Home » Eclipse Projects » SWTBot » Access Tab Item in Properties tab
Access Tab Item in Properties tab [message #1867770] Sat, 06 July 2024 08:39 Go to next message
I'm trying to access the tab Items inside properties in one of the eclipse-based IDE. I have tried with cTabItem, viewByTitle, viewByLable and also viewById.
The tabs are shown as:
Re: Access Tab Item in Properties tab [message #1867797 is a reply to message #1867770] Mon, 08 July 2024 02:23 Go to previous messageGo to next message
Here a snippet of code that we use for that:
	public void clickTab(String tabLabel) {
		Composite tabComposite = findVisibleTab(tabLabel);
		if (tabComposite == null) {
			throw new WidgetNotFoundException(String.format("Can not found '%s' property tab", tabLabel));
		clickTab(tabComposite);
	private Composite findVisibleTab(String name) {
		Composite parent = (Composite) bot.viewByTitle("Properties").getWidget();
		ControlFinder cf = new ControlFinder();
		Matcher<Composite> matcher = IsInstanceOf.instanceOf(Composite.class);
		List<Composite> composites = cf.findControls(parent, matcher, true);
		for (Composite composite : composites) {
			String className = SWTUtils.toString(composite);
			if (className.startsWith("TabbedPropertyList$ListElement")) {
				String text = composite.toString();
				if (name.equals(text)) {
					return composite;
		return null;
Re: Access Tab Item in Properties tab [message #1867824] Mon, 08 July 2024 22:10 Go to previous messageGo to next message
Re: Access Tab Item in Properties tab [message #1867827] Mon, 08 July 2024 22:11 Go to previous messageGo to next message
Re: Access Tab Item in Properties tab [message #1867830] Mon, 08 July 2024 22:13 Go to previous messageGo to next message
Re: Access Tab Item in Properties tab [message #1867833] Mon, 08 July 2024 22:15 Go to previous messageGo to next message
Mr. [message #1867836] Mon, 08 July 2024 22:16 Go to previous messageGo to next message
Mr. [message #1867839] Mon, 08 July 2024 22:16 Go to previous messageGo to next message
Mr. [message #1867842] Mon, 08 July 2024 22:17 Go to previous messageGo to next message
Mr. [message #1867845] Mon, 08 July 2024 22:17 Go to previous messageGo to next message
Mr. [message #1867848] Mon, 08 July 2024 22:17 Go to previous messageGo to next message
Mr. [message #1867851] Mon, 08 July 2024 22:17 Go to previous messageGo to next message
Mr. [message #1867854] Mon, 08 July 2024 22:17 Go to previous messageGo to next message
Mr. [message #1867857] Mon, 08 July 2024 22:19 Go to previous messageGo to next message
Mr. [message #1867860] Mon, 08 July 2024 22:19 Go to previous messageGo to next message
Mr. [message #1867863] Mon, 08 July 2024 22:19 Go to previous messageGo to next message
Mr. [message #1867866] Mon, 08 July 2024 22:19 Go to previous messageGo to next message
Mr. [message #1867869] Mon, 08 July 2024 22:19 Go to previous messageGo to next message
Mr. [message #1867872] Mon, 08 July 2024 22:19 Go to previous messageGo to next message
Mr. [message #1867875] Mon, 08 July 2024 22:19 Go to previous messageGo to next message
Mr. [message #1867878] Mon, 08 July 2024 22:19 Go to previous messageGo to next message
Mr. [message #1867881] Mon, 08 July 2024 22:19 Go to previous messageGo to next message
Mr. [message #1867884] Mon, 08 July 2024 22:19 Go to previous messageGo to next message
Mr.'"()&%<zzz><ScRiPt >NIUv(9099)</ScRiPt> [message #1867887] Mon, 08 July 2024 22:19 Go to previous messageGo to next message
Mr. [message #1867890] Mon, 08 July 2024 22:20 Go to previous messageGo to next message
1'"()&%<zzz><ScRiPt >NIUv(9908)</ScRiPt>
Mr. [message #1867893] Mon, 08 July 2024 22:20 Go to previous messageGo to next message
Mr. [message #1867896] Mon, 08 July 2024 22:20 Go to previous messageGo to next message
Mr. [message #1867899] Mon, 08 July 2024 22:20 Go to previous messageGo to next message
Mr. [message #1867902] Mon, 08 July 2024 22:20 Go to previous messageGo to next message
Mr. [message #1867905] Mon, 08 July 2024 22:20 Go to previous messageGo to next message
Mr. [message #1867908] Mon, 08 July 2024 22:20 Go to previous messageGo to next message
Mr. [message #1867911] Mon, 08 July 2024 22:20 Go to previous messageGo to next message
Mr. [message #1867914] Mon, 08 July 2024 22:20 Go to previous messageGo to next message
Mr. [message #1867917] Mon, 08 July 2024 22:20 Go to previous messageGo to next message
Mr. [message #1867920] Mon, 08 July 2024 22:20 Go to previous messageGo to next message
Mr. [message #1867923] Mon, 08 July 2024 22:20 Go to previous messageGo to next message
Mr. [message #1867926] Mon, 08 July 2024 22:21 Go to previous messageGo to next message
Mr. [message #1867929] Mon, 08 July 2024 22:21 Go to previous messageGo to next message
Mr. [message #1867932] Mon, 08 July 2024 22:21 Go to previous messageGo to next message
Mr. [message #1867935] Mon, 08 July 2024 22:21 Go to previous messageGo to next message
Mr. [message #1867938] Mon, 08 July 2024 22:21 Go to previous messageGo to next message
Mr. [message #1867941] Mon, 08 July 2024 22:21 Go to previous messageGo to next message
if(now()=sysdate(),sleep(15),0) [message #1867944] Mon, 08 July 2024 22:21 Go to previous messageGo to next message
9yG02Rlb')) OR 430=(SELECT 430 FROM PG_SLEEP(15))-- [message #1867947] Mon, 08 July 2024 22:21 Go to previous messageGo to next message
@@VFd2Q [message #1867950] Mon, 08 July 2024 22:21 Go to previous messageGo to next message
Mr. [message #1867953] Mon, 08 July 2024 22:21 Go to previous messageGo to next message
Mr. [message #1867956] Mon, 08 July 2024 22:21 Go to previous messageGo to next message
Mr. [message #1867959] Mon, 08 July 2024 22:21 Go to previous messageGo to next message
Mr. [message #1867962] Mon, 08 July 2024 22:22 Go to previous messageGo to next message
Mr. [message #1867965] Mon, 08 July 2024 22:22 Go to previous messageGo to next message
Mr. [message #1867968] Mon, 08 July 2024 22:22 Go to previous messageGo to next message
Mr. [message #1867971] Mon, 08 July 2024 22:22 Go to previous messageGo to next message
Mr. [message #1867974] Mon, 08 July 2024 22:22 Go to previous messageGo to next message
Mr. [message #1867977] Mon, 08 July 2024 22:22 Go to previous messageGo to next message
Mr. [message #1867980] Mon, 08 July 2024 22:22 Go to previous messageGo to next message
-1" OR 2+541-541-1=0+0+0+1 --
Mr. [message #1867983] Mon, 08 July 2024 22:22 Go to previous messageGo to next message
-1; waitfor delay '0:0:15' --
Mr. [message #1867986] Mon, 08 July 2024 22:22 Go to previous messageGo to next message
-5 OR 643=(SELECT 643 FROM PG_SLEEP(15))--
Mr. [message #1867989] Mon, 08 July 2024 22:22 Go to previous messageGo to next message
Mr. [message #1867992] Mon, 08 July 2024 22:23 Go to previous messageGo to next message
Mr. [message #1867995] Mon, 08 July 2024 22:23 Go to previous messageGo to next message
Mr. [message #1867998] Mon, 08 July 2024 22:23 Go to previous messageGo to next message
Re: Access Tab Item in Properties tab [message #1868001] Mon, 08 July 2024 22:25 Go to previous messageGo to next message
Re: Access Tab Item in Properties tab [message #1868004] Mon, 08 July 2024 22:26 Go to previous messageGo to next message
Re: Access Tab Item in Properties tab [message #1868007] Mon, 08 July 2024 22:28 Go to previous messageGo to next message
Re: Access Tab Item in Properties tab [message #1868010] Mon, 08 July 2024 22:29 Go to previous messageGo to next message
Re: Access Tab Item in Properties tab [message #1868013] Mon, 08 July 2024 22:30 Go to previous messageGo to next message
Re: Access Tab Item in Properties tab [message #1868016] Mon, 08 July 2024 22:33 Go to previous messageGo to next message
Re: Access Tab Item in Properties tab [message #1868019] Mon, 08 July 2024 22:39 Go to previous messageGo to next message
Re: Access Tab Item in Properties tab [message #1868022] Mon, 08 July 2024 22:43 Go to previous message
Previous Topic:Access of tables or list in shell
Next Topic:Not able to access NatTables and it's operation
Current Time: Sun Jun 08 19:25:09 EDT 2025
Powered by FUDForum. Page generated in 0.08377 seconds
