Multiple models in one diagram representation [message #1829986] |
Wed, 15 July 2020 05:54  |
I am trying to build an application where I have two models that are connected in some way.
The first model contains a component model, similar to an UML model representation. It is pretty fleshed out and contains some additional information and fields for elements.
In a second step, I now want to add a "MappingModel", which is basically just a model that maps components to strings (will be Java Classes at some point) and specific elements of the components to other strings.
I now want to be able to edit these mappings inside my diagram representation on a new Properties Page.
How can I add multiple models to a representation?
I tried to load the model in a service call, which worked, but I can not edit any information then. I think it has to do with Sirius not being able to "find" the EObject after the initial loading of the resource, but this is just guessing;
I had a properties view for mappingModel::ComponentMapping, with sementic candidates coming from service which I called on a component, i.e. component.getMapping().
Any ideas would be greatly appreciated.
Re: Multiple models in one diagram representation [message #1830155 is a reply to message #1830095] |
Sat, 18 July 2020 06:59  |
Hi Florian,
thanks! That was actually much easier than expected. The hint with "Sirius session" really helped, for anyone coming across this post, I can also recommend this thread: https://www.eclipse.org/forums/index.php/t/1078013/
For completeness, some quick notes that helped me:
When both models are in the same modeling project, they are automatically added to the same session.
You can retrieve all semantic resources of the current session in a service like this:
SessionManager.INSTANCE.getSession(obj).getSemanticResources();
Where obj is the EObject parameter of the service call.
I then iterate over all semantic resources and compare the URI of the resources to the URI of the model that I am searching for.
This way, I can return the Resource and use my program logic to return semantic candidates for diagram elements using yet another service, which uses the mentioned resource.
Bastian
FUDForum. Page generated in 0.03951 seconds
