Home » Eclipse Projects » Eclipse Platform » Deleting projects
Deleting projects [message #286120] Thu, 02 June 2005 16:09 Go to next message
Originally posted by: torkildr.tihlde.org
I want my plugin to be notified when a project is being deleted so that I
can remove all the metadata. Considering that all resource changes are
caught by my IncrementalProjectBuilder I was guessing that I can trap
project deletions there, but that does not seem to be the case. Am I doing
something wrong or should I use a ResourceChangeListener for this?
Med vennlig hilsen / Kind regards ((
Torkild Ulvøy Resheim, Senior Systemutvikler / Software Engineer ))
Emma EDB AS, Trondheim, Norway. http://www.emmaedb.no |----|_
Private pages: http://resheim.no - "Any sufficiently advanced | | )
bug is indistinguishable from a feature." |____|'
Re: Deleting projects [message #286122 is a reply to message #286120] Thu, 02 June 2005 17:01 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
There is a way of storing the metadata on a per project basis. In that
case the metadata will be deleted at the same time as the project for
you automatically.
To put something in the project metadata area use:
IPath data = iproject.getWorkingLocation("yourpluginid/whatever-you-want ");
This will return an absolute file path that is per project.
Rich Kulp
Re: Deleting projects [message #286144 is a reply to message #286122] Fri, 03 June 2005 01:38 Go to previous messageGo to next message
> you automatically.
> IPath data =
Hi Rich,
Ah... that looks like something I need to investigate. So far I've been
using the plugin's working location. However I also need to remove data
from memory at the same time. Maybe I should just implement the
ResourceChangeListener. It's pretty straightforward so there is not a big
deal if I need to change it.
[snip]
Re: Deleting projects [message #286162 is a reply to message #286144] Fri, 03 June 2005 08:49 Go to previous messageGo to next message
You should probably put your project in the project metadata area and
use the resource listener for in-memory. This is because it is possible
to have the project deleted before anything caused your plugin to be
activated. In that case you would not have a listener. So the data would
still automatically go away then.
>>you automatically.
>>IPath data =
> Hi Rich,
> [snip]
> Thanks :-)
Rich Kulp
Re: Deleting projects [message #286164 is a reply to message #286162] Fri, 03 June 2005 08:53 Go to previous messageGo to next message
Also, this article may be useful to you. It is about resource change
listening:
http://eclipse.org/articles/Article-Resource-deltas/resource -deltas.html
Rich Kulp
Re: Deleting projects [message #286253 is a reply to message #286164] Mon, 06 June 2005 05:31 Go to previous message
> listening:
Thanks :-) I've implemented the ResourceChangeListener and it all works
well. Now I just need to move the metadata.
Previous Topic:Full path from SaveAsDialog
Next Topic:Path to resources
Current Time: Sat Nov 15 23:29:52 EST 2025
Powered by FUDForum. Page generated in 0.25828 seconds
