal dialog visible.
I could not figure out what that "phantom" shell objects are on the GUI.
I always thought the main shell is the application itself which anyone can
see (is visible). And if there is a model dialog on top of that shell,
then there are 2 shells, but not more or less.
Did something change regarding that in SWTBot? Or have I to look at the
application under test if there something changed? Or any ideas why this
is?
Re: More shells than expected [message #28958 is a reply to message #28442] Wed, 18 March 2009 19:56 Go to previous messageGo to next message
Looking at the code, it does not appear to have been touch for awhile.
Besides the underlying code that returns all shells is:
public Shell[] getShells() {
return UIThreadRunnable.syncExec(display, new ArrayResult<Shell>() {
public Shell[] run() {
return display.getShells();
Re: More shells than expected [message #28995 is a reply to message #28958] Thu, 19 March 2009 04:06 Go to previous messageGo to next message
Then it might be something with the application under test.
But what could these invisible Shells be? There is a application window
(main Shell) and no dialog on top of it. How can it then count more than 1
Shell?
Re: More shells than expected [message #29032 is a reply to message #28995] Thu, 19 March 2009 04:17 Go to previous messageGo to next message
These could be shells that were created but not opened.
Try looking at the titles on these shells to get an idea of what they
do, or set up a breakpoint in the shell constructor to see where they're
being created.
-- Ketan
> 1 Shell?
Re: More shells than expected [message #29068 is a reply to message #29032] Thu, 19 March 2009 05:40 Go to previous messageGo to next message
What I try to achieve is to generically test whether there is a modal
dialog in front of the application (for example warning or error dialog).
Since after some actions I expect either a modal dialog to appear or no
modal dialog to appear.
I thought I can do this with display.shells().length, but it is not
suitable for that purpose.
Any idea how I can test this generically (independent of shell title etc.)?
Re: More shells than expected [message #29146 is a reply to message #29068] Thu, 19 March 2009 08:31 Go to previous messageGo to next message
See the #resetWorkbench() method in
http://github.com/ketan/swtbot/blob/master/org.eclipse.swtbo t.eclipse.dsl/src/org/eclipse/swtbot/eclipse/dsl/DefaultWork bench.java
The dsl plugin is not distributed because of lack of tests around it,
but you'll find most of the things you need there.
-- Ketan
Re: More shells than expected [message #29184 is a reply to message #29146] Thu, 19 March 2009 12:18 Go to previous messageGo to next message
It was not quite the solution to my problem, but it gave me an idea. Now I
solve it this way:
public void assertActiveShell(String text)
SWTBot bot = new SWTBot();
SWTBotShell activeShell = bot.activeShell();
String activeShellText = activeShell.getText();
assertEquals(text, activeShellText);
DefaultWorkbench.java has some nice helper methods, but in my mind they
are not DSL specific.
> -- Ketan
Re: More shells than expected [message #29337 is a reply to message #28995] Thu, 19 March 2009 19:10 Go to previous messageGo to next message
I know there can be "hidden" shells. We have one always open but not
shown...so there are always two shells but only one shown.
> Shell?
Re: More shells than expected [message #29374 is a reply to message #29068] Thu, 19 March 2009 19:20 Go to previous message
This might not work all the time but if your goal is to make sure your
application under test is accessible, I would try getting all the shells
descendant of your application, i.e. Shell.getShells() method. In SWTBot,
look at
org.eclipse.swtbot.swt.finder.waits.Conditions.waitForShell( Matcher <?>,
Shell); you should be able to pass in anything() matcher to get all the
shell.
Another idea is to try to force focus the application. If it fails, get
the active shell and close it if not what you looking for in a loop.
Previous Topic:Changes in update site structure
Next Topic:problem with the main SWTBot update site?
Current Time: Fri Jul 18 21:07:48 EDT 2025
Powered by FUDForum. Page generated in 0.05482 seconds
