Home » Eclipse Projects » SWTBot » SWTBot test canot load class from application under testing(ClassDefNotFoundError)
SWTBot test canot load class from application under testing [message #1799784] Thu, 13 December 2018 08:15 Go to next message
Hello
I observed the following obstacle. In unit test I would like to get more information about GUI object for this I have to load class that is located in one bundle. This bundle is part of application under testing. Code Snippet like
 for (SWTBotGefEditPart editorPart : list) {
            Object modelObj = editorPart.part().getModel();
            InventarBrowserDevice model = (InventarBrowserDevice) modelObj;
in line InventarBrowserDevice model = (InventarBrowserDevice) modelObj;
I see the
java.lang.NoClassDefFoundError:
/xxx/yyy/InventarBrowserDevice
java.lang.NoClassDefFoundError: xxx/yyy/InventarBrowserDevice
java.lang.ClassNotFoundException: xxxx.yyy.InventarBrowserDevice
xxx.yyyy..Utils.GraphicUtils GraphicUtils.java 118 graphicalEditorGetElement
xxx.yyy.ibrowser.SchaltzettelVorv SchaltzettelVorv.java 116 Schaltzettel
sun.reflect.NativeMethodAccessorImpl NativeMethodAccessorImpl.java -2 invoke0
sun.reflect.NativeMethodAccessorImpl NativeMethodAccessorImpl.java 62 invoke
sun.reflect.DelegatingMethodAccessorImpl DelegatingMethodAccessorImpl.java 43 invoke
java.lang.reflect.Method Method.java 498 invoke
org.junit.runners.model.FrameworkMethod$1 FrameworkMethod.java 44 runReflectiveCall
org.junit.internal.runners.model.ReflectiveCallable ReflectiveCallable.java 15 run
org.junit.runners.model.FrameworkMethod FrameworkMethod.java 41 invokeExplosively
org.junit.internal.runners.statements.InvokeMethod InvokeMethod.java 20 evaluate
org.junit.runners.BlockJUnit4ClassRunner BlockJUnit4ClassRunner.java 79 runNotIgnored
org.junit.runners.BlockJUnit4ClassRunner BlockJUnit4ClassRunner.java 71 runChild
org.junit.runners.BlockJUnit4ClassRunner BlockJUnit4ClassRunner.java 49 runChild
org.junit.runners.ParentRunner$3 ParentRunner.java 193 run
org.junit.runners.ParentRunner$1 ParentRunner.java 52 schedule
org.junit.runners.ParentRunner ParentRunner.java 191 runChildren
org.junit.runners.ParentRunner ParentRunner.java 42 access$000
org.junit.runners.ParentRunner$2 ParentRunner.java 184 evaluate
org.junit.internal.runners.statements.RunBefores RunBefores.java 28 evaluate
org.junit.internal.runners.statements.RunAfters RunAfters.java 31 evaluate
org.junit.runners.ParentRunner ParentRunner.java 236 run
org.eclipse.swtbot.swt.finder.junit.SWTBotJunit4ClassRunner SWTBotJunit4ClassRunner.java 54 run
org.junit.runners.Suite Suite.java 128 runChild
xxx.yyy.SSSSuite SSSSuite.java 150 runChild
xxx.yyy.SSSSuite SSSSuite.java 20 runChild
junit.framework.JUnit4TestAdapter JUnit4TestAdapter.java 39 run
org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner EclipseTestRunner.java 350 run
org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner EclipseTestRunner.java 208 run
org.eclipse.swtbot.eclipse.junit.headless.UITestApplication UITestApplication.java 116 runTests
org.eclipse.ui.internal.testing.WorkbenchTestable$1 WorkbenchTestable.java 71 run
java.lang.Thread Thread.java 748 run
How can I resolve this issue?
[Updated on: Thu, 13 December 2018 08:19] by Moderator
Re: SWTBot test canot load class from application under testing [message #1799793 is a reply to message #1799784] Thu, 13 December 2018 09:53 Go to previous messageGo to next message
As first step I added required bumdle to MANIFEST of test plugin. It does not help.
Also I'm able to load required bumndle and load requied Class object rom bundle.
But when try to transform type from Object to required type I catch this exception
 Object modelObj = editorPart.part().getModel(); <--- success
 InventarBrowserDevice model = (InventarBrowserDevice) modelObj; <--- fail
[Updated on: Thu, 13 December 2018 09:59] by Moderator
Re: SWTBot test canot load class from application under testing [message #1799803 is a reply to message #1799793] Thu, 13 December 2018 13:54 Go to previous message
Seems to me I found the reason of issue. The bundle that contains required class has empty list of exported package. I've add required one then coersion opertion eas performed with success
Previous Topic:Release planned for Eclipse 2018-12?
Next Topic:2018-12 Issues
Current Time: Sun Jul 27 10:02:03 EDT 2025
Powered by FUDForum. Page generated in 0.04084 seconds
