Home » Modeling » TMF (Xtext) » The feature ..... contains an unresolved proxy
The feature ..... contains an unresolved proxy [message #1809267] Fri, 12 July 2019 11:25 Go to next message
I have a maven project, inside this maven project I have file like test.mydsl.
Eclipse keep showing an error like that and it can't resolve the references :
The feature 'type' of 'org....@6eefd0e3{platform:/resource/.../test.mydsl#... contains an unresolved proxy
When I put the same file in a fresh workspace I don't have any problem.
What is the root cause of this error ?
[Updated on: Fri, 12 July 2019 11:27] by Moderator
Re: The feature ..... contains an unresolved proxy [message #1809270 is a reply to message #1809267] Fri, 12 July 2019 11:31 Go to previous messageGo to next message
this is hard guessing without any hints.
- is the project a java project => is the model in a source folder
- is the project a xtext project => rightclick, configure, convert to xtext project
Re: The feature ..... contains an unresolved proxy [message #1809274 is a reply to message #1809270] Fri, 12 July 2019 11:39 Go to previous messageGo to next message
Maybe you can tell the cause of this error, i.e what does it mean ?
I will try to find some hints
Re: The feature ..... contains an unresolved proxy [message #1809276 is a reply to message #1809274] Fri, 12 July 2019 11:58 Go to previous messageGo to next message
this means you have have somewhere in your dsl a cross ref
like
class X extends Base
and Base cannot be found
Re: The feature ..... contains an unresolved proxy [message #1809284 is a reply to message #1809276] Fri, 12 July 2019 13:27 Go to previous messageGo to next message
And why I have no error i a fresh workspace ?
Re: The feature ..... contains an unresolved proxy [message #1809285 is a reply to message #1809284] Fri, 12 July 2019 13:28 Go to previous messageGo to next message
I don't know what you do so I have no idea did you check the hints I gave above.
Re: The feature ..... contains an unresolved proxy [message #1809286 is a reply to message #1809285] Fri, 12 July 2019 13:37 Go to previous messageGo to next message
Yes but I have questions :
Are you talking about the maven project or the project containing the mydsl files.
I think you are talking of the source code of the DSL. But in my case the dsl is already deployed using an update site.
Acually the DSL is already deployed as a feature in Eclipse.
But I don't see why a workspace can impact a whole DSL.
Re: The feature ..... contains an unresolved proxy [message #1809287 is a reply to message #1809286] Fri, 12 July 2019 13:39 Go to previous messageGo to next message
I am talking about the project where you get the error
Re: The feature ..... contains an unresolved proxy [message #1809288 is a reply to message #1809287] Fri, 12 July 2019 13:42 Go to previous messageGo to next message
I don't have the configure option, as they are simple folders of a maven project
Re: The feature ..... contains an unresolved proxy [message #1809289 is a reply to message #1809288] Fri, 12 July 2019 13:43 Go to previous messageGo to next message
How does that project look like. Please share a screenshot
Re: The feature ..... contains an unresolved proxy [message #1809290 is a reply to message #1809289] Fri, 12 July 2019 13:43 Go to previous messageGo to next message
And are you sure you cannot rightclick configure on the project ?
Re: The feature ..... contains an unresolved proxy [message #1809291 is a reply to message #1809290] Fri, 12 July 2019 13:56 Go to previous messageGo to next message
I put an error on the problematic file.
When I take this exact file on a fresh workspace it does not contain error.
My issue seems to be similar to this one : https://www.eclipse.org/forums/index.php/t/439033/
  • Attachment: screen.png
    (Size: 37.84KB, Downloaded 80 times)
Re: The feature ..... contains an unresolved proxy [message #1809292 is a reply to message #1809291] Fri, 12 July 2019 14:05 Go to previous messageGo to next message
There is only one file. Where is the other one you reference to?
Re: The feature ..... contains an unresolved proxy [message #1809293 is a reply to message #1809291] Fri, 12 July 2019 14:10 Go to previous messageGo to next message
My references are inside the same file.
Re: The feature ..... contains an unresolved proxy [message #1809294 is a reply to message #1809293] Fri, 12 July 2019 14:13 Go to previous messageGo to next message
There is something in the workspace that breaks the DSL. The same than the link above
Re: The feature ..... contains an unresolved proxy [message #1809295 is a reply to message #1809294] Fri, 12 July 2019 14:18 Go to previous messageGo to next message
Sorry I have no idea.
Do you have custom scoping?
[Updated on: Fri, 12 July 2019 14:29] by Moderator
Re: The feature ..... contains an unresolved proxy [message #1809297 is a reply to message #1809295] Fri, 12 July 2019 14:44 Go to previous messageGo to next message
Ok, thank you for your help :)
Re: The feature ..... contains an unresolved proxy [message #1809304 is a reply to message #1809297] Fri, 12 July 2019 17:39 Go to previous message
The message you reference provides some good clues. Due to various bugs tools are operating in target/classes and doing stupid unnecessary things.
You have not hared nearly enough information to be able to tell what your problem really is.
Ed Willink
Previous Topic:Xtext Referencing Not Working in Java Project
Next Topic:Xtext grammar autocompletion
Current Time: Sun Aug 31 03:01:18 EDT 2025
Powered by FUDForum. Page generated in 0.07679 seconds
