Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » SubApp Error
SubApp Error [message #1733157] Tue, 24 May 2016 16:24 Go to next message
Hi mi 4DIAC partners, I'm tying to handle a SubApplication but it turns impossible because of this problem:
https://lh5.googleusercontent.com/-FEXgjdYlxFU/V0S36qn3BVI/AAAAAAAAD00/hhGILSNXXKUioBakgjHTDtJVf3wYZz7MQCL0B/w564-h316-no/1.jpg
https://lh6.googleusercontent.com/-fTeXKfvU36o/V0S36l_2mmI/AAAAAAAAD04/WKxRexw3dAEYDO9MaOqB10nqSeLUGWlhwCL0B/w408-h400-no/3.jpg
I have no clue, please some help.
Re: SubApp Error [message #1733219 is a reply to message #1733157] Wed, 25 May 2016 09:26 Go to previous messageGo to next message
first of all I've to add a short disclaimer: Currently the Subapplication implementation in 4IDAC-IDE is very fragile and needs improvement. This is one of the reasons we started the big code-cleanup that we announced a few weeks back [1].
Regarding your problem. Could you be so kind and let us know what you did so that we can try to reproduce the problem?
Alois
[1] https://www.eclipse.org/4diac/en_news.php#en_news_20160330
Re: SubApp Error [message #1733261 is a reply to message #1733219] Wed, 25 May 2016 15:48 Go to previous messageGo to next message
All the problem started here, in that little subapp unmapped:
https://lh6.googleusercontent.com/-eDCRarowN3k/V0X_-kH9hII/AAAAAAAAD1s/9GokRwkJa08RISKkBLAi4aug8pPZg1nuQCL0B/w1026-h577-no/RECONFIGURACION.jpg
I was taking a screenshot of inside the subapplication but all 4DIAC collapsed before I could have done it.
https://lh6.googleusercontent.com/-XybWzLa_D7M/V0YAMcRCHfI/AAAAAAAAD1w/I-ZEvsf0XS4hOnvUrXeAWay17H-i135oACL0B/w1026-h577-no/error1.jpg
https://lh4.googleusercontent.com/-8G-_-E0qrBA/V0YAsb-0cyI/AAAAAAAAD2M/AowvKUaYuPILscSTjK98Rsb7Ewme43EJACL0B/w1026-h577-no/error2.jpg
Please I need to recover that project.
Re: SubApp Error [message #1733264 is a reply to message #1733261] Wed, 25 May 2016 17:02 Go to previous messageGo to next message
could you zip me your whole project directory so that I can better see where the issue is?
Re: SubApp Error [message #1733338 is a reply to message #1733264] Thu, 26 May 2016 11:00 Go to previous messageGo to next message
4DIAC does not let me see the project directory, I can only zip the FB libraries.
This is what I could extract:
https://www.dropbox.com/s/hufbkc42xd5092s/maquina.zip?dl=0
  • Attachment: maquina.zip
    (Size: 833.95KB, Downloaded 106 times)
Re: SubApp Error [message #1733359 is a reply to message #1733338] Thu, 26 May 2016 09:35 Go to previous messageGo to next message
yes 4DIAC provides you only the IEC 61499 system view. But you can access all the files also from your file explorer 4DIAC stores everything in plane xml files. You can easily save this files away for backup or add them into a version control system. I would recommend one of both.
Regarding your project. I spent some time looking through your project files. I don't know what happened here. After working a while with the files I could get a bit back from you when I deleted all devices (see attached project). What I didn't manage to bring back was the broken subapplication in your reconfiguration application. I'm very sorry that this happened and hope that this helps at least a bit.
Do you have more information on what steps you did? This could really help us to stabilize 4DIAC for future releases.
Re: SubApp Error [message #1733364 is a reply to message #1733338] Thu, 26 May 2016 17:12 Go to previous message
It's very useful, thank you so much!
Previous Topic:prevent FORTE from tracing to syslog
Next Topic:Use STRING datatype with IEC61131 F_SEL block
Current Time: Thu Jul 24 22:38:13 EDT 2025
Powered by FUDForum. Page generated in 0.07785 seconds
