Transition from LA to PA [message #1833037] |
Thu, 01 October 2020 04:31  |
Hello Again,
I am having some trouble when transitioning from LA to PA, most of the tutorials on the Capella website seem to end at LA or to jump to a completed PA so this part is especially difficult.
After performing the transition, my logical components have all become node physical components, I wanted them to be behavior components so I changed them using the property tool. Then I detailed them by creating new sub components (behavior).
I then created node components representing my circuit boards and started allocating behavior components to them.
For that I dragged the behavior components to a PAB diagram, opened the allocation tool and stetted their allocation to the corresponding node component, deleted them from the diagram and then used the deployed component tool on the node component.
The issue is that this method only works for the newly created components but not with the one transitioned, I can't insert them on the diagram, and I can't open the allocation management tool.
The validation tool reported that those components are not referenced by any part (rule id : DWF_DC_42) so I tried creating a new behavior component and moving the old ones into this one (in the project explorer tab and with the contained in tool in a PCBD diagram).
This doesn't seem to do anything (in expert view there are no changes) and I still can't allocate the components.
Could someone explain me what I am doing wrong and how to do it better?
FUDForum. Page generated in 0.10982 seconds
