Home » Modeling » Epsilon » Load second UML model with ANT
Load second UML model with ANT [message #1725170] Tue, 01 March 2016 06:04 Go to next message
Hi all,
I'm beginner in Epsilon. I need to load 2 or 3 UML models for comparison but when I use epsilon.loadmodel in ANT, this has BUILD FAILED for second UML model and can't create task or type epslion.loadmodel. however first UML model is loaded.
This is my build.xml:
<project default="compare">
<target name="loadModels">
<epsilon.eol>
"TESTMODEL".println();
</epsilon.eol>
<epsilon.loadModel name="V1" type="UML" impl="org.eclipse.epsilon.emc.uml.UmlModel">
<parameter name="modelFile" value="/ANTPro/V1.uml"/>
<parameter name="readOnLoad" value="true"/>
</epsilon.loadModel>
<epsilon.eol>
<model ref="V1"/>
Class.all.size().println();
</epsilon.eol>
<epsilon.emf.loadmodel name="V2" impl="org.eclipse.epsilon.emc.uml.UmlModel">
<parameter name="modelFile" value="/ANTPro/V2.uml"/>
</epsilon.emf.loadmodel>
<epsilon.eol>
<model ref="V2"/>
</epsilon.eol>
</target>
<target name="compare" depends="loadModels">
<epsilon.ecl src="CompareUML.ecl"
exportmatchtrace="matchTrace1">
<model ref="V1" alias="Source"/>
<model ref="V2" alias="Source"/>
</epsilon.ecl>
</target>
</project>
Ant the console output is:
Buildfile: E:\eclipse-epsilon-1.2-win32-x86_64\workspace\ANTPro\build.xml
loadModels:
[epsilon.eol] TESTMODEL
[epsilon.eol] 2
BUILD FAILED
E:\eclipse-epsilon-1.2-win32-x86_64\workspace\ANTPro\build.xml:19: Problem: failed to create task or type epsilon.emf.loadmodel
Cause: The name is undefined.
Action: Check the spelling.
Action: Check that any custom tasks/types have been declared.
Action: Check that any <presetdef>/<macrodef> declarations have taken place.
Total time: 508 milliseconds
My Epsilon version is 1.2 and my eclipse is Luna 4.4.0
Can someone help me?
Thanks ...
Re: Load second UML model with ANT [message #1725224 is a reply to message #1725170] Tue, 01 March 2016 15:55 Go to previous messageGo to next message
As stated in [1], "when running an ANT workflow that involves Epsilon tasks, please make sure you select the Run in the same JRE as the workspace option under the JRE tab of your launch configuration.".
Dimitris
[1] https://www.eclipse.org/epsilon/doc/workflow/
Re: Load second UML model with ANT [message #1725271 is a reply to message #1725224] Wed, 02 March 2016 03:45 Go to previous messageGo to next message
Hi Dimitris,
Yes, I selected the "Run in the same JRE as the workspace" option under the JRE tab of my launch configuration.
I think, it's problem of epsilon loadmodel for loading more than one UML models.
Can you test it?
A sample project is attached.
Mohammadreza
  • Attachment: ANTPro.zip
    (Size: 20.02KB, Downloaded 187 times)
Re: Load second UML model with ANT [message #1725297 is a reply to message #1725271] Wed, 02 March 2016 05:21 Go to previous messageGo to next message
There seems to be a typo in line 19 of build.xml. "epsilon.loadmodel" should be "epsilon.loadModel" instead (ANT is case-sensitive).
Dimitris
Re: Load second UML model with ANT [message #1725303 is a reply to message #1725297] Wed, 02 March 2016 06:34 Go to previous messageGo to next message
Hi Dimitris,
OK, My problem was solved.
Thanks a lot for your helps.
Mohammadreza
Re: Load second UML model with ANT [message #1843471 is a reply to message #1725224] Sat, 31 July 2021 10:24 Go to previous messageGo to next message
Regarding the "Run in the same JRE as the workspace" option, is there any way to specify that but programatically, when calling the build.xml from Java code? (I'm using ProjectHelper for that matter)
[Updated on: Sat, 31 July 2021 10:25] by Moderator
Re: Load second UML model with ANT [message #1843487 is a reply to message #1843471] Mon, 02 August 2021 05:31 Go to previous message
Hi Miguel,
I'm not familiar with ProjectHelper I'm afraid. Have you tried using AntRunner [1]? To investigate this further, a minimal example would be useful.
Best,
Dimitris
[1] http://archive.eclipse.org/eclipse/downloads/documentation/2.0/html/plugins/org.eclipse.platform.doc.isv/reference/api/org/eclipse/ant/core/AntRunner.html
Previous Topic:Model Validation from Java Code
Next Topic:How to configure the project when I try to run the EUnit test by JAVA on linux command line?
Current Time: Sat Jul 26 12:11:45 EDT 2025
Powered by FUDForum. Page generated in 0.05260 seconds
