Home » Modeling » Compare » EMF Compare EGIT Performance
EMF Compare EGIT Performance [message #1770222] Wed, 09 August 2017 03:54 Go to next message
I trying to use EMF Compare with an Git Based Repository (EGit Plugin). Everytime when im compare my model with the Remote Repository Eclipse freezes. My model ist about 4 MB
I analyze the Problem and i find out that the intrinsicIDMap ist always emty.
(Iam using a custom ResourceImpl)
So the whole model File is iterated for each Object id, maybe the source of the Problem is based on the class SynchronizedResourceSet, where is mentioned that you dont use the feature
XMLResource.OPTION_USE_XML_NAME_TO_FEATURE_MAP
https://bugs.eclipse.org/bugs/show_bug.cgi?id=403425
https://www.eclipse.org/forums/index.php/t/929918
Could you give me a hint for solving the problem
Re: EMF Compare EGIT Performance [message #1770426 is a reply to message #1770222] Fri, 11 August 2017 04:43 Go to previous message
Hi Markus,
Are you using the latest EMF Compare build (3.3.1, can be installed from http://download.eclipse.org/modeling/emf/compare/updates/releases/3.3/R201706130827)? Which version of EGit are you using?
Other than that... EMF Compare never explicitely sets the intrinsicIDToObjectMap. Why do you expect it to be set in your case? It sounds like it could be a very nice performance improvement for EMF Compare to set that map when it starts to resolve the logical model (and unset it once loading is done). Would you have any means to share a sample model that presents this particularity so that we can get a feel of the numbers?
Laurent Goubet
Obeo
Previous Topic:code snippet for loading comparing models from GIT
Next Topic:Merge issue "because its parent hasn't been merged yet"
Current Time: Sun Jul 20 22:12:26 EDT 2025
Powered by FUDForum. Page generated in 0.03954 seconds
