Error popup on launch: "'Load QML Analyzer' has encountered a problem." [message #1832784] |
Thu, 24 September 2020 19:45  |
The full message is as follows:
An internal error occurred during: "Load QML Analyzer"."
If I click "Details" I get:
"An internal error occurred during: "Load QML Analyzer".
Cannot invoke "javax.script.ScriptEngine.getContext()" because "this.engine" is null"
I'm on macOS, and I'm using Eclipse for a programming course through my university, so I'm new to the software and pretty new to programming in general, so I apologize for any lack of knowledge. I've emailed a TA about this, however this issue seems quite uncommon so it remains unresolved.
If I click "OK" on the popup I'm able to continue using Eclipse and it seems to work fine for everything I've tried to do on it so far, but the error is still annoying.
So far I've tried reinstalling JDK, as well as reinstalling Eclipse itself. My Mac had a software update I hadn't yet installed, so I tried that as well.
I'm not sure what else to try. Any help would be greatly appreciated, thank you.
Re: Error popup on launch: "'Load QML Analyzer' has encountered a problem." [message #1851854 is a reply to message #1832784] |
Wed, 20 April 2022 05:12   |
Grayson Flood wrote on Thu, 24 September 2020 23:45The full message is as follows:
Cannot invoke "javax.script.ScriptEngine.getContext()" because "this.engine" is null"io games
I'm on macOS, and I'm using Eclipse for a programming course through my university, so I'm new to the software and pretty new to programming in general, so I apologize for any lack of knowledge. I've emailed a TA about this, however, this issue seems quite uncommon so it remains unresolved.
If I click "OK" on the popup I'm able to continue using Eclipse and it seems to work fine for everything I've tried to do on it so far, but the error is still annoying. wordle website
You are probably running with Java 15 which has yet again removed some packages/libraries that were previously available. You should have better luck running the IDE with Java 14.
[Updated on: Tue, 26 April 2022 05:54] by Moderator
FUDForum. Page generated in 0.12016 seconds
