Home » Eclipse Projects » EGit / JGit » Mylyn connector for github?
Mylyn connector for github? [message #1826870] Sun, 03 May 2020 12:24 Go to next message
Folks:
I'm trying to connect a project in Eclipse 2020-03 to my github repository and use the task list via Mylyn.
The problem is, I'm not seeing the github connector in the list of available repository connectors. Just bugzilla, trac, foglyn, matis, and tuleap.
I've installed all the plug-in's that look related.
Any suggestions on what I'm not seeing?
Here are the relevant plug-in's that are currently installed.
Mylyn Versions Connector: Git 1.16.0.v20170629-1738 org.eclipse.mylyn.git.feature.group Eclipse Mylyn
Git integration for Eclipse 5.7.0.202003110725-r org.eclipse.egit.feature.group Eclipse EGit
Mylyn Versions 1.17.0.v20180628-1737 org.eclipse.mylyn.versions.feature.group Eclipse Mylyn
Mylyn Commons 3.25.0.v20190131-2250 org.eclipse.mylyn.commons.feature.group Eclipse Mylyn
Thanks!
david
Re: Mylyn connector for github? [message #1826891 is a reply to message #1826870] Mon, 04 May 2020 02:37 Go to previous messageGo to next message
See https://www.eclipse.org/egit/download/ : the Mylyn Github connector is in a separate p2 update site at https://download.eclipse.org/egit/github/updates .
Re: Mylyn connector for github? [message #1826912 is a reply to message #1826891] Mon, 04 May 2020 10:15 Go to previous messageGo to next message
After a fair bit of poking around, I noticed there was an update for the git plug-in's.
I installed the updates and all of a sudden the github mylyn connector was available.
I established the connection and it's working as expected.
Now I just have to figure out how to use it. :)
Re: Mylyn connector for github? [message #1831010 is a reply to message #1826912] Sat, 08 August 2020 21:51 Go to previous messageGo to next message
This was great information. I had been looking for the github connector for some time. I've downloaded and installed it. I have it working except for two issues. Although I can see labels in the dropbox, they do not stick if applied from within Eclipse. You have to apply the label in GitHub, and then it is pulled down. And, you cannot see any of the milestones created in GitHub within the Eclipse task.
Are there some setting I'm missing somewhere?
Re: Mylyn connector for github? [message #1831011 is a reply to message #1826912] Sat, 08 August 2020 21:53 Go to previous message
Previous Topic:Commit and Push in a single click
Next Topic:Failed to install egit-5.1 from https://archive.eclipse.org/egit/updates-5.1/
Current Time: Sun Jul 20 21:38:57 EDT 2025
Powered by FUDForum. Page generated in 0.14232 seconds
