EMF Compare shows only text compare [message #1857616] |
Thu, 16 February 2023 18:47  |
Hi, I'm trying to test EMF Compare with EGit on a simple model from a custom (very simple) Ecore meta-model, (see the attached project defining the metamodel and a git repo with the sample model). The main problem I have is that whenever I do a comparison, e.g. between two branches, the Merge Tool shows only the Text Compare mode, and there are no options to select "Model Compare".
I played with the Eclipse Compare preferences, the EGit preferences and the EMF Compare preferences to no avail. Is there perhaps an extension point where I must register the language or content type?
When I do a comparison or merge of Papyrus UML models it does show the Model Compare mode, so I know it works on some models.
I'm using only the following EMF Compare plugins (which are the same as the ones included in Papyrus 4.8 2020-06):
org.eclipse.compare_3.7.1000.v20200511-1203.jar
org.eclipse.compare.core_3.6.900.v20200412-2017.jar
org.eclipse.emf.compare_3.5.3.202005260905.jar
org.eclipse.emf.compare.edit_4.3.1.202005260905.jar
org.eclipse.emf.compare.ide_3.4.3.202005260905.jar
org.eclipse.emf.compare.ide.ui_4.4.3.202005260905.jar
org.eclipse.emf.compare.rcp_2.5.2.202005260905.jar
org.eclipse.emf.compare.rcp.ui_4.4.2.202005260905.jar
Unfortunately I'm restricted to use these versions because of the version requirements of the product I'm working on.
PS: The files attached are:
1) L1.zip contains the project with the Ecore meta-model, the genmodel and the generated model code;
2) emflang-examples.zip contains a git repo with some versions of a simple model called "m1.l1" on different branches
FUDForum. Page generated in 0.03498 seconds
