about shape Example [message #238245] |
Sat, 01 September 2007 15:02  |
Originally posted by: babybear315.163.com
gents:
I want to modify the gef example shapes for my study.I want to add text in
ellipse,How to do this,I try to add code in createFigure(),but I failed.
Re: about shape Example [message #238250 is a reply to message #238245] |
Mon, 03 September 2007 01:44  |
Hi Babybear,
GEF realizes the MVC (Model-View-Controller) concept. The Figures(View)
are being created and updated by the corresponding EditParts
(Controller) which usually listen to changes of the model elements.
Please take a look at the GEF developer's guide:
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. gef.doc.isv/guide/guide.html
If you want to implement editable labels for the shapes, the steps you
will have to undertake will probably look like this:
1.) Realize the model element (e.g. extend EllipticalShape)
2.) Implement the figure (e.g. extend the createFigure() /
createFigureForModel() method)
3.) Update the edit-part [e.g. extend refreshVisuals(), listen to
additional model (property) changes, react to direct-edit requests by
overriding performRequest(Request)-method, implement direct-edit
command, etc.]
Did you read the shapes tutorial?
http://www.eclipse.org/articles/Article-GEF-diagram-editor/s hape.html
Good luck! :)
Kind regards,
Andreas
babybear315 schrieb:
> gents:
FUDForum. Page generated in 0.23720 seconds
