Home » Eclipse Projects » Eclipse Titan » Installation problems on Window 10 Cygwin(Install problems)
Installation problems on Window 10 Cygwin [message #1827466] Thu, 14 May 2020 23:51 Go to next message
I install the TITAN on Win10.
The problem happens in compile TITAN.When I type in 'make -dep',there are some fatal errors. Then I type make install,there are errors .Error1 and Error 2.
Pls see the attachment.
Could someone help me ?
Re: Installation problems on Window 10 Cygwin [message #1827470 is a reply to message #1827466] Fri, 15 May 2020 01:54 Go to previous messageGo to next message
as you can read fom the end of the log, you shall install program "expect". Start cygwin installation program and do not change anything else but search "expect", choose it and install.
This is answer for make install. The "make dep" is not clearly documented in this conversation.
Hopefully this helps.
Best regards
Jenő Balaskó, Titan Team
Re: Installation problems on Window 10 Cygwin [message #1827471 is a reply to message #1827466] Fri, 15 May 2020 01:55 Go to previous messageGo to next message
Hi Didi,
did you follow the installation/configuration flow as exemplified in the tutorial video?
TITAN installation tutorial video for Windows with compiling on Cygwin.(Installation tutorial for the TITAN TTCN-3 toolset on Windows with compiling on Cygwin.)
https://www.eclipse.org/forums/index.php/t/1103718/
BR
Elemer
Re: Installation problems on Window 10 Cygwin [message #1827525 is a reply to message #1827470] Sun, 17 May 2020 06:09 Go to previous messageGo to next message
Hi Jeno,
Thanks for your answer!
I choose the "tcl expect' when install cywin.But there are still errors in the step"make install"see the attachment below.
BR,
Didi
Re: Installation problems on Window 10 Cygwin [message #1827529 is a reply to message #1827525] Sun, 17 May 2020 11:42 Go to previous messageGo to next message
Hi Didi,
if you don't want to use the Eclipse IDE, and you intend to use Titan in command line mode only,
you are probably better off if you install say a Ubuntu in Windows Subsystem For Linux, and install/build Titan under that.
Even better , you could use a Linux machine if you are not tied to Windows.
BR
Elemer
Re: Installation problems on Window 10 Cygwin [message #1827537 is a reply to message #1827529] Sun, 17 May 2020 20:29 Go to previous messageGo to next message
Hi Elemer ,
I am trying to install titan and use it in Win10,also I want to use Eclipse IDE but the process is not going well..
BR
Didi
Re: Installation problems on Window 10 Cygwin [message #1827557 is a reply to message #1827537] Mon, 18 May 2020 03:59 Go to previous message
Hi Didi,
Could you please check the contents of your Install directory?
In particular the c:\cygwin64\home\hover\git\titan.core\Install\include\RT1 forlder.
I can not read the Chinese characters, but maybe the folder is read only, or looking at it might help us further in some way.
Also please note that when using cygwin one can copy out the texts too.
In my case I just need to select the text in the terminal window, right click on the toolbar of the terminal window and select edit/copy ... after this the text can be copy pasted.
(or at least it works with ascii characters on my machine)
Br
Kristof
Previous Topic:Cannot make Demo Example from Titan
Next Topic:TITAN installation tutorial video for Windows with compiling on Cygwin.
Current Time: Mon Jul 21 06:12:39 EDT 2025
Powered by FUDForum. Page generated in 0.05114 seconds
