Home » Eclipse Projects » SWTBot » Eclipse SWTBot generator with Nattable
Eclipse SWTBot generator with Nattable [message #1761034] Fri, 05 May 2017 09:24 Go to next message
I have an existing RCP application which used Nattable. I have used 'org.eclipse.swtbot.generator_2.5.0.201609021837' jar and launched SWTBot test recorder successfully.
But it does not capture clicks/events from view which uses Nattable.
Re: Eclipse SWTBot generator with Nattable [message #1761173 is a reply to message #1761034] Mon, 08 May 2017 10:35 Go to previous message
Indeed, the SWTBot Generator has not been updated to support the NatTable widget.
If you would like to contribute this support, you can follow the guidelines found on the wiki: https://wiki.eclipse.org/SWTBot/Contributing
Previous Topic:Finding item in swtbottable fails if item not present in first column.
Next Topic:SWTBot & acceptance tests tools
Current Time: Sat Jun 14 01:41:22 EDT 2025
Powered by FUDForum. Page generated in 0.03704 seconds
