Home » Eclipse Projects » EGit / JGit » Authentication/Transport Error(Login Window does not take my credentials)
Authentication/Transport Error [message #1752719] Thu, 26 January 2017 08:04 Go to next message
Hey guys,
I have some trouble to clone my Repository. The Repository is running on Bitbucket if neseccary.
I tried to clone it via Egit with https. But when i type in my credentials and URI of the Repository and click next... Eclipse asks me again for my credentials... It asks me 3 Times for my credentials and then throws an exception. My Username and Password ist correct.
I guess Eclipse is not let me connect to the server.
Proxys Working fine (Marketplace is working).
I am also able to clone this repository besides Eclipse (Git bash)
EDIT: Neon.2, Windows 7 64 Bit...
Greetings Max
Error Message:
j
ava.lang.Exception: org.eclipse.jgit.api.errors.TransportException: https://mschwund@stash.Path.to/my/repo.git: not authorized
  at org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.perform(GitCloneTaskImpl.java:882)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3305)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.access$1(SetupTaskPerformer.java:3248)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil$1.run(SetupTaskPerformer.java:4469)
  at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2240)
  at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2267)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:4463)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.access$0(SetupTaskPerformer.java:4461)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3239)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3214)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:3114)
  at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:556)
  at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:682)
[Updated on: Thu, 26 January 2017 10:06] by Moderator
Re: Authentication/Transport Error [message #1752755 is a reply to message #1752719] Thu, 26 January 2017 16:25 Go to previous messageGo to next message
Which EGit version are you using ?
Does it work if you provide credentials on the first wizard page ?
Re: Authentication/Transport Error [message #1752770 is a reply to message #1752755] Fri, 27 January 2017 02:01 Go to previous messageGo to next message
Eclipse Git Team Provider 4.4.1.201607150455-r org.eclipse.egit.feature.group Eclipse EGit
No... Eclipse still asks me for my credentials.
Re: Authentication/Transport Error [message #1752958 is a reply to message #1752770] Tue, 31 January 2017 05:27 Go to previous messageGo to next message
Ok now the Problem is this:
org.eclipse.jgit.api.errors.TransportException: https://mschwund@XXX.XXX.XXX/scm/Test/testprof.git: cannot open git-upload-pack
	at org.eclipse.jgit.api.LsRemoteCommand.execute(LsRemoteCommand.java:221)
	at org.eclipse.jgit.api.LsRemoteCommand.call(LsRemoteCommand.java:159)
	at org.eclipse.egit.core.op.ListRemoteOperation.run(ListRemoteOperation.java:100)
	at org.eclipse.egit.ui.internal.clone.SourceBranchPage$8.run(SourceBranchPage.java:341)
	at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
Caused by: org.eclipse.jgit.errors.TransportException: https://mschwund@XXX.XXX.XXX/scm/Test/testprof.git: cannot open git-upload-pack
	at org.eclipse.jgit.transport.TransportHttp.connect(TransportHttp.java:510)
	at org.eclipse.jgit.transport.TransportHttp.openFetch(TransportHttp.java:288)
	at org.eclipse.jgit.api.LsRemoteCommand.execute(LsRemoteCommand.java:198)
	... 4 more
[Updated on: Tue, 31 January 2017 07:35] by Moderator
Re: Authentication/Transport Error [message #1826349 is a reply to message #1752719] Thu, 23 April 2020 16:27 Go to previous messageGo to next message
Did you ever get this to work. I have an issue very close to this. Egit :: clone repository takes my credentials and immediately throws the Transport Error (3 possible probs, url, sslVerify, etc). Git BASH clone works flawlessly. Any ideas on why Egit is being difficult?
Note: I do not have ssh keys set up.
Windows 10, Eclipse 4.4.2
Egit 4.9.2
Re: Authentication/Transport Error [message #1826373 is a reply to message #1826349] Fri, 24 April 2020 03:22 Go to previous messageGo to next message
You are using very ancient Eclipse and EGit versions. We are not fixing such old versions.
You should upgrade both to a recent release. Latest Eclipse release is 2020-03 and EGit 5.7.0 [1],
you can also try EGit nightly build [2] which is usually working fine and has a couple more fixes.
[1] https://download.eclipse.org/egit/updates
[2] https://download.eclipse.org/egit/updates-nightly
Re: Authentication/Transport Error [message #1826406 is a reply to message #1826373] Fri, 24 April 2020 09:15 Go to previous messageGo to next message
Thanks very much.
I'm limited by the fact that I'm in IBM ODM Rule Designer, the Eclipse built for BRMS business rules. Current version is 8.10.x but my client is confined to 8.9.x, which is a fairly recent version of Rule Designer (I realize not of Eclipse).
Trying to pull in a later version of Egit - using both of your links, most recently the most recent nightly builds, the installation balks and wants to install 4.9.20171215...
Is this because the update site does not like my "old" version of Eclipse?
How does the update know not to use the more recent version of Egit, and how does it choose which version to install instead?
Re: Authentication/Transport Error [message #1826408 is a reply to message #1826406] Fri, 24 April 2020 09:26 Go to previous messageGo to next message
You also reported this problem at https://www.eclipse.org/forums/index.php/t/1103487/ . Would be good if we could discuss this in one place.
That said, the latest EGit that will install in an Eclipse 4.4. is EGit 5.0.3, available at the update site https://download.eclipse.org/egit/updates-5.0.3 . See https://wiki.eclipse.org/EGit/FAQ#What_versions_of_Eclipse_does_EGit_target.3F .
Re: Authentication/Transport Error [message #1826410 is a reply to message #1826408] Fri, 24 April 2020 09:44 Go to previous messageGo to next message
Thanks for your great help. I agree, I should not have redundant threads. Please forgive.
Let's use the other thread please:
I will go there now.
Re: Authentication/Transport Error [message #1850167 is a reply to message #1826410] Fri, 18 February 2022 16:33 Go to previous messageGo to next message
Hello, People!
I have the exact same problem, the exact same error message, with the latest Eclipse version.
Re: Authentication/Transport Error [message #1850178 is a reply to message #1850167] Sat, 19 February 2022 12:50 Go to previous message
Which error message? There were several mentioned in this thread.
Please show the exact error message and any exceptions from the log. Also which EGit/JGit version exactly, and what operation did you attempt? Cloning?
What kind of server is used? If Bitbucket, the Server or the Cloud version?
Previous Topic:How to implement a breadth-first rev walker to find closest branch for HEAD
Next Topic:Does JGit has LFS file locking APIs
Current Time: Fri Jul 25 09:38:40 EDT 2025
Powered by FUDForum. Page generated in 0.04187 seconds
